New 72 cc Aluminium Heads?? - 460 Ford Forum
Old 12-10-2011, 09:54 AM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is offline
Default New 72 cc Aluminium Heads??
I'm trying to help out TrustTheRef. You can read the theread he started "460 Foxbody". He is going to use the stock bottom end out of a 1995 F-350. His goal is 500 HP. He whould like to get the compression in at around 10:1. I have done a little research and it looks like the pistons in that motor are a -24.4 cc dish. Can anybody confirm this for us? He would like a nice set of heads to go on the motor. It looks like if I am correct about the cc of the pistion dish a 72 cc chamber head would bring him in at about 9.7:1 compression (give or take a couple of tenths depending on if the block has been decked or not). I forgot the mention that the bottom end is a rebuilt Jasper motor. Does anybody know of any new aluminium heads with the 72 cc chamber. It looks like most of the Trick Flow's & Edelbrocks are 75 cc. I'd really like him to get the SCJ-B heads from Lem. But I know those take special pistions. I was hoping since he will be using a stock dish pistons with a realatively small cam to make the 500 HP that the SCJ-B heads would work without having to have the special pistons. Can anybody confirm or deny this? Any light you could shed would be most appreciated.
Thanks!
Old 12-10-2011, 10:22 AM
bigblok86ranger's Avatar
Super Moderator
Chris check out Scotty's Project 12.99 build he did something very similar.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
Old 12-10-2011, 12:04 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
The builder pistons in a jasper engine will be about 22 to 24 cc's dish. SCJ's will work with a cam a bit bigger than I used. I have well over .150" piston to valve clearance on the stock 11 cc dished oem 69 pistons. This with a small voodoo 219/227 with 1.8 high tech comp rockers.
With as cast SCJ heads you will need 9.5 to 1 static c/r and a comp XE274H cam to make your 500 HP with 9.5 to 1 static c/r.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 12-10-2011, 12:16 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
Thanks!
1995? That's an EFI engine and the pistons should have a 15cc dish.
SCJ-B heads have springs for roller cams. You'll want the SCJ-A version if you plan to use SCJ's.
Lastly, the ONLY aluminum head with stock non-CJ ports in stock locations is the Edelbrock head. What sort of intake and headers does he plan to run?
Old 12-10-2011, 01:58 PM
My bad i misread that as 1985...
Carl is right. IF they are the EFI pistons for that year the dish will be 15 cc's and the pistons will sit about .015" below deck.
Since the combo is a jasper rebuild I would measure the depth of the dish. If the dish is .240" then the cc's are about 24 if the dish is .180 then the dish is 15 cc. Also note the deck height.
A standard performer rpm intake will easily support 500 HP and more though with a fox body a torquer 2 is not a bad choice either.
Custom ground cams
http://R-H-P.biz
Old 12-10-2011, 02:38 PM
When you say this you are referring to the SCJ-A valve springs on the SCJ-B heads correct? Or were you saying that he needs the SCJ-A head? I'm thinking that you mean the prior but I want to make sure.
He could always get the SCJ-B bare heads and dress them out himself with springs that match the specific cam that he goes with.
With 3 senior members answering this post I feel pretty good about it. The SCJ-B heads seem to be the way to go. Assuming I am correct about the valve spring swap in the above question. They are hard to beat for the low cost and flow some really good numbers right out of the box. AND they are about $1000 less than the TrickFlow's that I've looked at. He should be able hit 500 HP (or a good bit more) blind folded.
Thanks for the great info guys!!
  #7
Old 12-10-2011, 02:46 PM
When you say this you mean the top of the pistion to the bottom of the dish right? Not the deck height to the bottom of the dish? I just want to make sure we get this right. Thanks again!
  #8
Old 12-10-2011, 03:10 PM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
Aren't the SCJ-As and the SCJ-B the exact same head, the only difference is the A's are flat tappet spring pkg, and the B's are roller springs? That's how I understood it??
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
  #9
Old 12-10-2011, 03:22 PM
DJ5A460's Avatar
DJ5A460 DJ5A460 is offline
DJ5A460 Driving a Ford
That's correct.
M-6049-SCJ -> Bare Head
M-6049-SCJA -> Springs for Flat Tappet Cams
M-6049-SCJB -> Springs for Roller Cams
Age doesn't always bring wisdom, sometimes age comes alone...
If your dreams don't scare you, they're not big enough...
  #10
Old 12-10-2011, 03:24 PM
Well think I was thinking something different. I was thinking that the SCJ-A's were the old Kaase designed aluminium head. Part number M-6049-A429 that SVO sold around 1999. Maybe I misunderstood the SCJ-A & SCJ-B thing... But now that you mention it that does make sense. The A being a hydraulic cam spring package and the B being the roller spring package.
All I know for sure is the new SCJ heads flow some pretty good numbers for the money.
  #11
Old 12-10-2011, 03:31 PM
Lem Evans Lem Evans is offline
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
The A429 heads were refered to as CJ heads.
B F Evans Race Parts
270-278-2376
  #12
Old 12-10-2011, 03:50 PM
10-4. I should know that. I have a set.
...but I do have the part number memorized!! It's conveniently stamped right on the side.
With any luck TrustTheRef will be coming to you for a set of the SCJ-A's
I just read Scotty's 12.99 engine build. That was pretty impressive with such a small cam..
Insurance
Date of Birth
Month Day Year
Privacy
