Push rod length - 460 Ford Forum
Old 03-19-2011, 05:33 PM
Big Block Capri Big Block Capri is offline
Big Block Capri First On Race Day
Default Push rod length
Just set my new Super Cobra Jet A heads on the block to check things out. My push rods are too short (8.780 for my DOVE heads). I'm using Comp Cams aluminum roller rockers 1.73 ratio. Any help would be GREATLY appreciated.
Thanks,
Paul
Old 03-19-2011, 06:16 PM
DJW-Racing's Avatar
DJW-Racing DJW-Racing is offline
DJW-Racing First On Race Day
Send a message via MSN to DJW-Racing
Uh, longer push rods?
1966 Mercury M-100
1976 Ford F250 4x4
Old 03-19-2011, 06:33 PM
White Lightning's Avatar
White Lightning White Lightning is online now
What cam have you got?
Rob
Old 03-19-2011, 07:51 PM
Its Comp Cams 34-653-5 solid mechanical. Duration 270 I, 276 E @.050. Lift .649 I, .642 E. Ground on a 108 centerline.
THX
Old 03-19-2011, 07:53 PM
DJOHAGIN's Avatar
DJOHAGIN DJOHAGIN is offline
DJOHAGIN Driving a Ford
Thanks,
Paul
http://www.460ford.com/forum/showthread.php?t=152377
http://www.460ford.com/forum/showthread.php?t=141907
There's some help.
Dave
Old 03-19-2011, 09:24 PM
LOL, That ought to keep him busy for a few minutes! lol HAD to include the first one didn't ya Dave.....
Rob
  #7
Old 03-19-2011, 09:30 PM
crittersf1's Avatar
crittersf1 Driving a Ford
Well what do you know? Dave is a comedian too!
  #8
Old 03-19-2011, 09:50 PM
Lololol
  #9
Old 03-19-2011, 09:56 PM
Not so quick boys...I'd already read the first one. Old and Canadian don't necessarily mean stupid! I was looking for a definitive answer and may have found one. Would 9.150 intake and 8.950 exhaust make reasonable sense?
Paul
  #10
Old 03-19-2011, 10:05 PM
Each combination is going to be a little different. What would make sense would be to buy a push rod length checker and determine EXACTLY what length push rod your particular combo needs.
Rob
  #11
Old 03-19-2011, 10:11 PM
crittersf1's Avatar
Measure, measure then measure again. Just to be sure!
  #12
Old 03-19-2011, 10:12 PM
crittersf1's Avatar
Measure, measure then measure again. Just to be sure! Don't guess and don't go by somebody elses combination.
  #13
Old 03-19-2011, 10:15 PM
t120r t120r is offline
t120r Driving a Ford
Send a message via ICQ to t120r Send a message via MSN to t120r
What would be the correct pushrod checking tool for the scj heads??
T120r
  #14
Old 03-19-2011, 10:16 PM
Measure it will be. Thanks guys. I will probably make my own and it will go from 8.750 to 9.250
Paul
  #15
Old 03-19-2011, 10:37 PM
customblackbird's Avatar
customblackbird customblackbird is offline
customblackbird First On Race Day
i used a JEGS aluminum 3/8" DIA pushrod with 5/16" ends. It was adjustable from 8-9.170" i believe. You only need one and it was cheap. however you will need a 12" caliper to measure the length. I believe the comp cams and trickflow ones have measurements on the actually adjustable pushrod. that way you dont need the 12" caliper for the end measurement.
