milling heads for compression - 460 Ford Forum
Old 04-19-2011, 03:48 PM
83cougar460 83cougar460 is offline
83cougar460 First On Race Day
Default milling heads for compression
I've recently converted over to e85, and was thinking I would like to up the compression to take advantage of the fuel. With my c8ve heads and speed-pro flattops, the compression calc comes out to around 10.75:1. Anyone know how much can be safely machined and how much it would raise compression? I realize I will have to have the intake milled as well. Thanks.
83 cougar 466/c6/8.8 3.73s
73 torino gts/351c/c4
54 ford/390/c6
Old 04-19-2011, 04:49 PM
2slow 2slow is offline
2slow Driving a Ford
to me any cut over .040" your pushing the the gasket sealing . that would be around 6 to 7 cc's less
Old 04-19-2011, 05:40 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
The speed pro pistons have a short compression height and usually sit a significant amount below deck.
A flat top piston in a 460 at 0 deck will net about 11.7 to 1. You will at best gain .5 point by decking the heads where there is much more to be gained by 0 decking the block in addition to the increased squish effect.
How far below deck are your pistons now?
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 04-19-2011, 06:06 PM
I figured zero decking the block was better, however the engine is in the car, and since I have the intake off to do some work, I was thinking of pulling off the heads as well. However, if only a .5 a point is to be gained, I probably will not do it. I used a feeler gauge to measure how far down in the hole the pistons are when I assembled the engine, but I don't remember now. I do remember it seemed like quite a bit. Scott, you've got PM.
54 ford/390/c6
Old 04-20-2011, 01:36 PM
Cool
PM answered...
S
Custom ground cams
http://R-H-P.biz
