Project 12.99 LTD finally... - Page 22 - 460 Ford Forum
  #316
Old 04-03-2014, 04:56 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
Originally Posted by xoliex View Post
well, are the bars fully in yet?
Rear trailing arm kit installed. Waiting for sway bar spacers.
Pinion angle set at 1.5 neg
New 26056 Beehive springs installed at 1.800"
Pulls like a freight train to 6300
950 hp carb re-jetted to 77/87 with 35 IFR's and 70 IAB's From 79 / 90
FAST A/F reads 12.8 to 13.1 at WOT VS 12.3 to 12.5
Feels better a tad leaner.
S
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 04-03-2014, 05:27 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is online now
I can't wait to see what it does when you get to the track. This has been one of my favorite build threads to pay attention to. Keep us posted.
  #318
Old 04-03-2014, 05:34 PM
mp40's Avatar
mp40 mp40 is offline
mp40 Driving a Ford
I too, have been following this thread intently.
Trying to launch several tons of steel like a Saturn 5!
1967 Mustang coupe, Mustang II front suspension. W/RV camed, D3VE headed, 460/C6 (soon to be 557 CID w/ported police interceptor heads) out of the box BBC headers(with homemade steel adapters)
Shocktower removal enthusiast.
The race is not over till the Fat Block Ford Sings!
FBHO
  #319
Old 04-04-2014, 03:34 PM
xoliex xoliex is offline
xoliex First On Race Day
Talking
S
I'm interested in the beehive spring set up!
12.8-13.1 AF at WOT? That's where my WOT was when i initially put my timing to 30 total but it also touched at 13.2 at 6100rpms. so i put #1 on both primary and secondary to try to keep it under 13.0 the whole range.
  #320
Old 04-05-2014, 12:52 AM
Cool
The track and chassis dyno will tell what AF is best. Seems that there is consensus building that modern fast burn chambers do not need as rich an AF ratio as older less efficient chamber designs.
S
Custom ground cams
http://R-H-P.biz
  #321
Old 04-05-2014, 06:03 AM
TommyK TommyK is offline
TommyK Driving a Ford
S
A "Don't try this at home, kids!" disclaimer might apply here. Yours is a carefully planned and executed build that purposely pushes the envelope for pump gas. Part of that process was special attention to cylinder distribution. For the average Joe using a single O/2 sensor reading the average A/F ratio for one bank, I think the generally recommended "safe" range of 12.5 to 12.8 still applies. Running an average 13+ at WOT could see the leanest cylinder(s) in the danger zone on a less than optimized combo.
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.50 trac lock
  #322
Old 04-05-2014, 01:11 PM
Cool
You make a valid point.
My post applies to the SCJ and P-51 chambers only. I specifically stated "modern fast burn" chambers. All of the other offerings for the BBF today are variations of the original bath tub chamber design and as such the 12.5 ish range would apply. In the end trap speed and chassis dyno numbers while keeping an eye on the wide band are going to tell you what your particular combo likes best or needs...
XolieX found that as he moved AF from the low 12's to the 12.8's he picked up 25 hp or more on the chassis dyno. He has an RHP SCJ headed 521.
I should have qualified the statement in that the A/F's were in the high 12's touching 13/1 to 1 at one point not staying above or in the 13's through out several acceleration runs...
More on this:
http://www.carcraft.com/techarticles...l_ratio_meter/
http://www.bristoldyno.com/tech/airfuel.htm
S
Custom ground cams
http://R-H-P.biz
  #323
Old 04-27-2014, 12:00 AM
Wpginterceptor Wpginterceptor is offline
Wpginterceptor First On Race Day
Im waitin patiently to Scotty..
PS: my big ford came with factory sway bars
  #324
Old 04-28-2014, 10:09 AM
68galaxie500 68galaxie500 is offline
68galaxie500 First On Race Day
Very cool build!!!
I am waiting to see how the PMT trailing arm kit works out.
I would love to see installation pics as well.
I would like to add that kit to the rear of my 68 Galaxie with 501" BBF.
Drag radials do not hook up well until 3rd gear.
Cheers
  #325
Old 04-28-2014, 03:53 PM
ok scotty, when's the next track day out there in WA?
  #326
Old 05-10-2014, 10:42 PM
Cool
Getting there slow but sure. The ram air set up took all afternoon to set up right...
S
  #327
Old 05-13-2014, 03:54 PM
torino501 torino501 is online now
torino501 Driving a Ford
THATS A LOT OF BIG SEXY RIGHT THERE...!!! EXCEPT FOR THE KITTY PRINTS ON THE FENDER. I LOVE MY CATS N ALL BUT DAMN...
  #328
Old 05-14-2014, 04:18 PM
429TORQ 429TORQ is offline
429TORQ First On Race Day
Nice intake setup...
I think that the 80's dual-snorkel mustang air cleaners that we were using are restrictive for engines of your caliber(mine is, and it is a much milder engine).
I left a rag in the inner fender well of mine probably 6-8" away from the opening of the corresponding hose on that side and the engine sucked it right up and had it plastered against the outside of the air cleaner element! lol
Aww shoot, I'm getting back in the game again...
  #329
Old 05-15-2014, 12:07 AM
Cool
My 5.0 HO air cleaner housing with K&N filter cost 8 HP on the engine dyno. Not too bad considering the small size of the filter.
S
Kitty prints on the hood too. Just after I washed it too. Damn neighbors leaving their cats out...
S
Custom ground cams
http://R-H-P.biz
  #330
Old 05-15-2014, 07:08 AM
nickbay's Avatar
nickbay nickbay is offline
nickbay Driving a Ford
Looks great, can't wait to see what it runs.
It's surprising to me that it loses 8 hp with the air cleaner setup.
I wonder what it would be with the filter out but still using the cold air setup.
Even though it may lose some hp on the dyno, it's possible it will still run quicker with the setup connected.
67 mustang street car, 1977 460, 212 degree cam, 2500 converter, 3.50 gears, RHP Edelbrock heads
best ET 12.01, mph 112.98, 60ft 1.69
http://www.youtube.com/watch?v=7HztIgJymNw
http://s212.photobucket.com/albums/cc110/laveennick/
