1986 coupe build. - 460 Ford Forum
Old 11-09-2011, 08:03 PM
TOPHER1's Avatar
TOPHER1 TOPHER1 is offline
TOPHER1 First On Race Day
Default 1986 coupe build.
I just thought I would share with you all my current build. 1986 mustang that is mini tubbed tied frame and a 10 point cage. My son and I have been getting it stripped down and are at the point of rebuilding now. More detail photo's to come but here is what we have so far. GOAL 9.50s.. Here in Maryland one of our tracks runs a NINE inch NIGHTMARE class 1/8 mile (.400 pro-tree 6.50 index 9 inch slick with mufflers). Will swap slicks back to 10.5w that are currently on it and run brackets when the N I N class is not running..
Thanks for looking and will get more detail pictures as we go.
Old 11-10-2011, 09:34 AM
BigBlockRanger's Avatar
BigBlockRanger BigBlockRanger is offline
BigBlockRanger Driving a Ford
Very cool! I love 4 eye cars!
If you have time check out www.foureff.com!
'83 Mustang GT - 545/C6 - 10.46 @ 130
http://www.foureff.com
Four Eyed Fords Forum
Drag Week 2011 - 77th in Daily Driver
Drag Week 2012 - Street Race BB N/A runner-up
Drag Week 2014 - *kapooya*
Old 11-10-2011, 11:04 AM
TOPHER1's Avatar
Default Thanks
I will have to check the 4 eyes page out.
More pictures to come soon.
Old 11-10-2011, 07:46 PM
TOPHER1's Avatar
Default MORE PICTURES
updated pictures from this past weekend..
Old 11-10-2011, 07:49 PM
TOPHER1's Avatar
Default even more pictures
interior pictures from this past weekend
Old 11-10-2011, 08:01 PM
jcoxracing jcoxracing is offline
jcoxracing Driving a Ford
Looks like you guys are off to a great start!
You might want to relocate your fuel isolator off of your fire wall so it will pass NHRA/IHRA tech.
Keep the pic coming.
Justin
  #7
Old 11-11-2011, 08:07 AM
TOPHER1's Avatar
Default ???
The isolator is still behind the fire wall. It is located were the wiper motor and arms so it technically is still behind a fire wall.
  #8
Old 11-16-2011, 08:28 PM
TOPHER1's Avatar
Default Looking for advice..
With a BBF upfront what should I run for front spring.. Tubular K member manual rack, motor set back 4-5 inches 90/10 lakewood struts and getting ready to purchase tubular a-arms and front coil over kit. What # springs??
also will be removing front bumper.
  #9
Old 04-02-2012, 08:45 PM
TOPHER1's Avatar
Default 86 coupe update..
Engine is due back from MME motor sports this week (502ci).. Converter is with ultimate converters (Lenny) and My brother is freshening up the PG trans.. Here are some update photos.. The rear is back from bracing and welding check out the brackets.. This is engineered design by AUTOFAB race cars here in MARYLAND.. It is a bolt on kit with the exception the braces.. Contact Josh at autofab if interested and tell them Chris sent you.. Most of the electrical is in..
http://autofabcart.net/
  #10
Old 04-05-2012, 06:15 PM
TOPHER1's Avatar
Default Motor update
502 bbf 750hp at 7000rpm 680 foot pounds of touqe @ 5600rpm
  #11
Old 05-27-2012, 12:08 PM
TOPHER1's Avatar
Default UPDATE.. TRIP to the track.
All,
Thanks for all the HELP from the 460 forum page. I was able to successfully get my 86 coupe down the track with only miner issues (front Line lock not holding and spinning hard when the night time air set in.
First pass off the trailer was 6.27 at 109 shifting at 5500.. leaving off of foot brake.. (shake down pass for straightness and stopping)
second pass left on Tbrake at 4300 to see what it could hold. Spun but went straight and of course the clocks did not work.. NO TIME.. but I was able to stay infront of 6.0 car.
Retry second pass.. Left line lock on after burn out but lowered launch to 3400 no spin but pulled to center lane because it was dragging left front wheel... 1.41 60ft lifted and motored down the track.
Third time run was on a pass but missed shift so only went 6.47 with a 1.40..
NOTE I am running a 9" night mare heads up (.400 pro tree) class (6.50 index) 1/8th mile.
First round of elims. I had a 1.37 60ft no spin and I raced the finish line lifting 2 time and dumping hard on the top end. 6.36 to his 6.35 run out. WIN
Second round elims. Race the class points leader. .070 light to his .086 raced the finish line. hit the brake with him and fed him the strip on top end 6.467 to his 6.409 break out... WIN
Third round SEMI's.. Bad light spinning hard peddling through the 60ft cought him and passed him by half track lifted twice to bring him in and fed him the strip 6.52 to his 6.58.. my light .161 to his .060..
First time out very pleased with everything and now just have to adjust suspension some, do to spinning at night.. I believe there are some 5.90's in the 1/8th carb is lean and suspension needs a little adjustment..
Any advice on QA1 single adjustable shock setting and rear four link bars heigth from ground.. I have multiple adjustment points on the rear but stock location on chassis..
Chris..
  #12
Old 06-11-2012, 07:43 AM
TOPHER1's Avatar
Default More Track time.
Friday night racing after rear suspension adjustment for 1/8 mile track.
Best 60 ft 1.350 best ET to this point 6.15 at 111MPH with a little better then 3/4 throttle.. The index for the class we race is 6.50 so I am still way fast.. This coming Friday night going to pull 10 degrees of timming out it and shift it around 5800-6200 (currently 6500 shift) to see if I can get closer to a 6.50..
Will be at MIR this Saturday running the first (of two) TOP ET 1/8 ($5000) so I can finally see if the car is consistant..
My son turns 17 this weekend and will let him race the FOOT brake class at MIR Saturday afternoon.. He has made is first pass in the car this past Friday night Test and Tune with good results. He had 1.36 60ft 6.23ET at 107MPH peddeling it down track FOOT BRAKING it.
  #13
Old 06-11-2012, 01:44 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is offline
Man!! That sounds like an awsome amount of fun!! I can't wait to get mine done. Hopefully it will be as fast as yours. It should be close anyway!! Nice job! Keep us posted when you go back out to the track. I love the descriptions that you give. VERY EXCITING!!
  #14
Old 06-18-2012, 08:50 PM
TOPHER1's Avatar
Default Trip to the track.
First off want to wish my SON Happy 17th Birthday.
This past Saturday evening I turned the driving duty over to my son Daniel for MOD ET at MIR race way.
The morning started out not so good I tried to run the car all out in TOP ET and had traction issues. I lost first round and had to make changes to the car so Dan could make a clean pass down the track without getting loose. I changed the instant center of the car and pushed it out closer to the front tires and WOW what a difference. Daniel drove the car like a true pro (He has not raced in 2+ years and that was a 7.90 82MPH JR dragster).
Time runs and eliminations for the day.
60 foot 1/8 mile E/T MPH
1st 1.352 6.107 112.32
2nd 1.358 6.108 112.85
1st round 1.363 60' 6.121E/T 111.42 scrubbing the brakes 6.10 dial in lost bad light so he wanted to buy back in..
BUY back run 6.13 dial .039 reaction time clock didn't work on the 60' (GRRR)
6.147 E/T at 106.11MPH dragging the brakes through the finish line WIN!!!!!!
2nd round 6.13 dial .035 reaction time 1.385 60' 6.149 at 105.70 MPH dragging the brakes WIN!!!!!!!
3rd round 6.13 dial .058 reaction time 1.364 60' 6.107 at 111.83 scrubbing the brakes LOST.. broke out opponent broke as well but not as bad and reaction times were within .007..
ALL in ALL very proud of my 17 year son..
  #15
Old 09-03-2012, 12:18 PM
TOPHER1's Avatar
Default 1986 coupe Update
Would like to thank all the member here and give my last update on the 1986
coupe build. The car has been running real strong with a best of 1.34 60' 6.10 in the eight at 112MPH.. Been tweaking the carb to more fuel in it but have been rained out the past few weeks.. This upcoming weekend will be the true test if have gone in the right direction.. If all goes well I consider the stang done other then Paint and Lexan windows for next season. Follow my next project 1989 THUNDERBIRD SC..
Chris
