1986 coupe build. - Page 2 - 460 Ford Forum
  #16
Old 09-03-2012, 12:24 PM
TOPHER1's Avatar
TOPHER1 TOPHER1 is offline
TOPHER1 First On Race Day
Default 1989 THUNDERBIRD Build
Here is my next project.. Tube chassis Bird with Fiberglass frontend, hood, doors and trunk. Lexan windows and 9 inch rear with 4.29 gears and four link. I trade a my 2002 Harley FLHT away for it. It will get me old reliable 492ci BBF with a Bug catcher injection on it and powerglide to back it up. Here are some pictures.
Old 02-13-2014, 10:37 AM
TOPHER1's Avatar
Default Update for both builds
Well my son and I have decided to swap car because he want to go fast (8.50s or better).. The mustang build ended up as a great foot brake small tire car running 5.98 @ 114MPH in the 1/8 and 9.46 @ 141 + MPH 1/4. The plan for the Tbird is 545ci with a set of Blue thunder heads (stage III porting). The one problem I am having is my son has it in his head that he think he needs to spin 7200-7500 RPM to make the 850-950 HP. I have tried to explain that BBFs do not need or want to turn those RPMs he is asking why..I told him that they are tall deck and longer rod engines that make gobs of torque and most of the HP number under 7000.. He thinks that he can put a .800 lift cam with big duration (300 - 325) that will allow him to spin it hard. A good explanation of why we do not need to spin HIGHer then 7000 would be greatly appreciated..
The Mustang is on a diet removing glass and metal with hopes of loosing about 100+ pounds for this season and changing the trans gear to 1.96 first and slightly taller rear slick 31 x 10.5 stiff sidewall. The stang was scaled last year at 2930 pounds with driver and fuel. Picked up a fiberglass nose and changing the factory style disc brakes to aero space all around as well.
The Tbird is in the process of reconfiguring the front end to aftermarket K member (cut a badly installed mustang II front suspension) plus cut out as much metal as possible. Hope to get the Bird down to 2500-2600 pound with driver and fuel with driver. Hoping this will get me in the range of 8.50s when it is all said and done.. I will get pics up later currently we are getting snowed up to our you know what.. COME ON SUMMER...
More to come later.
  #18
Old 02-13-2014, 01:12 PM
butterbean butterbean is offline
butterbean First On Race Day
Default builds
nice builds, I really like the coupe build its rite up my alley, I'm building a 1988 T-Bird BBF/C-6 and its a full bodied car with power windows and mirrors, all lights work ECT:ECT:ECT: I've built a .030 429 with C8VE's and a small solid roller but I know I will be dissapointed in the HP and performance, its a good street/strip engine but not a good bracket/heads up motor, so I'm rounding up stuff to build a 514 and Edelbrock RPM's because I need/like to have 700/750 hp so it will run like your coupe. keep us posted when you get back to the track. thanks for a good read
  #19
Old 02-14-2014, 12:15 PM
TOPHER1's Avatar
Default More changes
Here are some pictures of both cars. New nose for the mustang and rims.
Front clip removed from Tbird and new K-MEMBER squared and centerd
  #20
Old 02-14-2014, 12:22 PM
TOPHER1's Avatar
Default More Pictures of Tbird
I have moved the front wheels about 3 inches farther forward in the wheel wells. Here are the pictures
  #21
Old 02-25-2014, 07:50 PM
TOPHER1's Avatar
Progress.. Decided to move wheel back about 2 inches.. Having Strut bars bent at AUTOFAB race cars here in MD. Will pick them up tomorrow and hope to have the Bird mocked up and on the ground by the weekend.. So I can get back on the MUSTANG to for this season..
  #22
Old 02-25-2014, 09:36 PM
windsor windsor is offline
windsor Driving a Ford
Nice builds. How did you like MME for the engine building?
  #23
Old 02-25-2014, 09:48 PM
TOPHER1's Avatar
Default MME
I have had nothing but great results with the MME engine builds. He has built a 472 that is currently in my brothers probe (8.80s at 152MPH) and the 508 in the mustang runs 9.40s at 141MPH. I will be taking MME my back up 492 at the beginning of this season to sit on the shelf as a spare.
MME is the best in my opinion.
  #24
Old 02-25-2014, 09:56 PM
Thanks for the feedback. Good luck with your builds!
  #25
Old 02-26-2014, 09:49 PM
bigblockpaul bigblockpaul is offline
bigblockpaul Driving a Ford
Default wow
way cool builds ya got.i must be doin alot wrong.I got 633hp in a 3000 pound notchback with glide and 410 gears and only got it to go 10.80,s..woow i need help.
  #26
Old 02-28-2014, 11:49 AM
TOPHER1's Avatar
Default Little more done
One strut bar tacked in place
  #27
Old 03-03-2014, 09:09 AM
TOPHER1's Avatar
Default Finally finshed tacking
FINALLY.. The Bird is on the ground and roller again. Still need to finish welding everything. Here is .. No springs on the front for now just to see if how far it would compress.. ride height will be about 3 inches higher..
  #28
Old 03-24-2014, 01:56 PM
Anquia Anquia is offline
Anquia First On Race Day
I love 4 eyed coupes! keep us posted
home improvement projects
  #29
Old 03-24-2014, 10:33 PM
TOPHER1's Avatar
Default Back on the Mustang
Couple pictures of the 86 coupe. New nose, new Dash, and Engine back in.
  #30
Old 03-25-2014, 07:51 AM
Gydyup's Avatar
Gydyup Gydyup is offline
Gydyup First On Race Day
Awesome build, love it. Your shop is like a surgical ward, mine, not so much.
MME? That Marvin right? Read a lot of great articles about his builds if so. He is a clean freak and deamon on dressing blocks, pumps, etc.
Gydup -67 Coupe, 521 Kaase P51 Comp Solid Roller . Jerico DR4, narrowed & mini tubbed 9 inch with 4:56 spool , Mark Williams Axles on CALTRACS, Shaved towers.
Grabbing gears for 38 years.
