Solid Transmisstion Mount?? - Page 2 - 460 Ford Forum
  #16
Old 01-03-2012, 06:19 AM
D.I.L.L.I.G.A.S.'s Avatar
D.I.L.L.I.G.A.S. D.I.L.L.I.G.A.S. is offline
D.I.L.L.I.G.A.S. First On Race Day
There is no magical "one size fits all" engine height/engine angle/driveshaft angle/slip yoke angle/pinion angle profile that will work with every car combo. "Drag race only" cars generally can use a different driveline angle profile than a car that only sees street/highway use.
"Street/highway" driven cars. For long U-joint service life under the never ending/constant/repeated partial loading-unloading "hammering" a street driven car's driveline sees for 1000's & 1000's of miles, both front & rear U-joints need a few things to help them live........
1 - Both U-joints need to be operating in "phase" with each other (being at/as close to "equal but opposing operating angles" as possible).
2 - Both U-joint's operating angles them selves need to be at least enough to (A) insure enough cap/needle-bearing rotation & self lubrication during use. But (B) not be at too much of an excessive operating angle where the U-joints are operating at/close to being in a bind at a given driveshaft RPM range.
This generally means that this "repeating partial loading" profile has (A) the pinion's centerline pointing at the same/similar angle as the crankshaft centerline (in relation to the ground), while at the same time the pinion height off the ground vs the crank height off the ground has enough difference that it gives you equal but opposing U-joint operating angles (or interference angles if you want) at both U-joints. The actual U-joint operating angles needed really depend on the rear suspension type used. A rear suspension that has limited pinion/housing upward rotation potential (like say a 4-link with stiff bushings) could get away with somewhere around -2.0* operating angle between the driveshaft & the pinion, and around +2.0* operating angle between the driveshaft & the slip yoke. Having "equal but opposing" U-joint operating angles on a car with a lot of pinion rotation potential (like say a leafspring car without a traction device) can sometimes be a can of worms to deal with. On one hand the leafspring's increased possible pinion rotation can sometimes call for more U-joint operating angle (at the pinion). But putting the same increased operating angle at the slip yoke U-joint (to stay in phase) can sometimes cause it's own problems.
"Drag race only" purpose built cars driveline profile (ladder bar & 4-link). Generally speaking on a drag only car you are less worried about a U-joint's "long service life" over 1000's of miles & more worried about reducing U-joint friction under heavy launch loading. So in this application they are looked at more as a periodic replacement maintenance item. As you build the car (while sitting at the proposed ride height) you in effect mount the engine/trans in the chassis so it's crank centerline points directly at the pinion's centerline & the pinion's centerline points directly at the crank centerline. This in effect gives you front & rear initial mock-up U-joint operating/interference angles of 0.0 degrees at both U-joints. Then after the car is finished & on the ground you adjust in a small amount of downward operating angle back at the pinion U-joint. So in the end (with say a 4-link) you might end up with only around -1.0* (one degree) operating angle back at the pinion, and only around +0.5* (a half a degree) operating angle at the slip yoke U-joint. The theory is that under heavy launch loading the pinion will rotate upward a small given amount (under load) making both U-joints operate at as close to 0.0* as possible (again under load) for the least possible amount of frictional losses through the driveline.
D.I.L.L.I.G.A.S. Dave::
460 street '66 Ranchero.......................finished someday.
460 race '70 Maverick..........................finished someday.
All 'glass Top Sportsman '69 Mustang......ummm, check back when I win big playing the Texas Lotto, or online poker.
My youtube page. Some ancient & newer local race video.
Join the Poker Players Alliance (theppa.org). US online poker should NOT be turned into a crime.
Old 01-03-2012, 10:33 AM
White Lightning's Avatar
Well put Dave.
Rob
  #18
Old 01-03-2012, 07:00 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is online now
I appreciate the post. It helps. I'm going to try to get the angles as close as possible. The rear upper & lower control arms are adjustable so I'll be able to chase it around a bit. I'm also going with solid u-joints. I'm not sure how to mount the alternator with the motor plate so at least for now it will be a track only car.
  #19
Originally Posted by parkclay View Post
Here is a decent article on driveshaft angle.
I have been told the carb pad should be level. I know this is part of the reason we added the new tunnel. I do not remember what we ended up with for a driveshaft angle. I know the carb pad is level on mine. I will try to find some more info in my chassis books.
Clay
http://www.drivetrain.com/parts_cata..._problems.html
That was a good read Clay. Thanks for posting it.
  #20
Old 01-12-2012, 09:17 PM
whitefield's Avatar
whitefield whitefield is offline
whitefield Driving a Ford
Send a message via AIM to whitefield Send a message via MSN to whitefield Send a message via Yahoo to whitefield
Originally Posted by bigblok86ranger View Post
Don't ever use a solid tranny mount bushing almost a garauntee to crack the trans case.
Chris their should be a short one and a tall one I believe the difference is stick or automatic.
But the trans will be a super tight fit on these cars you will need 90* fitting coming out of the tranny for the lines and always install the lines before final engine and trans installation.
X2
Way Fast Whitey.
  #21
Old 06-28-2013, 08:40 PM
bigjohn2007's Avatar
bigjohn2007 bigjohn2007 is offline
bigjohn2007 Driving a Ford
Send a message via ICQ to bigjohn2007 Send a message via AIM to bigjohn2007 Send a message via MSN to bigjohn2007 Send a message via Yahoo to bigjohn2007
Default How it end up?
Im having the same problem and when i raise the tranny it hitting the shifter linkage.Looks as the motor would never be level by carb. flange.What crossmember did you end up using?
big john
  #22
Old 06-29-2013, 08:33 AM
ITSA 91 ITSA 91 is offline
ITSA 91 First On Race Day
I used 1.25 K-member spacers to get the clearance I needed.
