9.86@134 GLD 10/8/11 - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > Race Talk
Race Talk Tech and Non Tech Discussion
Old 10-11-2011, 09:04 PM
levy87's Avatar
levy87 levy87 is offline
levy87 Driving a Ford
Default 9.86@134 GLD 10/8/11
runn'n 9's
Thank you to the Zylstra crew for all the help at Great Lake's Dragway.
10.5 junkie
Old 10-12-2011, 02:50 PM
levy87's Avatar
here is another vid of the run.
http://www.facebook.com/video/video....45408725507237
10.5 junkie
Old 10-12-2011, 04:26 PM
NITROUS FORD's Avatar
NITROUS FORD NITROUS FORD is offline
NITROUS FORD Driving a Ford
Send a message via Yahoo to NITROUS FORD
Whats the combo!
Old 10-12-2011, 08:12 PM
bigblocktisdale's Avatar
bigblocktisdale bigblocktisdale is offline
bigblocktisdale Driving a Ford
nice pass
1972 torino
fastest ET to date 9.93@139.8
spinning the tires
Old 10-13-2011, 12:02 AM
Jarred Hodges Jarred Hodges is offline
Jarred Hodges First On Race Day
Originally Posted by NITROUS FORD View Post
Whats the combo!
x2
Old 10-13-2011, 01:12 AM
levy87's Avatar
Thumbs up
The motor is 466,stock dove heads,stock cast 2y crank,football rod's,nothing fancy.small NOS shot 125.
10.5 junkie
  #7
Old 10-13-2011, 05:09 PM
Nice!
  #8
Old 10-13-2011, 05:18 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
I thought I heard it perk up just before you went to high gear. Nice pass!
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
  #9
Old 10-13-2011, 09:06 PM
what cam and pistons if you don't mind me asking. If the dove heads are stock without portwork thats probaly the most impressive one I have seen.
  #10
Old 10-13-2011, 10:21 PM
levy87's Avatar
I have a 466. DOVE-A Block,Windage tray,guirdle,Canton Pan,Stock Steel DOVE Head's,SCJ rod's /ARP bolt's,Arias flat top piston's,total seal ring's.
The cam is a Comp Cam Hydraulic flat tappet 305 grind duration @ .050 lift 253 intake 253 exhaust.valve lift 585 intake.585 exhaust part#34-337-4,
Vicktor manifold,1095 king demon carb,Pro shot fogger,magna fuel pro star 500 pump,magna fuel reg's,fuel log,and magna fuel return system.
This is in an 87 mustang GT, weight 2785,me in it 3050.Ladder bar,29x10.5x15 tire,I use 110 octane.
10.5 junkie
  #11
Old 10-13-2011, 10:41 PM
zephyrbob zephyrbob is offline
zephyrbob Driving a Ford
congratulations,,,,would have like to been there...btw you guys make good videos....see yas again at byron, bobn
scouts, and zephies rule 12.3 109 corrected using dragtimes calcul
  #12
Old 10-13-2011, 11:08 PM
levy87's Avatar
Hi Bob.
Ya can't wait to do the race again at Byron,it was a good time.
I wonder how Eric's been,i think he started a new business.
10.5 junkie
  #13
Old 10-13-2011, 11:43 PM
awesome running car, what was the 1/8 mile et, I am thinking in the 6.30 range. I am going to build a similiar combo next year and like seeing what they will do
  #14
Old 10-14-2011, 01:29 AM
levy87's Avatar
1.34 60
4.01 330
1/8 6.25
mph 108.69 my foot slipped off gas pedal,you can hear a dip in motor rpm from video.
A lot of the tuning improvement's were made in the suspension,using different spring rates,adjusting shock's,adjusting spring's front and rear with 4 individual scale's.
I was told i could pull off a 1.29 60 when i find the tune right,i'm close,still need more practice.
I was using 150 pound spring's they were to stiff.Now i'm using 110 pound spring's.maybe 125 i should try.I might need more front suspension travel?it's all trial and error.I keep trying everything till i find what work's best.
Next time out i'm going to do some adjustment's in my MSD box,i can probably pull a couple more hundreth's out of it maybe a tenth or two?
10.5 junkie
  #15
Old 10-14-2011, 04:10 AM
cool with a little more nitrous I think 5.90's in the 1/8 is possible
