Project 12.99 LTD finally... - Page 3 - 460 Ford Forum
  #31
Old 09-19-2011, 02:25 AM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
Finalised my ports this afternoon.
Here is a pic of the intake ports final shape. I am not interested in making the damned thing pretty just functional.
2.200" intake / 1.760" exhaust. Intake back cut 29 degrees .088" wide.
.200" 104 / 163
.300" 147 / 250
.400" 183 / 302
.500" 213 / 337
.570" ..... / 353
.600" 234 /
Valve lift is .562" / .575" with the 1.8 ratio comp high tech stainless rockers
The SCJ's go turbulent just under 600" lift with an untouched short turn and I left the intake short turn radii alone because I want very strong low and mid lift flow rates. These flow rates were achieved with minimal increase in intake port cross sectional area to keep port velocity as high as possible. More flow is available with more cross section and a larger bowl however I dont feel it appropriate for this build.
There is enough intake flow to support well over 700 HP... Far more flow than needed however the cam will peak higher because of the fat intake flow curve...
File Type: jpg 1299 LTD SCJ-A Intake port 353_.570.jpg (90.0 KB, 241 views)
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 09-19-2011, 07:29 AM
Price5113 Price5113 is offline
Price5113 First On Race Day
Default Traction?????
Hey Scotty, do you have any ideas on what your going to do about traction aide-aides on the LTD? Steve.............
  #33
Old 09-19-2011, 11:26 AM
Cool
Given the full size nature of the beast I do not have many options. I have contemplated getting the lower trailing arms boxed, 90/10 shocks for the front for the track and loosening or removing the sway bar for weight transfer.
She has a K code 2.75 9" trak lok in her now. Looking for a 3.25 or 3.50 center section at present.
Any thoughts on this subject are welcome.
Custom ground cams
http://R-H-P.biz
  #34
Old 09-19-2011, 01:17 PM
Default Traction thoughts...........
Scotty, what I found in my past experience with another 73LTD Combo simular to yours that rear shocks & springs were more beneficial than anything else I did to get the car to hook. When I get home this evening I will get the part # of the Rancho RS9000 shocks for the rear. I also used a NEW replacement set of Moog coil springs that I cut down for the rear, and adj. the pinion angle to NEG 4* as I recall. I disconnected the frt sway bar and used Koni SPA1 adj front shocks along with NEW replacement Moog Big Block springs as well. The Trac Loc I used grenaded after a VERY short time. It was a REMAN 31spl version. A spool was used from there after with good results. With 275/60-15 BFG Drag Radials the car would 60ft in the high 1.7's-low 1.8's. This was with 4.11 gears and a 10.1 472 C6(9.5" converter) combo. The car weighed in at 4560lbs with me aboard. Boxing the lwr c/arms would be wise, as I noticed some deformation with mine. Steve..........................
  #35
Old 09-20-2011, 12:55 AM
mudbogtom's Avatar
mudbogtom mudbogtom is offline
mudbogtom Driving a Ford
Send a message via Yahoo to mudbogtom
Maybe with some other mods, removing the front sway bar would be acceptable, but in stock mode, only removing that front bar creates a poor handling ride on the street. My 70 Wagon handles like crap without it, and it isn't just a matter of getting used to it... the body roll going around a turn even at very low speeds is crazy. A blowout at highway speeds would be a nightmare, imo. I do agree that improving the rear suspension would be the place to start.
Tom
Soon to be powered by...
www.carsbycarl.com
  #36
Old 09-20-2011, 09:45 AM
bob460 bob460 is offline
bob460 First On Race Day
Anyone run a stabiliser bar in thr rear end. We have a guy down here running 9.6 at 141mph in a 3500lb falcon on m/t radials. He runs a leaf spring rear end and the stabiliser bar ( no 4 link, 2 link or caltracs). It lifts the front even ever run. This is the set up im looking to do for my car just wondering if anyone else has used or tried it. Cheers, Bob
  #37
Old 09-20-2011, 01:08 PM
Default Rear Sway Bar
Great point! I know of a lot of GM "A" bodys out here that swear by using a rear sway bar on their drag cars. Really seems to help more so on the coil sprung rear cars. I have not seen or heard much about using a sway bar on the rear of a leaf car, although I have seen more than one NHRA Stock eliminator car with a track bar on the rear of a leaf car................
  #38
Old 09-24-2011, 12:55 AM
Cool
After fighting with my flow bench for several days because of a calibration error that seemed to appear at the higher flow rates I have some revised figures for the SCJ-A castings. Checked some stock doves to verify that the bench is not happy and several out of the box pairs of aluminum heads which were coming up short which is what clued me into the potential issue... any way...
.200" 165 cfm
.300" 260
.400" 320
.500" 360
.570" 376
Pretty typical flow rates for the type of work done. Bowl blend. right side wall opened as well as the bowl itself on the same side. 29 degree back cut .088" wide.
Exhaust numbers remain unchanged. Funny that the error did not affect the exhaust numbers...
Far more flow than the combo needs however this will help the combo hold on after the cam has peaked...
Custom ground cams
http://R-H-P.biz
  #39
Old 11-18-2011, 11:18 AM
Cool Some additional pics... Getting real close just down to the details...
All of the big stuff is done.
Engine ready excepting final finishing on the heads.
Engine bay ready, power steering pump redone.
Now it is really a matter of getting the final details addressed and installing the engine.
Ordered and have received Summit 2.5" X pipe kit, walker dynomax ultra mufflers and a nice low key tach for the steering wheel.
Also have a set of 3.50 gears, a trak lok etc. now to get the third member done...
Custom ground cams
http://R-H-P.biz
  #40
Old 11-20-2011, 09:00 AM
torinojoe1971 torinojoe1971 is offline
torinojoe1971 Driving a Ford
Default 12s
Scott I think your set up should run some where between mid 11s to low 12s. I have a 71 cobra torino, car weighs 4000lbs, I had a 429 30 over in it, cj heads stock ports solid cam with 280 duration 615 lift, 11.3.1 comp, 2 inch headers into 2 1/2 straight exhaust in to mufflers, stealth intake, 850 double pumper. c6 3000 stahll converter, 411 gears 9 inch traction lock with slapper bars on the leaf springs. I had the front sway bar still attached. The car would run consist 12.9s all day, I feel with some tuning the car would have run 12.5s but a lobed wipped out. With your set up and knowledge you should be in my oppion be at least be in the high 11s. looking foward to see what she runs Joe.
  #41
Old 11-20-2011, 10:05 AM
cletus66's Avatar
cletus66 cletus66 is offline
cletus66 Driving a Ford
Have you done anything to the transmission? I remember about 20 years ago, a customer at the parts store had a big LTD with a built 460, and he had trouble with the high gear band. There was a transmission shop behind our store, and he welded something to keep it together. Kinda vague, I know, just something from the foggy memories.......
Where's my beer and that half inch wrench?
http://i168.photobucket.com/albums/u...cecar066-1.jpg
  #42
Old 11-20-2011, 11:21 AM
Default Intake?
Hey Scott, I was curious on what INT Manifold you are going to use? As you probally know, there is not much in the way of hood clearance on these cars. I have included some eng. pics from our 73.The INT used was RPM Performer with a 1" spacer. The rear of the hood had to be raised to clear the air cleaner. I have quite a lot of extra trim and some other misc peices(some NOS) left over form that car if your interested....Steve
  #43
Old 11-27-2011, 01:27 PM
Cool
Trans is a perf reman with a shift kit for now. I have an E40D with bauman controller in the works. Just have to pick it up...
B&M 2400 holeshot though I feel with the HIGH 10.9 to 1 c/r, vehicle weight and torque the stall will be higher. 3.50 gears with trak loc.
The intake is a performer RPM with the runners raised to cj height and all equalized to flow 320 to 331 per runner. (I will be using a drop base dual snorkel 5.0 HO air cleaner assembly ducted to cold air.) I picked up 25 to 35 cfm per runner flowed on the heads by doing the roof work. Runners are shaped and matched to their respective port.
Carb is a comp carbs reworked 750 flowing 820 cfm.
My dyno sims are calling for 520 to 560 HP. My gut says the 520 is more realistic.
Every intake port has been checked and they are all in the 371 to 379 range at .570 lift.
Heads will be done this weekend. I am mired in the details right now. Removing the power brake booster for bead blast and repaint, new master cylinder for looks sake, install line lock etc. It never ceases to amaze me how these projects always balloon.
The engine compartment will be the **** if I may say so.
Pics coming soon....
Custom ground cams
http://R-H-P.biz
  #44
Old 11-27-2011, 11:07 PM
xdute's Avatar
xdute xdute is offline
xdute First On Race Day
Aint that the truth!
Kevin
"I'm just going to swap the motor." What the! A rotisserie?
  #45
Old 11-28-2011, 03:11 AM
Looking good MP...............Throw that 12.99 out the window........an easy 11.99 project now. Keep up the good work.
