Lockup torque converter in a C6?? - 460 Ford Forum
Old 03-24-2012, 09:04 PM
76ford466's Avatar
76ford466 76ford466 is offline
76ford466 First On Race Day
Default Lockup torque converter in a C6??
I never have really heard anyone talk of putting a lockup convrtor in a C6. maybe Ive missed this but do they make them? It seems alot of drivablity could be had from a lockup style and more power put to the ground.
Old 03-24-2012, 10:30 PM
stuarta stuarta is offline
stuarta Driving a Ford
It can't be done.
The only way is to install an E4OD.
But then you will need a controller.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Old 03-24-2012, 11:57 PM
richter69's Avatar
richter69 richter69 is offline
richter69 Driving a Ford
what he said ^^^^^^
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
Old 03-25-2012, 07:46 PM
ITSA 91 ITSA 91 is offline
ITSA 91 First On Race Day
Will an E4OD last behind a 700hp BBF?What about a converter that will stall to 3500 in a 3600lb car?
Old 03-25-2012, 09:34 PM
76ford466's Avatar
Ok thanks. Now why cant you? haha Im full of questions.Not being smart I just
want to know what a E40D has that a C6 dont have to use one besides a control circuit.
Old 03-26-2012, 06:13 AM
E4OD has a lock up and overdrive.
The clutch plate in a convertor must be engaged using hydraulic pressure.
C6 has no clutch in the convertor and no way of getting pressure to said clutch.
Journeyman in 1964.
  #7
Old 03-26-2012, 06:15 AM
The first killer is weight of the transmission and convertor.
It's close to twice as heavy as a C6.
Journeyman in 1964.
  #8
Old 03-26-2012, 05:56 PM
Not building a real race car this time.Will it hold up?
  #9
Old 03-26-2012, 08:00 PM
quick 52 quick 52 is offline
quick 52 First On Race Day
have not seen it in a c6 but think it can be done. ive seen it in turbo 400 and chrysler 727 so if the money is there someone will build it.
Drag week quickest street rod
2009 2010
  #10
Old 03-26-2012, 11:52 PM
Neither TH400 or C6 have capabilities of a lockup convertor.
727 yes.
Journeyman in 1964.
  #11
Old 03-27-2012, 08:56 AM
727 yes.
the 400 can be done ive seen them and have seen the internals the pump is rework by drilling a port for hydraulic pressure for apply tcc circuit the input shaft is rework by drilling the shaft to supply fluid to the tcc vortec converter is building them Mike riding is his name and they are out there
2009 2010
  #12
Old 03-27-2012, 09:08 AM
im also using a 700r4 behind my 472 and it works find i dont have alot of hp at 480hp but also spray 150hp to it that put around 600hp and it as been doing it for 4 years have had trouble with the tcc from wot lockups it not will it take out the converter clutch its when and the when has come a couple times
2009 2010
  #13
Old 04-01-2012, 04:48 PM
2slow 2slow is offline
2slow Driving a Ford
727 yes.
early 400's could change the stall . why not use that hyd. system to engage a clutch
