budget 460's what did they run - 460 Ford Forum
Go Back   460 Ford Forum > Non-Tech Topics > Chilly's Garage
Old 10-08-2010, 10:49 PM
Jarred Hodges Jarred Hodges is offline
Jarred Hodges First On Race Day
Default budget 460's what did they run
I think I will be building a 460 for the maverick probaly next year if the billfold will let me. lol I have been looking on other sites and there as been some good running budget engines. My friend went a 6.98 in the 1/8 with a mild 460 cast flat tops, .575 lift hyd cam and ported d0ve heads. I have read of a bunch of similiar combos going 6.70's-7.30's in the 1/8. I was wondering what your budget 460's ran. thanks
Old 10-08-2010, 10:58 PM
Taxman's Avatar
Taxman Taxman is offline
Taxman First On Race Day
Very low cost 466 in my fox body. Pump gas, mild hyd cam (probably similar to the .575 in your friends), a bit of head work, headers, intake and holley 750 and best so far is 11.32 @ 117 (7.17 in the 8th). Should go a bit faster in better air. The key I think is the powerglide and 4.11 gears. With my 28" MT drag radials, I'm crossing the traps at a perfect 6200 rpm.
Old 10-09-2010, 08:15 AM
DaveMcLain DaveMcLain is offline
DaveMcLain Driving a Ford
Wes Littrell's cousin Shannon's '62 Ford pickup ran 6.60's at 100mph at the Big Ford Bash 1 with a low dollar 460 engine. It had KB-137 flat top pistons, home ported Dove heads, Victor intake and a Ford 514 crate engine roller cam(swap meet purchase).
I dyno tested the engine and it made 585 horsepower at 6000rpm with either a Ron's injection or a 1050 gas Dominator carburetor. He ran it in the truck on methanol with the Ron's setup.
Any sufficiently advanced technology is indistinguishable from magic --Arthur C. Clarke
Dave McLain
McLain's Automotive
Old 10-09-2010, 11:48 AM
460Skywalker 460Skywalker is offline
460Skywalker Driving a Ford
Buddys foxbody 466 with big valve dove heads ported with a small comp solid like 250dur. with a 850 annular,portosonic , non balanced, c4 went 6.49 at 106 with a spinning 1.43 60ft. it will be faster with new slicks.
Old 10-09-2010, 04:01 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
466,L2404 dishtops, .600ft solid cam, home ported dove heads, 2 660s on a tunnel ram, c4 fooot brake, 2800lbs w/driver, best of 6.17 @108.5, 9.78 @134.7, 60ft times low 1.30 to high 1.20s. Its fun to drive, and cheap to race with 93 octane pump gas. Gotta love them BBFs!!!
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
Old 10-15-2010, 10:42 PM
impressive. I hope mine will go high 6's na and high 5's on about a 200 shot
  #7
Old 10-15-2010, 11:16 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is online now
BOSS 429 Driving a Ford
whats the $$$$ fig on budget?
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
  #8
Old 10-15-2010, 11:45 PM
not really sure yet. It will vary how things go and so on. mainly looking for backyard combos, nothing with a $4000 rotating assembly or 5k heads
  #9
Old 10-16-2010, 01:25 PM
rmcomprandy Bleeding Blue
A "backyard" 466 should make anywhere in the area of 475 horsepower to 650 horsepower depending upon the talent of the individual doing the building of the combination.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
  #10
Old 10-19-2010, 05:01 PM
Tom McTernan's Avatar
Tom McTernan Tom McTernan is offline
Tom McTernan First On Race Day
If your planning on building a budget motor using the DOVE head castings keep it 460" to 466" (.030 overbore) and try to find a set of SCJ heads. Because of the location of the ports in the OEM castings you may end up disappointed if you try stroking it. Get the heads worked over the best you can $$$ and use at least an 850 CFM carb on either a Performer RPM or better manifold. Make sure the ports in the manifold are matched to the heads. If your planning on sticking with a 466" BBF, then consider playing with the rod ratios if you can afford to do so. Those heads with that size motor loves the longer connecting rods in it. If your in question about it, the 429 (3.59" stroke) and the 460
(3.85" stroke) use the same connecting rod. If you divide the 6.605" CtoC connecting rod length by the stroke, you'll come up with an 1.84 rod ratio for the 429 and a 1.72 for the 460. Using the same heads, the 460 has more torque, but runs out of cylinder head earlier. Keeping the 3.85 inch stroke and lengthening the connecting rod to say 6.940 would provide you with a 1.80 rod ratio. And guess what, the 6.940 length rod is the same as some of the old Chysler big blocks. Chysler uses a smaller rod bearing but a larger pin. With a little machining, it may very well work for you. I know because I tried it and it worked very well.
  #11
Old 10-19-2010, 08:28 PM
95lightiningguy 95lightiningguy is offline
95lightiningguy First On Race Day
Send a message via Yahoo to 95lightiningguy
Wouldn't it be cheaper to "0" deck the block, isnt that basically what you are trying to do with a longer rod. Not that I'm any hot shot engine builder but thats what it sounds like to me.
89 F150 351w powered
95 F150 300 I6 5 speed soon to be 460 powered lightining clone
  #12
Old 10-19-2010, 10:31 PM
Negative, running a .000 deck or .005 down in the hole simply reduces the volume for mechanical compression ratio calculation purposes. By playing with the rod ratio or L/R increases the dwell time at TDC and reduces the acceleration of the piston as it leaves TDC. It places less demand on the DOVE heads thus making the motor think it's got larger heads than it actually has. The longer rod with those less expensive heads causes the torque and horsepower curves to go up rather rapidly and flatten for an extended period throughout the RPM range and then drop slowly rather than going straight up and then straight down in a short period of time. Hey, I threw it out there for you. You can consider trying or not, the decision is yours. The only draw back is the cost if you pick up a custom one off set of rods and custom pistons with a special order pin location. I tried it and it worked for me. I wouldn't hesitate to go to the expense again.
  #13
Old 10-20-2010, 12:17 AM
res0rli9 res0rli9 is offline
res0rli9 Driving a Ford
Tom, thanks for this info. is there a shelf piston that will go with the Chysler rod, like another manufactures piston?? non custom.
Would like to invite you to check out the http://www.429-460.com form also. Your knowledge would be very welcome over there to.
Kieth
  #14
Old 10-20-2010, 07:56 AM
White Lightning's Avatar
Tom, does the same theory work for larger bore/stroke/ larger CFM heads? Longer rods would still give you longer dwell time/slower acceleration/deceleration piston speeds @TDC/BDC? How long of a piston skirt does that type of combo like? Say if you wanted a 557" target cube, what would be the ideal bore/stroke/rod length/head CFM/RPM numbers?
Rob
  #15
Old 10-20-2010, 08:32 AM
I thank a 460-466 long rod deal would also make a great engine for a street pickup and off and on towing and maybe get better gas mileage.
or a 501 seeing how you'd have to turn turn the crank for the Chysler rod anyway.
Insurance
Date of Birth
Month Day Year
Privacy
