Carburetor For 460 - 460 Ford Forum
Old 10-18-2012, 07:30 PM
BigBlockFord's Avatar
BigBlockFord BigBlockFord is offline
BigBlockFord First On Race Day
Default Carburetor For 460
I've currently got a Edelbrock 600cfm carb on my 73' 460. I'm not upgraded much over stock. I feel like I'm a bit under-carbed at the moment though. It takes off good, but feels like it's lacking power in the 50MPH+ range. I believe the stock carbs were 650cfm, so I'm even under stock carb specs. I'm looking at 750cfm carbs because that seems like the sweet spot for me.
The Summit Racing carbs look nice because they're fairly inexpensive. Has anyone used them? As far as brands go, my top pick is probably Holley, but I don't have a fat wallet at the moment and the Holley 750cfm cost just over 20% more.
Any advice on what would be the "best" option?
Here are links to the Holley and Summit carbs that I'm considering:
Holley: http://www.summitracing.com/parts/HLY-0-3310SA/
Summit Racing: http://www.summitracing.com/parts/SUM-RM08750VS/
I'm glad for any help! Thanks
- Collin
- Collin
88' F-350 RCLB 4x4, 2" lift springs, 3" body lift, 37s, C6, 4.56 gears 1973 468, long tubes, RV cam, ported heads, Stealth intake
My Build Thread
Burnin' gas and rubber
Old 10-18-2012, 07:38 PM
Fordmanmatt's Avatar
Fordmanmatt Fordmanmatt is offline
Fordmanmatt First On Race Day
Garage
I have a 750 edelbrock but I have not installed it yet but I have gotten great reviews on it.....I have a 78 Ford F150
Old 10-18-2012, 07:39 PM
Garage
Also I would go with one with an electric choke thats what I have been told....
Old 10-18-2012, 07:44 PM
Yeah, I looked at some of the Edelbrock 750cfm carbs, and one of them was right in between the pricing of the Holley and Summit carbs I'm considering. All of the Edelbrock carbs I've seen even up through the $400+ range are all single inlet. The other ones I'm considering are dual inlet. Not necessarily a bad thing, just different from much of the market from what I've looked at.
- Collin
My Build Thread
Old 10-18-2012, 07:48 PM
Yeah, the $230 Summit Racing carb I'm considering has electric choke. The Holley has manual. My current carb has manual choke.
- Collin
My Build Thread
Old 10-18-2012, 07:52 PM
Garage
Well i wish you good luck I can tell you this,, there are some really great men on here that really know there stuff and sometimes it takes a while to here back from them but they will get to you, sorry I am not as knowlageble as the senior members but when they advise you on somthing you can take it to the bank they really know there stuff....
  #7
Old 10-18-2012, 10:56 PM
zephyrbob zephyrbob is offline
zephyrbob Driving a Ford
i perfer manual chokes. tried a 750 vac sec holley went to a proform 850 dp. night and day difference....bobn++
  #8
Old 10-18-2012, 10:59 PM
Hoggy's Avatar
Hoggy Hoggy is offline
Hoggy First On Race Day
I just removed my old Holley 600cfm and put on a n Edelbrock 750cfm carb. It has a manuel choke and manuel secondarys. The engine is stock with the exeption of headers and dual exhaust.
The first thing i noticed was the van has more pep off the line, I can hear the secondarys kik in when I put my foot in it. I am usually driving around at part throttle without my foot in it all the time. Normal driving I would say it responds better with the larger carb, the primarys are bigger and you feel it. The secondarys may meed a jet change or maybe needles or both, I'll get to that. I did have to get a bigger gasket for the 750 because when I hit the gas pedal the butterflyes were hitting the gasket. (food for thought).
I am quite happy with the 750. Engine feels like it breathes better and runs more effortlessly. I am not seeing a big difference at all in gass mileage yet. I do know that it likes the bigger carb without a doubt.
  #9
Old 10-18-2012, 11:02 PM
Between the 750 and 850... Are you running an upgraded 460? I'm using mine as a daily driver. I like some performance, but i need to keep low end responsiveness and decent fuel economy (around my current 12-14 if possible). I also hadn't been looking into 850cfm carbs because they cost a little more. Could be worth it if the benefits are good enough.
- Collin
My Build Thread
  #10
Old 10-18-2012, 11:10 PM
Yeah, I've also been wondering about the manual vs. vacuum secondaries and what each does for performance vs. fuel mileage. I always thought that manual secondaries were worse off the line, but better for top end HP. I also thought they were worse for mileage, but not completely sure.
Thanks for sharing the experience with your carb! Do you have a model number or link to the carb that you're running on your 460?
- Collin
My Build Thread
  #11
Old 10-18-2012, 11:24 PM
Hoggy's Avatar
I'm running this because it is what I have available. If I had my way it would be a n electric choke with vacume secondarys. Vacume secondarys open up when the engine wants it and not because you foot tells it to (so I listen to how it sounds when I get on it , and back off when I hear its not doing much good) you feel if its going faster or not right?
I believe its an Edelbrock 1407
For the record, I do prefer the Holleys. The Edelbrock is very easy to work on though. I'm still learning too.
  #12
Old 10-19-2012, 12:23 AM
The Big One The Big One is offline
The Big One First On Race Day
I too have been researching various carbs for my 74 460 in my F350 to replace my stock Motorcraft 4300 4bbl carb. The engine is all stock. You might also look at the Quick Fuel Technology carbs. The 735 SS and 750 slayer have been highly recommended. Also the Demon carbs, 750 street is also recommended. You can google them and check their websites out.
  #13
Old 10-19-2012, 04:16 PM
Okay, I looked at what you have, and I may get an Edelbrock 1411 model. Similar to yours, but it has vacuum secondaries and electric choke. Cost like $320 which is more than I was looking to spend, but it's probably the best choice. Edelbrock carbs are nice because they're almost "dummy-proof" when it comes to adjustments and stuff.
Thanks for the help!
- Collin
My Build Thread
  #14
Old 10-19-2012, 06:26 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
http://www.460ford.com/forum/showthread.php?p=1009040
This is a better deal. IMHO.
D
Sent from my iPad using Autoguide
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
  #15
Old 10-19-2012, 07:52 PM
D
Yeah, I'd glanced at the Quick Fuel carbs. Looks like a decent deal for a 750 cfm from them. The Edelbrock 750 cfm I'm looking at is only another $20 though, and I think I prefer the Edelbrock brand. That's just a personal preference. Thanks for sharing the info though!
- Collin
My Build Thread
Insurance
Date of Birth
Month Day Year
Privacy
