Compression of 520 with P51's - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
Old 03-01-2012, 05:54 PM
juiced520 juiced520 is offline
juiced520 First On Race Day
Default Compression of 520 with P51's
I was told the compression of my 520 with P51's was 13.5:1, but after experiencing some problems with it on the dyno popping through the exhaust between 5,500-700, the dyno operator pulled his Moroso slide calculator out and it says a 520 with 72cc heads should be closer to 15:1 and that the 110 octane fuel is not enough resulting in the popping. We're going to pull my Quickfuel 1150 off tomorrow and try my buddies Quickfuel 1250 tomorrow and see if it pops with it and if it does we're gonna try more octane. Any other ideas on what may be causing the popping?
Old 03-01-2012, 06:51 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
I'm showing 13.09:1.
As for the popping, I'm thinking timing and/or plug gap.
Old 03-01-2012, 07:25 PM
Timing is at 30 right now, I'll have recheck the gaps, any suggestion on the gaps?
Old 03-02-2012, 08:25 AM
Mark Laczo's Avatar
Mark Laczo Mark Laczo is offline
Mark Laczo Driving a Ford
Default popping
What type fuel were you running ?
Old 03-02-2012, 12:12 PM
110 octane
Old 03-02-2012, 12:18 PM
Changed carbs and it's still popping thru the exhaust at 5,700 rpm. The plugs are gapped at .030
  #7
Old 03-02-2012, 05:19 PM
Zac Zac is offline
Zac First On Race Day
If you're running flattops, zero deck and HGs in the ~.040" thick range, static compression shouldn't be much more than 13:1. Something in the ignition system is playing foul. What's the ignition system made up of?
  #8
Old 03-02-2012, 05:34 PM
An MSD Digital 7, an MSD HVC coil, and a locked out MSD distributor.
  #9
Old 03-02-2012, 06:06 PM
Al Q's Avatar
Al Q Al Q is offline
Al Q First On Race Day
try different plug wires, think i had this problem once, had one bad wire with brand new set, put an old set on and away we went
  #10
Old 03-02-2012, 11:50 PM
Mark Miller Mark Miller is offline
Mark Miller Driving a Ford
Did you try Fuel with more octane?
Later Mark.
  #11
Old 03-03-2012, 08:13 AM
I'm going over this morning with a new set of plugs, wires, MSD box, and 120 octane fuel.
  #12
Old 03-03-2012, 09:22 AM
bbstang502's Avatar
bbstang502 bbstang502 is offline
bbstang502 Driving a Ford
http://www.dvorakmachine.com/Calc_staticCR.shtml
  #13
Old 03-03-2012, 03:08 PM
Problem Solved! The two wires going to the distributor were backwards, swapped them and fixed the popping. With 30 degrees timing it put out 921 hp and 720 tq at 6,200 rpm. Torque peaked at 728 at 6,000 and 899 hp. Do these numbers sound right or do they seem a bit high? I wasn't expecting it to make over 850......
  #14
Old 03-03-2012, 05:09 PM
onequickstang's Avatar
onequickstang onequickstang is offline
onequickstang Driving a Ford
Garage
Congrats! That's really impressive! did you try different timing settings to see if you could get any more out of it?
'68 Mustang Fastback. Coming soon - all aluminum 548 A441 Hemi! Gonna be one bad FoMoCo!
  #15
Old 03-03-2012, 05:16 PM
bob460 bob460 is offline
bob460 First On Race Day
Very nice numbers with your build, there was a build by a guy on here with 572ci...p-51...and more comp than you and made 934hp!!!!...........you should be happy
Insurance
Date of Birth
Month Day Year
Privacy
