what engine oil is best for big block ford's - 460 Ford Forum
Old 03-01-2010, 07:47 PM
levy87's Avatar
levy87 levy87 is offline
levy87 Driving a Ford
Default what engine oil is best for big block ford's
i've been using 20w50 lucas racing oil is this a good oil or can i do better?what brand's and weight are you guy's using. also i think i should be using synthetic.i spent a lot of money on motor and i don't want to use cheap oil.what do you guy's think about amsoil,red line,royal purple oil, good,bad?talk to me .what about amsoil 5w20 racing oil any good.
10.5 junkie
Old 03-01-2010, 08:13 PM
Cj Ford's Avatar
Cj Ford Cj Ford is offline
Cj Ford Driving a Ford
I use plain old Havoline 20w50 have had great results, been using it for the last 10 years
Chris
Chevy big blocks are great ....... for traction !!!
Old 03-01-2010, 08:20 PM
65_Ford_F100's Avatar
65_Ford_F100 65_Ford_F100 is offline
65_Ford_F100 First On Race Day
I use Brad Penn racing oil, 10w-30 with a 70/30 Lucas blend. I wouldn't run anything else in my motor.
Mike Gentry "A Ford man in a Chevy world"
1965 Ford F-100, 460/429, C6, 9" Posi Axle.
Old 03-01-2010, 08:37 PM
blown473 blown473 is offline
blown473 First On Race Day
Smile motor oil
I use Mobil 1 15w-50. I really believe in the synthetics. It has a higher level of zddp than other Mobil 1 wts. It gives good temperature range and motors I have seen run on it show almost no wear. You can get a really good price on it if you buy it in the 5 qt jug at Walmart; about $22. I like Royal purple synthetic too, but its very pricey at $9. a qt. I have a 10qt system so 2 jugs isn't bad about $45 + a filter for a change. My oil pressure runs 80 cold and on the hottest day (105 degree summers) about 30 hot. Thats with a standard vol. pump.
Old 03-01-2010, 09:19 PM
richter69's Avatar
richter69 richter69 is offline
richter69 Driving a Ford
I'm real fond of Schaeffer's products, Ever since I switched over and started getting the oil analysis done the reports have been awesome. My alky motor be hard on oil.....................
If anyone is looking for this product I have a friend who is a dealer, can drop ship most places as well.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
Old 03-02-2010, 02:09 AM
levy87's Avatar
Default oil, what brand, so many choices??
what do you guy's think about amsoil is it any better then lucas oil.amsoil sell's a racing oil 5w50 it's like $10.50 a quart, but is it worth it.i have an iron headed motor with a hydraulic cam 30 over 460 making it a 466 nothing to radical ,little bit of spray 125 shot,i just want to make improvements this year. i figure i want to start off with a good oil,also i have a powerglide from jw, i have been using there oil but is there better stuff. i want to go in the direction of synthetic for the motor and trans.
10.5 junkie
  #7
Old 03-02-2010, 11:20 AM
Cale Aronson's Avatar
Cale Aronson Cale Aronson is offline
Administrator
Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!
Lucus is good stuff. When it gets to synthetics there are three brands that I tell my customers to stick with. Lucus, Royal Purple or Redline. There are some others out there, but some of them break down much worse than the norm.
Cale Aronson - Administrator
Aronson Motorsports
Ford Racing 2010 Mountain Motor Pro Stock Mustang
Shop - 660-646-4553 - Cell - 816-390-0852 - Email - cale@gofastquick.com
WWW.GOFASTQUICK.COM
Jon Kaase Racing Engines - Ford Racing Parts - UPR Products - RAM Clutches - PEM Gears - Orme Brothers - Penske Racing Shocks - Innovators West - DJ Safety
  #8
Old 03-02-2010, 06:25 PM
HEMI-HUNTER HEMI-HUNTER is offline
HEMI-HUNTER Driving a Ford
Valvoline Racing Str. 50# --what other kind is they?
70' Maverick , 557 A-Head 8.90's...1969 #MATCHING MACH1 428 CJ RESTORED 1 of 1....1970 HEMI CHALLANGER
  #9
Old 03-02-2010, 08:34 PM
levy87's Avatar
Default question for blown473
is the mobile1 15w50 at walmart full synthetic oil,or semi synthetic?what is the difference between 15w50 and 20w50 oil?i have an high volume oil pump stars cold at 78psi,then warms up and stay's at 60 psi,hydraulic cam,not roller,305 comp cam magnum.should i be using straight 50 weight synthetic,or 20w50 synthetic
10.5 junkie
  #10
Old 03-02-2010, 09:45 PM
falconracer's Avatar
falconracer falconracer is offline
falconracer Driving a Ford
Send a message via AIM to falconracer
Valvoline VR1 20w-50
"Best Engineered Full Bodied Car" winner at the
2006 IHRA Div. 2 Bracket Finals.
514 BT heads
1050 Holley Dominator
Custom Cam
Comp Lifters
PG Trans
5.60 @ 122 , 1.19 60 ft. 1/8 mile
http://www.rapturemotorsports.com
  #11
Old 03-03-2010, 12:09 AM
800+BBF's Avatar
800+BBF 800+BBF is offline
800+BBF First On Race Day
Default Oil
After some Dyno pulls and 20 gal of race fuel, I Like RED LINE RACING 40WT. Also added a half qt of Lucas Oil Stabilizer
BUILT FORD TUFF
  #12
Old 03-03-2010, 09:45 AM
bigblok86ranger's Avatar
Super Moderator
Exclamation
Amsoil Has bought a bunch of Latemodel motors around here last couple years so I would stay away from that. I would think it would be hard to keep the doors open buying a bunch of these guys new 30-40000 dollar engine because of oil failure.
Eric Millard
bigblok86gt@yahoo.com
Pumpgas 523 powered 2000 Ford Ranger
Best run to date; 10.51@128.55 on 93 octane!!!
http://www.poweredbyfordrace.com/
  #13
Old 03-03-2010, 06:06 PM
levy87's Avatar
Thumbs up
your right staying away from amsoil.i just bought synthetic royal purple oil for the motor,trans,and the differential ,set me back several hundred dollars.i figure might as well get the best.i don't want my stuff breaking.i plan on going to the the track alot this year,and spraying it hard.
10.5 junkie
  #14
Old 03-05-2010, 09:00 AM
rickyd rickyd is offline
rickyd Driving a Ford
Smile What oil?
Here is some thoughts one I have always used 20w50 Valoline blend and have never had a lube type failure I like to keep the spread as close as possible so if the oil starts to break down it won't change too to lite of oil I have been told that the base weight is the smallest of the two and then if you start the car in cold weather a straight weight like 50 is not going to flow well and then keep it affordable and change it more often so you don't flush big bucks down the drain and all ways change the oil after any time you have to pull a intake or head the other thing is if your machine work will suport useing a 5w20 think of the supply and the demand if you have a race engine and it is machined as such specs are held tighter where a street engine may not be and the higher weight helps fill the gap any way just some thoughts. Mine 466 cj head 85 stang soon to be 533 SCJ tunnel ramed
  #15
Old 03-05-2010, 02:49 PM
levy87's Avatar
valvoline 20w50 is a good oil i've used it before.i'm going to try royal purple this season,i want to see how much difference it has than the other stuff i used in the past.i'm experimenting.what was cool about it.i orderd it from summit and they literly had it deliverd on my porch waitng for me the next day went i got home from work now that kiks ***.i did'nt even have to go to the store and lug all the stuff home.bam
10.5 junkie
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
