Valve Spring installed height - 460 Ford Forum
Engine Tech A place to discuss all 385-series engine tech and theory. is the premier 460 Ford Forum on the internet. Registered Users do not see the above ads.
Old 03-28-2012, 03:03 PM
GoWest GoWest is offline
GoWest Driving a Ford
Default Valve Spring installed height
Wondering what seat pressure you would use on an application such as the following. The spring is supposed to be 230lb @ 2.00" and 580lb at 1.300". RPM ins't too high so wondering if it may be safe to drop down a bit. Street/Strip with F1 Procharger.
Cam is a Comp solid roller with #4303 intake lobe and #4022 exhaust.
Intake: 290*, 257* @.050, 176* @.200, .429 lobe lift.
Exhaust: 300*, 264* @ .050, 181* @ .200, .420 lobe lift.
Intake valve: 148g
Exhaust valve: 121g
Steel Keepers
Rocker: 1.73 I/E
Spring: Comp #26089
Engine should peak @ 6000 so max rpm in the neighborhood of 6500-6800.
Date of Birth
Month Day Year
