69 fastback 552 Prostreet - Page 2 - 460 Ford Forum
  #16
Old 08-29-2012, 12:43 AM
70Cougar 70Cougar is offline
70Cougar First On Race Day
Thanks for the info! looks sweet keep us updated!
Old 09-13-2012, 11:49 AM
blu69machI's Avatar
blu69machI blu69machI is offline
blu69machI First On Race Day
Garage
Default rear end
So I pulled the rearend so that I can replace the leaky pinion seal, plus I realized that it doesn't have a vent. I have a question and I tried searching online but didn't find an answer. Can any of you gents tell me if the vent has to be on the axle housing or can I tap it into the back of the pumpkin toward the top? I played with the idea of using the filler hole but I think that the location may be too low. I found a art morrison filter over flow that I would mount into the trunk with a hose going to the vent on the diff.
  #18
Old 09-13-2012, 04:42 PM
Gydyup's Avatar
Gydyup Gydyup is offline
Gydyup First On Race Day
It can be either or, the axle tubes are not internally sealed at the pumpkin end, so its wide open.
  #19
Old 09-15-2012, 10:38 AM
blu69machI's Avatar
Garage
Ok, thanks for the input on the rearend, I am just going to plan to put it up high on the pumpkin not much space on the axles with all the four link brackets. Thanks again.
  #20
Old 09-28-2012, 09:50 AM
blu69machI's Avatar
Garage
Default small update
Putting the rearend back together this weekend. I'm ready to get a solid roller spec'd and cut. Thinking about calling Mr. Lem Evans this afternoon as others had suggested.
  #21
Old 10-03-2012, 04:13 AM
Steve460's Avatar
Steve460 Steve460 is offline
Steve460 First On Race Day
Looks great.Did you make up the brake pedal assembly?
I was thinking about taking my brake booster out as well.
Thanks Steve
  #22
Old 10-03-2012, 10:49 AM
blu69machI's Avatar
Garage
I bought the pedal assembly as a kit from Speedway Motors out by my house. it came with the 2 master cylinders your choice of size and the pedal assembly. I also bought a remote adjuster cable so I can change the ratio of front and back brake pressure without getting up under the dash. The master cylinder and pedal assembly cost about 160.00. The cable was like 40.00 bucks. I still need to get the fittings and tubing.
  #23
Old 10-04-2012, 05:35 AM
Steve460's Avatar
Is this the place ?
http://www.speedwaymotors.com/Wilwoo...edal,1960.html
  #24
Old 10-04-2012, 09:04 AM
Gydyup's Avatar
[QUOTE=blu69machI;1032730]Thanks for the compliments.
The shock towers wasnt a kit, I found an article online here:
http://www.fordmuscleforums.com/susp...ck-towers.html
Just realized the article you used to cut your towers, I wrote! NICE, glad folks read and use the stuff I have done.
  #25
Old 10-04-2012, 10:10 AM
blu69machI's Avatar
Garage
Yes that's the company and that's the brake kit.
Shock towers: Hey I'm glad you put that article together, it gave me some confidence to attempt it myself. Thanks!
Pretty excited, I spoke with Mr Evans the other day and he is putting cam specs together for me and will call me back, so I can order it from him.
  #26
Old 10-04-2012, 06:58 PM
66prostreetFairlane's Avatar
66prostreetFairlane 66prostreetFairlane is offline
66prostreetFairlane First On Race Day
Garage
You won't regret that phone call! Get ready to hold
66' Fairlane Prostreet
Blown boss 9 521ci
  #27
Old 10-05-2012, 09:14 AM
blu69machI's Avatar
Garage
first BBF build, first time getting a custom grind. To tell you the truth I just wanted to say "Hey Lem whatever you see fit, heres my card grind away" LOL As a matter a fact I got so excited that I forgot to ask what the lift was and hung up the phone. Then I just sent him the spec request through 429-460. I'm really happy with what he spec'd out and can't wait to get the project done.
Had to go play with the dyno and drag software just for sh#ts and giggles. I know it's probably not all that accurate but, it's a lot more fun why you have the actual cam specs to play with. Now back to working on this rearend.
  #28
Old 10-05-2012, 09:15 AM
blu69machI's Avatar
Garage
Had to go play with the dyno and drag software just for sh#ts and giggles. I know it's probably not all that accurate but, it's a lot more fun when you have the actual cam specs to play with. Now back to working on this rearend.
  #29
Old 10-12-2012, 11:19 AM
blu69machI's Avatar
Garage
Got the cam a couple of days ago just waiting on the bronze cam plate, got the rear end back in after changing the pinion seal, installing a drain plug, a vent tube, and fill plug and painted.
  #30
Old 03-15-2013, 09:41 PM
blu69machI's Avatar
Garage
Default electrical, brakes and engine
Ended up pulling out all the old factory wiring and installed a new harness and fuse panel. I got the back half of the car wired up. I'm waiting to get the front end back on to finish the front. The plan is to finish the brakes first then put the front end back on to finish the wiring.
Got all the brake line and fittings now, installed the pedal assembly and master cylinders. Started running the new lines with the line lock.
Picked up the engine today and painted it up. The project is going slow but it's still moving so its all good.
