motor plate - 460 Ford Forum
Old 06-23-2012, 03:04 PM
bluecoupe 545 bluecoupe 545 is offline
bluecoupe 545 First On Race Day
Default motor plate
i have a few ? about installing a bbf in a fox body mustang. put motor in for the first time and the motor is off set to the pass side.should i center it up or leave it alone it has front and mid plates.
Old 06-23-2012, 05:50 PM
White Lightning's Avatar
It depends on what you intend on doing with the car. When I build a Drag Race only chassis I prefer to center everything in the chassis. It makes everything a little easier to fab up and, IMHO, makes the chassis reaction to the applied power (for going in a straight line) more evenly predictable. Not that you can't run an offset drive train (Ford and Mopar have been doing it for years in their street chassis') but the weight differentiation has to be dealt with by staggering spring rates (if it's significant) and that makes the chassis (IMHO) a little more time consuming to tune.
Rob
Old 06-23-2012, 06:38 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is online now
I'm in the process of building a 1993 Foxbody myself. Rob is right. For a full on drag car everything shoudl be centered in the car. With that being said there are also compromises to the situation. It is offset to the right to clear the steering linkage. If you center the motor in the car you may be creating a lot more work to make the steering linkage fit. You would then also be looking at custom built headers as weel so they clear everything. So it really depends on what you want to do, how much moeny you have to dump into the money pit and how much extra work you are willing to take on.
With all of that being said I didn't center mine. I used the Flaming River manual rack and pinion and steering linkage. I also used a Total Performance motor plate and matching Mad Dog headers. All of those were plug and play with zero fabrication work.
Old 06-23-2012, 08:57 PM
Default plate
were did you get the total performane plate at
Old 06-23-2012, 09:01 PM
I got it from Total Performance out of Clinton Township Michigan. I got the Mad Dog headers from them as well. They headers and motor plate were a kit. It all fit PERFECT!
Here is their phone number: (586) 468-3673
Here is what they look like. The motor plate is also designed to sit the motor lower in the car as well.
Total Performance Motor Plate and Mad Dog Headers.
I hope that wasn't too much information.
Old 05-01-2013, 12:27 PM
Israel's Avatar
Israel Israel is offline
Israel First On Race Day
Do you have a clear shot of what the shock towers look like,..did you mod them at all?
Wife,........."You drove how far for that thing?"
Daughter,..."Theres no inside and it stinks."
Friend,......."Dude, thats a rusted piece of sheet."
Son,.........."This old car is cool."
USMC Security Forces, Kamiseya Japan, 0311
  #7
Old 05-01-2013, 07:19 PM
My shock towers are bone stock & untouched. I have all kinds of pic's in my build thread. Here is a link to that:
http://www.460ford.com/forum/showthread.php?t=157117
  #8
Old 05-01-2013, 08:14 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
should not be centered in these cars,theres a few threads out there about this and the problems it causes
if you using hooker headers it wont fit if centered
from the factory they are not centered
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
  #9
Old 05-01-2013, 09:53 PM
Israel's Avatar
any links to the centered issues?
  #10
Old 05-01-2013, 10:36 PM
T-Dogg T-Dogg is offline
T-Dogg First On Race Day
I was thinking about setting my motor with motor mounts then adapting my plate to set the motor where it sits on mounts. I have a D&D plate and headers. My plate is not as plug and play.
  #11
Old 05-02-2013, 06:24 PM
I should add that the D&D plate is not as plug and play, because you can set it to center your engine or offset as stock. It is a nice looking plate too.
  #12
Old 05-05-2013, 05:17 PM
frank13's Avatar
frank13 frank13 is offline
frank13 Driving a Ford
Send a message via AIM to frank13
Ok can some please help me correct my screw up.
I put the motor and trans in the car to make the frame for the motor plates, but forgot to measure the crank centerline offset. Can someone please post up the correct offset or even measure from frame rail to center point on the crank on both side..
And yes, i am being lazy to not have to re install the block and trans.
  #13
Old 05-06-2013, 07:41 AM
I can measure it for you tonight after I get home.
  #14
Old 05-12-2013, 04:59 PM
frank13's Avatar
Any Luck?
  #15
Old 05-12-2013, 06:30 PM
Oh hell. I forgot. I'll go do it now. Sorry about that.
