Project 12.99 LTD finally... - 460 Ford Forum
Old 08-03-2011, 11:38 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Talking Project 12.99 LTD finally...
Well after selling off 3 engines I have built for this car I am finally going to install a big block in her.
I had a 70K mile unmolested C9 lincoln 460 which was essentially a good runner with no bore wear or inappropriate wear anywhere excepting the timing set which still had the nylon teeth on the cam gear. Decided to build an engine with parts lying around the shop so here is what I have"
Block decked .012" to set pistons .002 out of the bore
Stock C9 pistons with 11 cc dish. Will notch for large valves.
Reringed and a quick hone to freshen the straight cylinder bores.
Polished crank and select fit .001" clevite bearings
Paul Kane modded std volume oil pump.
Voodoo cam 219/227 on a 110 with mid 500" s lift ground with 4 degrees advance. Installed 1 degree advanced to 105 ICL. (Cam and lifter set free courtesy of my cam grinder.)
1.8 ratio comp high teck stainless roller rockers for .560" / .582" final lift
RPM intake gasket matched to felpro std gasket.
Edelbrock large chamber heads fully ported concentrating on good flow under .600" lift, decked .060" and .030" off of the intake side. 10.1 to 1 final C/R with an 8.8 to 1 DCR. (Thank you for the good deal Dave Ohagin) 330/233 cfm @ .600" lift. Squish grooves.
Holley 750 reworked by bobby at competition carbs. choke tower removed, rear metering block added, emulsion circuits reworked, air bleeds set up for this combo, quick change vac sec dashpot cover. Flows 820 cfm with down leg boosters that have been massaged and have a shear ledge.
Summit high volume mechanical fuel pump. Vehicle has 3/8" fuel lines and a 5/16" return
Dual snorkle 5.0 HO aircleaner with K&N filter ducted to cool air on sides of radiator.
Headers TBD either 6126 hookers or FPA headers.
3" X pipe and magnaflows with 2.5" tail pipes
B&M holeshot 2400 stall convertor purchased from a forum member thank you Andy M!!! Killer deal.
3.25 or 3.5 gears with trak loc. Already have 2.75 trak loc 9" now just need to change gears.
With a full iron 400 and a/c she weighed 4320 pounds. Should come in at around 4150 with all a/c removed and the aluminum heads, intake and water pump on the 460.
I am going to conservatively estimate HP at 460 and torque at 510.
I may change the cam to an EX solid flat tappet 230/236 @ .050 .584" / .600" lift ground again on a 110 because of the 1.8 rockers. would be 109 with std rockers.
The idea as the name states is to run 12.99 at about 105+ mph. Traction will be a huge problem I know...
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 08-04-2011, 12:35 AM
hookin78's Avatar
hookin78 hookin78 is offline
hookin78 First On Race Day
very nice.... clean car. at least once are you going to drive around with a cane and a purple pimp hat ??
Just kiddin....... should be a nice sleeper.
Brandon
Old 08-04-2011, 01:47 AM
mudbogtom's Avatar
mudbogtom mudbogtom is offline
mudbogtom Driving a Ford
Send a message via Yahoo to mudbogtom
If you meet these goals, both Carl and I will be extremely happy, but I will need some safety equipment... ZephyrBob... not so happy. The Hooker 6126s will be cake if you have the time to fab up a trans crossmember... no big deal really, as I did it, without major issues. No cutting the $$$ Hookers.
Soon to be powered by...
www.carsbycarl.com
Old 08-04-2011, 02:29 AM
mxb mxb is offline
mxb First On Race Day
Default ltd times
it'll run faster than that with a decent gear.3;73 or up
Old 08-04-2011, 12:15 PM
Cool
Brandon
Lol wise a$$.. It is supposed to be a streets of san francisco detective clone or hawaii 5 0 detective car.
Already done the pimp thing my brotha......
Custom ground cams
http://R-H-P.biz
Old 08-04-2011, 02:52 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
Should be a fun driver no matter what number it runs.
  #7
Old 08-04-2011, 03:59 PM
Cool
I have decided to pull the voodoo hydraulic cam and install an Extreem energy solid.
230 intake / 236 exhaust 110 LSA +4
.587" lift intake
.603" lift exhaust
Power band will be similar but the solid will add additional power and torque plus better RPM capability to utilise the ported heads and intake tract flow.
Carl I agree regardless of track times it will be fun. The tweeked 400 would go sideways from a dead stomp.
Custom ground cams
http://R-H-P.biz
  #8
Old 08-04-2011, 04:54 PM
Dirtybird545 Dirtybird545 is offline
Dirtybird545 Driving a Ford
Scotty I think you're my new personal hero!LOL
I had a 74 LTD with a 460 and always wanted to attempt what you're doing.Mines been gone for 26yrs and I still miss it.
Good luck and keep us posted,
Russ
P.S.,
Let us know if you need any advice breaking in that new cam....LOL
  #9
Old 08-04-2011, 05:02 PM
CarsByCarl's Avatar
.587" lift intake
.603" lift exhaust
Awwwwww, come on. Wouldn't you rather run the number with a smooth idling "peanut cam"?
Given the converter and gear, more cam might actually make it slower.
  #10
Old 08-04-2011, 07:09 PM
Cool
Given the need to increase duration to compensate from going to solid from juice the cam really is not that much larger.
The 224/230 xs262 s has almost identical opening and closing events at .015 and .050" lifter rise.
I'm just looking for comparable opening and closing events but with a solid flat tappet which will make more power in the same operating range.
The slightly smaller cam might be the better ticket. I will have to think on this for a bit.
Custom ground cams
http://R-H-P.biz
  #11
Old 08-05-2011, 01:13 AM
Mark Miller Mark Miller is offline
Mark Miller Driving a Ford
Scotty,i think a 12.99 in the 1/4 mile shouldn't be a problem with that combo with a 3.50 gear.I ran a 13.26 at 100 mph with a 4,420 lb. with driver 1978 LTDII,466,Dove-C Heads,Weiand Steath Intake,850 Holley DP,Lunati Cam .554-.554 lift 230-230 duration at 0.50,Hooker 6126 Headers,C-4 TCI 10" converter,3.70 gears,M-H Sticky tires,3" exhaust with Flowmaster mufflers.The 13.26 at 100 mph pass was thru the mufflers on the M-H tires.
Later Mark.
  #12
Old 08-06-2011, 12:07 AM
Cool
Its funny how things work out sometimes. I was going to utilise the eddy heads because I had them there at the shop having gotten them for a good price. Not my first choice but never the less I have them flowing 340 cfm @ .600 lift.
I sold them today to a client that wanted them for his own project and they are a perfect fit for him. I managed to get enough out of them to buy a pair of SCJ-A heads from lem so the recipe is going to change a bit. Thank god I have not decked them yet.
I will now be using the SCJ heads instead. I will notch the pistons to accomodate the different valve locations and add enough volume to get a final static c/r of 10.5 to 1. Given the highly efficient nature of the scj chambers I feel that this will actuall be of benefit as the cross section of the eddy heads and the SCJ's are very similar. I can port the scj's to flow 370 at .560" lift with little more than some tweeking at the short turn walls. IMHO a much better cylinder head that will out power and out torque the eddy heads any day of the week.
Still debating a cam change to a commensurate solid flat tappet with very similar timing events to the cam I have outlined originally. Looking to build a fun driver that has some real balls but appears subtle until you hit the loud pedal.
I now have a set of heads that will support a stroker if needed at some time in the future but are also a good fit for what I am doing now.
S
Custom ground cams
http://R-H-P.biz
  #13
Old 08-06-2011, 12:26 AM
tfsbbf466 tfsbbf466 is offline
tfsbbf466 Driving a Ford
I went a best of 12.04 with consistent 12.1s with ported D0VEs, 3000 converter, XE284H cam, 3.70s, 1 7/8 with full 3" exhaust, mismatched victor, and a 850dp. The truck weighed 4150 at the time. Its now in my dads 95 F150 with a stealth, 750dp, 3.55s power everything, cold a/c and has been 12.51. His truck weights 42-4300lbs.
  #14
Old 08-06-2011, 12:45 AM
Cool
As long as she will break into the 12's in stealth mode I will be more than happy...
The power will be there it is going to be more a matter of hooking it up...
I want to be very stealthy and then unleash the beast.
Custom ground cams
http://R-H-P.biz
  #15
Old 08-06-2011, 04:13 PM
cletus66's Avatar
cletus66 cletus66 is offline
cletus66 Driving a Ford
Cool project. Keep us posted.
Where's my beer and that half inch wrench?
http://i168.photobucket.com/albums/u...cecar066-1.jpg
