vacuum pumps - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions
Photobucket
Old 07-30-2012, 06:19 PM
64bbsprint's Avatar
64bbsprint 64bbsprint is offline
64bbsprint Driving a Ford
Smile vacuum pumps
Jon was wondering if you have made anymore advancements on the use of vacuum pumps. I know there was a question asked about them awhile back. I am looking to put one on my 545 to maybe help control alcohol in the oil. Your advice would be greatly appreciated.
Old 07-30-2012, 10:58 PM
David Cole's Avatar
David Cole David Cole is offline
David Cole Driving a Ford
I'm not Jon, but I run a vac pump on my deal. Alky injected 598. Star Std pump. Works great. Oil stays clean all the time. Combination of the vac pump and getting heat in the engine with my gas primer setup. Used low tension oil rings. On the dyno we broke it in on gas and the pump pulled 16" at wot with the relief valve set in at just about the middle of the adjustment range. Never tired it any higher due to it being a wet sump oiling combo.
When we we switched it over to the injected alky the vac dropped some but it still held 10" at wot. That is normal from everyone I have talked to. Both injection experts and the guys at Star. I have since adjusted it just a touch upward for 11".
86 T-Bird chassis car
Struts, ladders and W's
Alky injected BBF
Old 07-31-2012, 12:13 AM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
What is the max inches you can safely pull on a wet sump engine without starving the wrist pins of oil?
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
Old 07-31-2012, 11:28 AM
FourEyed Freak's Avatar
FourEyed Freak FourEyed Freak is offline
FourEyed Freak Driving a Ford
10-11
When to much is just right
Old 07-31-2012, 11:29 AM
64bbsprint's Avatar
Default vacuum pump
Okay thanks i had read and discussion on here awhile back. And Jon Kasse suggested not running to high of vacuum on a wet sump system. Had something to do with causing the oil to foam up. And hurting the rod bearings If i remember right Jon suggested keeping it around 10" and not much more.
Old 07-31-2012, 11:27 PM
David Cole's Avatar
Several years ago at one of the winter tech seminars Mr Kaase spoke on the subject. seems that above 10-11 " a gerotor style oil pump as used in Fords start to cavitate. Vac pulling the oil in one direction and the pump in another, thus the foaming oil.
Alky injected BBF
  #7
Old 08-01-2012, 08:52 PM
bruno's Avatar
bruno bruno is offline
bruno Driving a Ford
Thumbs up
couple of good threads on vacuum pumps :
http://www.429-460.com/t13307-vacuum...ghlight=vacuum
http://www.429-460.com/t12169-dry-su...ghlight=vacuum
http://www.429-460.com/t1682-info-on...ghlight=vacuum
enjoy the reading
www.429-460.com
"HOME OF THE FASTEST BIG BLOCKS"
[SIGPIC][/SIGPIC]
www.bfevansraceparts.com
www.evansracingengines.com
JET BOAT BOB
DAN "STICKER MAN" HOBBS
