Increase compression ratio? - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Build Archive
Engine Build Archive A place to archive DYNO or 1/4mile VERIFIED engine builds. Please post any engine tech questions to the Engine Tech forum.
Old 02-10-2010, 12:31 AM
TonyS TonyS is offline
TonyS First On Race Day
Question Increase compression ratio?
What is the easiest and best way to increase my compression ratio? I have a 460 out of a 1986 F350. Can I just mill the heads? If so, how much without going to adjustable overhead? What about just changing the pistons? I am looking for about 10:1 at the end. Thanks for the help.
Old 02-11-2010, 10:10 AM
fordrka1975 fordrka1975 is offline
fordrka1975 Driving a Ford
the easiest way imo is to get a set of c8,c9 or dove heads.Randy.
Old 02-11-2010, 12:12 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
You can mill the current heads .020 without any changes in the valvetrain required, but that will only raise the compression by .2 of a point.
Milling the heads .020, installing flat tops and zero decking will get you about 9.6:1.
Installing early small chamber heads on the current setup will get you about 10:1, but will require a different valvetrain.
Installing dome pistons with the current heads, no other machine work, and no change in valvetrain will get you about 10.5:1.
Old 02-27-2010, 08:47 PM
Thanks, I like the idea of changing the pistons vs messing with the milling and head work.
Old 03-09-2010, 06:51 PM
Is it as easy as bolting on the right heads and leaving everything else alone? I understand DOVE heads. What do you mean by C8 and C9 heads?
Thanks, Tony
Old 03-09-2010, 07:23 PM
CarsByCarl's Avatar
Thanks, Tony
C8 and C9 are essentially the same as D0VE heads and can be bolted on in place of the current heads, but they will require different rockers, etc. than the later D3 style heads.
Be sure to consider the cost of the early heads, machine work to make them right (hard seats, valve job, guides), new valvetrain, etc. and compare it to the cost of pistons, balance work, pressing rods on the pistons, etc.
