HELP 1988 Ford F-250 460EFI burning way too rich - 460 Ford Forum
Old 01-10-2011, 06:56 PM
88460EFI 88460EFI is offline
88460EFI First On Race Day
Default HELP 1988 Ford F-250 460EFI burning way too rich
I need some help on my 88 F-250 Ford 460 with EFI. I recently brought it in because it wouldn't start after someone left the key on in it. The computer was fried so he put a new computer in. When I picked it up it topped out at 30, barely made it up small hills, ran really rough and was puffing black smoke the whole way. It took almost 5 gallons and the drive was only 7 miles. Every once in a while it would start running right but when you would hit a bump it would go back to burning really rich. I don't know what is wrong so I figured I would ask you guys for some ideas on what might be wrong. Thankyou
Old 01-10-2011, 07:59 PM
63bird390 63bird390 is offline
63bird390 Driving a Ford
Default running rich efi 460
things to check check for
vacuume leaks on intake. get a pressure guage and see how much you have 17-22 is the norm for a stock engine. and if its steady or fluxing all over. make sure there is no cracked lines.
map sensor (if its bad the truck will run bad or not at all)
oxygen sensor
air intake sensor (on intake close to the distrubitor)
coolant temp sensor (on intake as well towar the back driver side)
TFI moduel those can be checked at the local autoparts store
possible not likely IAC ( idle air control valve) can affect it while cold but not so much when the the engine is hot.
either way the eec is getting a bad signal from above or massive vaccume leaks. which tells the eec to lengthen the injector duty cycle. hope this helps.
Old 01-10-2011, 08:56 PM
Elmore Racing Elmore Racing is offline
Elmore Racing First On Race Day
fuel preasure regulator could be bad - pull vaccum line off when running and see if gas comes out of reg.
Old 01-11-2011, 09:13 AM
bigblok86ranger's Avatar
Super Moderator
I would check TFI module and fuel pressure regulator as they seem most likely. I would swap the TFI with a known good one as I went through similar issue with an 86 F150 last year and the module tested fine so I put a new computer in it and still did the same thing, got mad after spending the money on a new computer and pulled a TFI off a spare distributor I had and solved the problem.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
Old 01-11-2011, 09:24 AM
lowranger lowranger is offline
lowranger First On Race Day
My vote is for the map sensor and check the fuel pressure.
Old 04-09-2011, 10:01 PM
where is the fuel pressure regulator?
  #7
Old 04-10-2011, 12:18 AM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
X2, or the E.C.T. Sensor is bad (engine coolant temp) stuck to the cold side.
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
  #8
Old 04-10-2011, 10:22 AM
I replaced the MAP sensor and that didn't help at all. Should I try the fuel pressure regulator next?
  #9
Old 04-10-2011, 10:36 PM
Pull the vacuum line off of it when the engine is running, and see if there is fuel coming out of it.
  #10
Old 04-11-2011, 02:51 PM
429TORQ 429TORQ is offline
429TORQ First On Race Day
What about PIP(profile ignition pickup)? I think it's otherwise known as the pickup coil by most people. When I get issues like this I do diagnostics the hard way because I do not have a scan tool.
#1- I check for proper charging system voltage at the battery
#2- I check the engine vacuum, compression, and general engine condition.
#3- I check the power and ground supplies to the ECM
#4- I check EVERY SINGLE ECM input at the ECM AND at the sensor(tps, iac, egr, o2, map, ect, etc.). This method also checks the wiring between the sensors and ecm if you compare the readings at the ecm to the readings at the sensors. I also determine whether the sensors are bad OR reporting incorrectly because the mechanical element they are measuring is messed up.
The ECM is considered faulty after all of the above has been tested and found to be good.
Aww shoot, I'm getting back in the game again...
  #11
Old 04-11-2011, 03:15 PM
crittersf1's Avatar
crittersf1 Driving a Ford
Most likely ECT or pressure regulator.
  #12
Old 04-11-2011, 06:15 PM
turbo2256b First On Race Day
Possibly the wrong ECM (possibly misslabled if a flashed one
) or a bad one. Worst fuel issues are most likely a bad thermostat.
Insurance
Date of Birth
Month Day Year
Privacy
