460 into a 1969 torino - 460 Ford Forum
Old 10-10-2010, 08:41 AM
jtgb428 jtgb428 is offline
jtgb428 Driving a Ford
Send a message via Yahoo to jtgb428
Default 460 into a 1969 torino
hey guys, jim here. i thought that dropping in a 460 into my 69 torino would be a fairly easy and senseable swap. my car has a 390 in it now so it is baically set up for a big block. i have more people telling me not to do it than i have people telling me to do it. here are some examples-to heavy of an engine, i wont like the way it handles and goes down the road, motor mount issues, fabrication to the tranny tunnel, numerous things under the hood that have to be moved around to make room for the engine, etc,etc. i know you guys are running 460s in your 68-69 torinos and fairlanes so please tell me what im up against with this swap. my torino is a street car, it is not all original by any means so pulling the 390 is no big deal. im not worried about handeling because as i said it is basically a street car. if i am opening up a can of worms let me know. thanks, jim.
i live for muscle cars,they are all special in their own right.i love the ford and mercury muscle cars of the 60s.i own a 69 mercury cougar and a 69 torino fastback.
Old 10-10-2010, 04:28 PM
Tim1859 Tim1859 is offline
Tim1859 Driving a Ford
These might help:
http://www.torinocobra.com/forum/viewtopic.php?t=8021
http://www.torinocobra.com/forum/viewtopic.php?t=1262
Old 10-10-2010, 10:30 PM
Bruce Wilkie Bruce Wilkie is offline
Bruce Wilkie Driving a Ford
The engine bays really arent terribly different in a 66-69 fairlane/torino than a 70-71 fairlane/torino. Tight fit yes, but plenty of 429/460's get swapped into these cars. There are several I've seen around here on cruise nights/shows and never heard anyone complain. Sure looks identical to my 71 Torino and the 460 fits just fine. (even with 2.125" headers though a bit of a pain to install them) Wish I had pics of when I had my 528 motor mocked into place in my 71.
IIRC the 390 is at least as heavy if not heavier than a 460. The trans tunnel clears a c6 so I dont see where that could be an issue. Maybe with Boss heads there may be an issue with power brake booster clearance? Stock radiator hose positions are the only thing I can think might be different. You need a front sump pan. 70-71 429 motor mounts should fit. 70-71 Torino Hooker Super Comp 429/460 headers fit 69 Mustangs I dont see where they wouldnt fit a 69 Torino as well. Sure only relatively minor mods if they didnt.
My 2 cents I think others wish they had a 460 vs their little 289/302/351 in their Torino and are either jealous or misinformed.
Get that 460 in there!
Old 10-12-2010, 01:02 AM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
ive done this more then once, same eng bay as 70 71 torino , no firewall work needs done,
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 10-12-2010, 07:48 AM
radir68 radir68 is offline
radir68 Driving a Ford
This is a great swap. The power brake booster fits with stock valve covers, trans fits (c6) in the tunnel. Worst part is changing plugs. The shock towers are really close. The rad is to fan clearance is tight but works. I used the crites swap parts in mine. I would go for it. Have fun.
68 torino 460 etc..
Old 10-12-2010, 08:10 AM
fordmonsta fordmonsta is offline
fordmonsta Driving a Ford
Send a message via Yahoo to fordmonsta
i did my 68 a few year ago, made my own mounts but apparently they must have been real close to what crites makes because their headers fit good after teh fact, all said and done it is an easy swap, if i did it all over again i'd just go with the right stuff rather than making it all, but like said before, the shock towers are a pain, i ended up notching mine back and plating them in and that helped get header bolts in and spark plugs were fairly easy at that point, wish i'd have kept tha car, sold it about year and a half ago
  #7
Old 10-12-2010, 11:05 PM
19mach69's Avatar
19mach69 19mach69 is offline
19mach69 Driving a Ford
If I remember right the 66 and up Falcon has the same engine bay as the Torino. My 460 dropped right in with no problems. When I get the headers in I can see it potentially making it harder to change spark plugs. I got my motor mounts from crites and it installed easily.
1966 Falcon
1969 Mustang Mach 1
1970 Dodge Charger R/T
  #8
Old 10-27-2010, 01:46 PM
Flip Flip is offline
Flip First On Race Day
Fits like a charm. I've dropped a 429scj into a 68 fairlane and I have a 460 in my 1966 fairlane.
From what I've heard the difference in weight is around 70lbs. But that's assuming cast just about everything on both motors. Replacing the intake with aluminum just about evens that out.
Here are some pics of my '66 the engine is tight but I've done zero mods to the engine compartment. I'm planning on hacking out the shock towers next time I pull the motor just for the hell of it.
I definitely advise relocation on the oil filter as seen here:
Going to a fiberglass hood will drop about 50lbs too:
I run a perma cool electric fan set to push. it was too tight of a fit to make it work in a pulling fashion:
The fit looks a lit tighter then it really is, but that's part of what makes the swap badass IMHO:
As far as handling goes? It doesn't drive any different then any '66 out there with a 390. It's some weight up front, but with the weight saving features (fiberglass fenders/hood, aluminum intake, headers that weigh less then the heavy cast manifolds...) I'm actually lighter then I was with the 390 in the car.
I have a ton more pics too, if you want to see them just let me know.
  #9
Old 10-27-2010, 10:22 PM
bigblockfairlane bigblockfairlane is offline
bigblockfairlane First On Race Day
Default valve covers
hey flip curious about motorsport valve covers won`t clear master cyl.on my 66fairlane or was that a pic of your 68 engine bay. Bill
  #10
Old 02-20-2014, 09:48 AM
Slow Poke Slow Poke is offline
Slow Poke First On Race Day
I'm about to embark on my own 429 swap into my '69 F code Torino. I'm so excited! This forum has given me a lot to go off of and I think I have a pretty good idea of what's in store. Thanks to all of you that have posted; if you have anymore tips or tricks I'm all ears! Anything I should be on the look out for? That maybe wasn't covered in these swap talks?
Insurance
Date of Birth
Month Day Year
Privacy
