79 bronco rear 4 link - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 06-27-2012, 09:52 PM
79Bronco429's Avatar
79Bronco429 79Bronco429 is offline
79Bronco429 First On Race Day
Default 79 bronco rear 4 link
anybody got any specs or pics on a rear triangulated 4 link in a 79 bronco? just coils not coilovers. also any tips on one would be great thanks
if it isn't broke... i must need more nitrous
78 f150 70 460 10:1 hp:425 street truck/towtruck
78 bronco 71' 429 10.8:1 450hp sand truck
Old 06-28-2012, 07:05 AM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
No pics, but if you just want to do a coil spring setup, I've seen where a guy took a set of stock radius arms and coil springs from the front of a late 70's F-150 and put them on the rear. It looked pretty decent and flexed really well on the trails. Had no axle wrap either. If class rules would have allowed it for me, I would have done the same thing on my ranger.
Old 06-28-2012, 02:46 PM
george565's Avatar
george565 george565 is offline
george565 Driving a Ford
Or you can use the same setup from an early Bronco. 66-77yr
Also check with either James Duff or Wild Horses 4x4, one of them makes a 4 link for the big bronco.
Old 06-28-2012, 08:35 PM
orangeford79 orangeford79 is offline
orangeford79 First On Race Day
I have a 4 link rear in my bronco. I used jeffs bronco graveyard superflex front springs in the rear. 2 inch dom ballistic fab joints ect. It works way better than leafs for off road. No wheel hop and lots of flex. Let me now if you have any questions. I could probably email pics of it.
Old 06-28-2012, 10:07 PM
Michael Enright Michael Enright is offline
Michael Enright First On Race Day
I have a down-and-back modified truck that has a 78 bronco frame. I have a little info for some great resources for some fabrication parts. I have Giant Motorsports 4-link mounts, QA1 1 1/4 heim joints, 2" .250 wall DOM tubing, and I personally have King coilovers and bypasses, but go to Ballistic Fabrication for some many great mounts for springs and all kind of fab items that would take hours to make for cheap! hope this might help! Just make sure to make it with alot of adjustability, for alignment, because with my frame, as I put more cage on the truck, A guy would be surprised how much the frame moves!
Old 07-03-2012, 08:46 AM
adamsoffroad's Avatar
adamsoffroad adamsoffroad is offline
adamsoffroad First On Race Day
This is on a little larger scale but here is my mud truck and my monstertruck is set up the same way. But if you notice how the cradle is built it's setup for maximun length on the bars it's also on a straight frame too but the same setup can be used.
http://www.pirate4x4.com/forum/showthread.php?t=1061240
here's the monstertruck it starts as the teardown of big brown but turns into the build of the monster truck.
http://www.pirate4x4.com/forum/showthread.php?t=824073
  #7
Old 07-03-2012, 04:28 PM
Is this for racing, mud, rocks, street use?
  #8
Old 07-04-2012, 11:02 AM
mostly for 300ft sand drags out on silver lake sand dunes but also for a few jumps and bumps around the dunes
  #9
Old 07-09-2012, 10:54 PM
Prizefighter Prizefighter is offline
Prizefighter First On Race Day
Garage
Using the set up for an EB isn't a bad idea. I've read about some 78-79 Bronco guys using the EB coil springs up front because of the progressive rate with no problems. I would be interested to know what you end up doing.
Insurance
Date of Birth
Month Day Year
Privacy
