TOW RIG. - Page 2 - 460 Ford Forum
  #16
Old 05-18-2010, 11:24 PM
kid460 kid460 is offline
kid460 First On Race Day
no matter what they should take the tires back i work at an auto shop an we see alot of tires that get ply seperations or the metal on the inside of the tire lets go an our tire distributor always replaces them free of charge so i would take them back to where you got them or if you got them of the internet call them also easy way to tell if there bad is spin the tire look at the tread see if its still round an then look at the sidewalls an spin it an make sure there straight just in case you didnt know
92 fox
460 bb
c-6 3000 stall
8.8
slick
an its really funny how cops dont like slicks or loud exhaust they give me crap all the time lol
Old 05-19-2010, 09:08 AM
wayney wayney is offline
wayney Driving a Ford
that looks like the dueller at revo tires? I have had a couple sets on my previous truck
didn't have any problems towing 10000 on a single rear wheel truck.
wayne
  #18
Old 05-19-2010, 04:01 PM
turbo2256b First On Race Day
I purchased them from Tire Rack. They wouldnt take them back because they were on the truck for a few days over a month. They only had around 900 miles on them. They lost my business. Called Brigstone they wouldnt take them back either. Finally sold them about 2 years later for 100.00 each. Brigstone / Firestone lost my business too.
I went to Rickson and purchased some 19.5 rims and some F load range 225 70 General drive tires for the rear and steer tires for the front. Not an issue since. Hoping these tires last the rest of my life.
  #19
Old 05-19-2010, 10:16 PM
AKB AKB is offline
AKB First On Race Day
Those wheels look awesome
  #20
Old 05-20-2010, 09:16 AM
Now for the exhaust. Thoughts were at first were 2.5" duals with a crossover or "X" pipe. There wasnt realy a lot of room for this with dual tanks. The is plenty of ground clearance but exhaust would be hanging a bit low. Looked at a lot of different turbo style mufflers but was realy wanting something rather quiet. Reasons one my ears have seen to much abuse over the years, not realy interested in a more powerful stereo. Big reason ever back up and not feel or hear your crunching something?
Talking to a few muffler shops they wanted to place both mufflers on the passenger side of the truck. Thought that was a bit lame. At this point thought it might work out best all around to find a dual inlet 2.5 muffler with a 3" single outlet. Most of the factory pipes could be retained. I love the look of duals out the back but this is a tow vehicle a big single should be fine. Serching once again found plenty of single inlet dual outlet mufflers.
Finaly looking through walkers stuff looked in the RV section. There was a ricently added muffler. It was dual inlet 2.5 single out 3". Called Walker and spoke with an engineer. He told me it was a direct for a factory Ford motor motor home chassis with a 460. He also stated that the factory muffler was about 8" of back pressure this muffler was only 1". So I ordered one.
  #21
Old 05-20-2010, 09:36 AM
how much is the muffler and the part number? I was thinking about using a 2.5 in y merge into a dynomax rv muffler 3" from jegs.
wayne
  #22
Old 05-20-2010, 11:24 PM
Well here is the muffler used all the existing factory pipes almost a bolt on. Thought it might be a water heater for an RV at first. Fuel economy didnt improve but power picked up. Its relitively quiet. Think the engine is having issues maybe some toasted valves from the original owner running 44* total advance. Guessing at this point an intake better than a Performer is needed. Also guessing the D3 heads still have the big lumps in the exhaust. All the real smoky diesels want to race me thinking mine is a diesel.
I will try to dig up the number. Been real busy trying to get my Merc ready for the car show at Ford World Headquartres and orientation day at Waterford race course the next day 30th and 31st
  #23
Old 05-21-2010, 01:55 PM
Here are the mufflers. I believe 21309 is the one that I used
http://www.walkerheavyduty.com/produ...osingleout.pdf
  #24
Old 05-21-2010, 02:14 PM
Next I began thinking about the heads. Purchased a 78 F150 with blown head gaskets and a sweet bed that was needed for my 78 F150. The bed on it split in half bringing the ZF trans home for the dually.
The heads were D3s the same as on my dually. Removed them and tore them down. I was shocked that the lumps for the EGR drillings were so huge. Couldnt eve stick my finger through the exhaust port. Without a head to cut up wasnt realy shure how the crossdrilling would look if they were removed. The drilling the length of the head's wall thickness also protruded into the roof of the port.
A friend I used to port heads with had a set of DOVE heads that had been kicking around the shop for about 10 years. They were off a jet boat. I purshased them and went to work.
  #25
Old 05-21-2010, 11:24 PM
Some shots of the heads. Originaly wanted to keep the stock 2.08 intakes but pitting common to the old 385 series heads left me with two options. Larger 2.19 valves or seats went with the larger valves. Exhaust was upped to 1.75s. Would realy have perfered 2.08 and 1.75 exhaust but I just happend to have 2.19s left over from a 351C build up.
  #26
Old 05-23-2010, 08:22 PM
The heads aree ready to assemble. Wish I could have flowed them but the bench has a burned up motor. Wont do a big block. About two years ago (purchased a set of Hooker Super Comp headers. Started to put them on but half the bolts snapped. Wasnt ready to do head swap at the time. The headers were made incorrectly. I sent them back to Hooker and 4 months later got the first set of corrected ones. I think their customer responce was perty good.
  #27
Old 05-23-2010, 09:04 PM
White Lightning's Avatar
Originally Posted by hookin78 View Post
Years ago Edelbrock used to make a intake they called a "Street Master" I think someone correct me if i am wrong, it had tiny runners that worked great for low end grunt and would help fuel economy, Can any one else add to this ?
Or is that intake something I dreamt up ????
You might be thinking about the Offenhauser "Dual Port".....
  #28
Old 05-24-2010, 06:39 PM
1lowet 1lowet is offline
1lowet Driving a Ford
Smile intake
Yes there was a holley street master ,Ihave one.
  #29
Old 06-07-2010, 04:38 PM
Have a few more valves to lap in. Painted the heads. Have been waiting 2 months for the correct retainers for the valve springs. I took some measurements with some retainers from a 302 but dont know if there + or - in position compaired to the correct ones.
  #30
Old 06-19-2010, 08:34 AM
StickBBF StickBBF is offline
StickBBF Driving a Ford
So did you get that valve job done?
Did you finally get your valve spring retainers?
Inquiring minds need to know...... <smile>
StickBBF
Insurance
Date of Birth
Month Day Year
Privacy
