MSD 8982 problem - 460 Ford Forum
Go Back   460 Ford Forum > Non-Tech Topics > Chilly's Garage
Old 08-14-2012, 10:38 PM
Richard Richard is offline
Richard Driving a Ford
Default MSD 8982 problem
HELP
I have instaled a MSD 8982 retard box in conjunction with Nitrous.
The instructions indicate to conect the gray wire to the nitrous solenoid witch creats a ground and when 12v is applied to the solenoid the retard is activated.
When I do this it pulls all the timing away and when I remove the wire from ground the timing is back but motor is slugish. This is just backward from what I read.
I removed it from the system and went back to the straight MSD 6AL, engin runs much crisper not sure if I am missing smothing or?
Wiring from MSD box.
red to 12v key
Black to ground
Yellow to whits on MSD 6AL
Gray to nitrous sytem.
Old 08-15-2012, 08:19 AM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is offline
Below is a link to the instructions for the 8982. I ran one of these units myself to take timing out when the nitrous we activated. I believe that the gray wire went to the micro switch on the carbuerator that was activated at WOT. When the micro switch was engaged it grounded the gray wire circuit.
http://static.summitracing.com/globa...2_frm28662.pdf
Old 08-15-2012, 09:31 PM
Default problem
Yes that is true I tried a 2nd unit today and it acted the same way. I even went directly to the battery to insure it was getting full voltage
Old 08-16-2012, 04:33 PM
Your not running power wire to the micro switch are you?
Old 08-17-2012, 04:22 AM
Default MSD problem
Spent some time on the phone with MSD Tech today after talking to 3 techs I got one that said the extenchion lead from the Box to the distributor might be braking down " Noise as he called it".
I removed it and all is good now go figure never heard of such a thing but what the heck always willing to learn.
He also said the extenchion leads go bad after a while and should be replaced, know if I could only find some way of testimg it.
I want to that all who replied to my Problem.
Richard
Old 08-17-2012, 07:00 PM
WOW!! That was a troublesome issue. I hate chasing electrical problems like that. It is a real pain. Good job figuring out the problem!
  #7
Old 08-17-2012, 07:36 PM
turbo2256b First On Race Day
The wires running from the box to the dizzy MSD units. The install instructions state not to run those wires near any other wires for the most part like a foot away or interferance with the signal can take place.
MSD offers shielded replacment wires to remedy the issue. I purchase the grounded shielded version right of the bat now. It might be easy to run wires far from otheres on a pure race vehicle but can be tough to do in a fully optioned street vehicle.
