How do you get the oil pump drive to slide into distributor shaft? - 460 Ford Forum
Old 07-14-2012, 06:36 PM
4604X4's Avatar
4604X4 4604X4 is offline
4604X4 Driving a Ford
Default How do you get the oil pump drive to slide into distributor shaft?
Any tricks or gadgets to help get the oil pump drive shaft to fit into the distributor when installing the distributor? Surely you guys see this from time-to-time.
I'm just fininshing my cam swap and got to the point where I was reinstalling the distributor. I tried many times to seat the distributor but I could not get the oil pump drive shaft to go into the distrubtor. I tried turning the oil drive shaft a little, and the "turn and slam" method, and moviong a gear tooth either direction, but the problem is that the oil pump drive shaft lays aginst the side of the engine housing/boss (it doesn't sit stright up) so the edge of the distributor shaft hits the top of the oil pump shaft and it won't go inside.
Okay so I got it in in (this is going to sound crazy) but I had to wad up a little piece of bread (sandwich bread) and stuff it in the hole to keep the oil pump shaft sitting straight up. Once I did that the distributor slide right into place. First try.
But this shouldn't happen. I have the star washer/retianer on the shaft so it can (edit: should say CAN'T) be pulled out of the oil pump when removing the distributor. The oil pump drive shaft is a "mtorsports perfomance shaft" and the distributor is a MSD billet.
Old 07-14-2012, 07:05 PM
White Lightning's Avatar
But this shouldn't happen. I have the star washer/retianer on the shaft so it can be pulled out of the oil pump when removing the distributor. The oil pump drive shaft is a "mtorsports perfomance shaft" and the distributor is a MSD billet.
Can or can't??? The star retainer goes on the pump side of the block boss so that the pump rod DOESN'T get pulled out of the pump and fall into the pan. FYI, a little heavy wheel bearing grease around the shaft will hold it in position in the future. You'd better get that bread washed out of there before it gets circulated around in the engine........
Rob
Old 07-14-2012, 07:53 PM
DaveMcLain DaveMcLain is online now
DaveMcLain Driving a Ford
Be careful when you take the distributor out the next time because it's VERY EASY for the pump driveshaft to stick inside of the distributor just long enough to pull out of the pump and then fall into the oil pan. That's the purpose of the star washer but with that said it can't really hurt anything if it's in the engine the other way once it's all together. I don't think that the bread will hurt anything really.
I've taken a new driveshaft and particularly if it's an MSD one that's ery blunt on the end and ground it to be more pointy and cone shaped on the end which goes into the distributor.
Any sufficiently advanced technology is indistinguishable from magic --Arthur C. Clarke
Dave McLain
McLain's Automotive
Old 07-14-2012, 08:51 PM
rmcomprandy rmcomprandy is online now
rmcomprandy Bleeding Blue
The top of an OEM oil pump shaft is pointed so it will center itself.
The main problem is that there are 15 teeth on a distributor gear and only 6 sides on the oil pump drive shaft.
Insert the distributor close to the needed position untill the drive gear engages the camshaft gear. Unless you are real lucky it will go only about half way down. Now "hand" rotate the engine from the front until the hex inside the distributor shaft will engage the drive shaft and it will drop down the rest of the way.
You MAY need to do this a few times to get the distributor exactly where you want it to be clocked.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
Old 07-15-2012, 12:04 AM
Money-pit Money-pit is offline
Money-pit Driving a Ford
I always adjust the position of the star washer on any driveshaft I put in. From the factory they never seem to be where I want them.
Old 07-15-2012, 02:23 AM
gregaust gregaust is offline
gregaust Driving a Ford
An absolute must so i know that shaft is staying put..
  #7
Old 07-15-2012, 05:52 AM
4604X4's Avatar
Rob
Typo - the star washer is in the correct place so the shaft CAN'T be pulled out with distributor removal (but it doesn't help tp hold to shaft straight up). Your grease idea is good.
  #8
Old 07-15-2012, 01:27 PM
cletus66's Avatar
cletus66 cletus66 is offline
cletus66 Driving a Ford
I took a 390 apart once, and it had 3 of 'em in the pan.
Where's my beer and that half inch wrench?
http://i168.photobucket.com/albums/u...cecar066-1.jpg
  #9
Old 07-15-2012, 05:47 PM
BBFmavrick's Avatar
BBFmavrick BBFmavrick is offline
BBFmavrick Bleeding Blue
That one made me smile. Nothin wrong w/knowing where a few extra's are stashed.
Rick Brown
(LIL TWEETY) BBF 62 Falcon Tube Chassis
Member of a BAND OF BROTHERS
Pro Motion Machining
Perfect Reflections Photography
Bronx Corner Automotive
Insurance
Date of Birth
Month Day Year
Privacy
