600hp build question P-51 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
Old 09-19-2012, 03:14 AM
Ashburner Ashburner is offline
Ashburner First On Race Day
Default 600hp build question P-51
Hi guys,
Wintertime is coming up what means my engine will be modified (hopefully)..
My car is a ´69 Mustang with a almost stock 429 cui bbf engine, C-6 transmission, 9" 3.50:1 rear end, etc..
Currently I´m running stock cast iron heads, Edelbrock Performer Intake, 770 Holley street avenger with vacuum secondary, full MSD Ignition (6AL), headers, electric fuel pump and that´s it.
What I want to reach until next summer is a 600hp engine (crank) with aluminum heads, good drivable cam (mostly street driven car). I´ve red a lot about P-51 heads and I really like them.
I was in email contact with a Kaase guy, he sent me a whole list of parts. I´m not sure if I really need all those parts, the problem is I can´t spend 7000 dollars on parts. 5000 dollars is about my maximum. I know thats a personal thing but I hope you can help me to sort out the parts I really need for my build. I would like to change only parts that have to be replaced for 600hp, not the whole engine. Would you recommend to stroke the engine? Can the stock crankshaft, pistons, rods, etc. be used at 600hp?
I hope you can help me with my (budget) issue.
Franz
Old 09-19-2012, 11:42 AM
Any low budget solution guys?
Old 09-19-2012, 12:40 PM
BBFRanger BBFRanger is offline
BBFRanger First On Race Day
Forego the p51 heads and work your stock c9 up. I'm making 620hp+ with my c8 heads.
http://www.460ford.com/forum/showthread.php?t=155290
-Brett
1991 Ranger, (stockish) 460BBF and 2-1/2 ton Rockwells. WORK IN PROGRESS.
RIP Matt (greenbroncoguy) 6-16-86/1-29-12. You will be missed but never forgotten.
Old 09-19-2012, 05:58 PM
Thumbs up
That's a very nice build!
BUT I also want to switch to aluminium heads because of the weight. The car is too heavy in the front for stock suspension and linkage..
It seems like I would have to set up a two year plan for my engine build.
Maybe you can help me to set up a plan for my engine.
Things I want to do the next TWO years:
-aluminum heads (favorite are p-51's)
-pistons
-rods (h or I beam???)
-switch to roller rockers and lifters
-switch to roller camshaft
-stroker crank (4.3inches)
-victor or trick flow intake???
-pushrods
That would be the main parts.
Well like I wrote earlier I have about 5000 dollars for this year.. What would make most sense to start with in your opinion?
All the parts should be changed in the next two years and I want to drive the car next summer so it has to work in two steps..
Thanks for your help
Franz
Old 09-20-2012, 06:25 AM
sounds like a good build to me but IMO your going to be over your 5k budget, esspecially when you add the cost of machining, bearings, rings, misc. you would be close if you left out the 4.3" crank, depending on the quality of other parts you buy.
you could EASILY build a 600hp p51 headed motor using stock crank (i would source out and get a 460 crank for some cheap CI) and SCAT/EAGLE h-beam rods (i got my scats off ebay for under 400 bux shipped).
this site has alot of great and knowledgable engine builders (far better than i) that can give you further advise as to pistons, cam, intake, carb, etc. to help you get to your goals. Carl (carsbycarl), scotty j (themadporter), randy (rmcomprandy), and paul kane (paul kane) just to name a few, are all master engine builders on here.
-Brett
Old 09-20-2012, 07:53 AM
Thumbs up
Thanks for your response BBFRanger. At least youre answering my questions
Maybe I said it wrong.. I have not more than 5000 Dollars to spend THIS winter, next winter I will have saved money again so I will be able to buy the rest then..
I thought about it the whole night... It drives me crazy I think
Here´s what I (!!!) think:
Winter 2012 (Step1):
-P-51 heads
-head covers
-roller rockers
-roller lifters
-roller cam
-intake
And keep the rest of the parts (Rods,Pistons,Crank). So I think I will be in my 5000 dollar budget this year.
Winter 2013 (Step2)
-H-beam rods
-diamond pistons
-4.3" Crankshaft
what else do I need? Of course gaskets and stuff like that but thats not a big thing.. let me know if I forgot anything.. Oh yeah, what about the good old mechanical water pump?
What do you think? Would that work? Are the P-51´s working with stock pistons, rods etc. without any damage?
  #7
Old 09-20-2012, 08:42 AM
bob460 bob460 is offline
bob460 First On Race Day
I would go with the SCJ heads, solid cam and lifters, harland sharp roller rockers, probe pistons. You can save some money by using these parts and go without the p-51 heads, diamond pistons, roller cam and lifters.
X2 on having a look on ebay and racing junk...........sometimes you find a great deal, BUT than again sometimes you dont. Good luck.
  #8
Old 09-20-2012, 09:51 AM
no, your current pistons will not work with the p51 heads, the valve locations are different, you could get your pistons recut with the new valve reliefs.
dont forget about a new carb in your budget, that little 770 is not going to suffice with what your trying to do.
i would still recommend a 460 crank and some h-beam rods in your "stage 1" build. thats cheap hp/trq and reliability, but will require new pistons. and keep in mind the cost of machine work, it can get expensive.
if you are patient you can keep watch here in the "for sale" section and find some killer deals on engine parts like your roller rockers and roller lifters and save some money over buying new.
-Brett
  #9
Old 09-20-2012, 10:04 AM
Machining isn't a problem, my brother has a CNC milling machine and we also have a center lathe. So machining is for free
For me it's not that easy to buy parts from one day to another because I'm living in Germany.. Kinda sucks
So I really have to think about my next steps..
Where do I get dimensions or drawings for my stock pistons to make the correct milling work on them?
  #10
Old 09-20-2012, 11:10 AM
I wouldn't reuse the stock cast pistons. They won't be reliable with the build your doing
-Brett
  #11
Old 09-20-2012, 07:40 PM
kevin316 kevin316 is offline
kevin316 First On Race Day
I just ordered P51's and a cam from Kaase.
$3,575.63, includes shipping, roller rockers but not lifters. Lifters will be another $500 (+/-).
It will be $4100 by the time I'm done.
  #12
Old 09-20-2012, 08:47 PM
windsor windsor is offline
windsor Driving a Ford
600 hp definitely doesn't need p51, more like a429 or edelbrocks if you want to go aluminum. With that its sometimes good to get bigger heads for future growth.
I've seen everything you would possibly need in the auction block for way cheaper than a set of new heads. Have a look around. http://www.460ford.com/forum/forumdisplay.php?f=41
  #13
Old 09-21-2012, 10:27 AM
a set if edelbrock Victor heads isn´t cheaper than a set of Kaases P-51s. So thats not the point for me..
And of course I dont need the P51 for 600hp, but they are at the same price than other heads..
the problem isn´t the price of the heads. it´s what comes additional to the heads
help me guys
  #14
Old 09-23-2012, 12:23 AM
68xr7cat 68xr7cat is offline
68xr7cat Driving a Ford
X2
Bob460 is right on the money!
All you need is a set of FRPP SCJ heads, solid flat tappet cam, Crane gold (or one the clones) roller rockers, probe pistons, a scat cast 4.3" crank, and some 6.8" 4340 rods. If you are looking for max HP get a Victor intake and a 1050 Dominator, if more street then a Torker II with the top of the port matched to the head (this is worth some power) and a 950 holley. Think you would like the Torker II and 950.
If you want you can do a bowl blend on the heads and put about a 30 degree backcut on the intake valves. Other than that and just verifying everything is to spec the heads should be good to go.
  #15
Old 09-23-2012, 10:34 AM
bosshoss's Avatar
bosshoss bosshoss is offline
bosshoss Driving a Ford
I am a firm believer in only spending the money once and doing it right the first time.
I would build the short block you want with good pistons, rods and crank first. You can get pistons that have both sets of valve notches. Beef up your drivetrain with good axles, u-joints, good converter and trans mods this year and then add the good heads next year.
The good short block will run with the heads you have. The old short block will be badly stressed if you try to run it with the good heads.
jmho.
dkp
572 67 Mustang Super Gas
289 4 spd 68 Mustang Fastback
Insurance
Date of Birth
Month Day Year
Privacy
