485 cu.in. build - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
Old 11-06-2012, 08:45 PM
fpuller fpuller is offline
fpuller First On Race Day
Default 485 cu.in. build
I am considering changing my pulling truck to a 485 cu inch class and was wondering what would be the best combo. I now have a 4.14 stroke crank and .080 over bore and P-51 heads. The max bore spacing alowed is 4.9 inches. Any heads are allowed ecept Hemi. Single four barrel carb. no sheet metal or tunnel ram manifolds. Thanks for your input.
Old 11-07-2012, 10:00 AM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
A 1.25 CD +.080 stroker piston with a 7.1 rod and an offset ground factory crank will net you 483 cubic inches with a 1.82:1 R/S ratio.
Old 01-15-2013, 09:25 AM
rmcomprandy Bleeding Blue
I have a few engines out there in that class with a slightly different set-up for lower budget.
Offset ground FORD crank to Mopar journal size and 3.975" stroke; a bushed pin end Mopar 440 rod 6.760" long, (could be aftermarket replacement or not) and a 4.390" bore with a piston compression height of 1.560".
Those P-51 heads and a Trick Flow Dominator manifold with a 1,250cfm carb. A custom cam to match your vehicle and running gear.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
Old 01-15-2013, 01:13 PM
hookin78's Avatar
hookin78 hookin78 is offline
hookin78 First On Race Day
The term " Best Combo" will be different depending on budget .....
factory block with standard Production "style" heads.....
Or
Max Effort
Aftermarket Block 4.700 bore destroked
A-style heads
wicked valvetrain and 10,000 plus RPM capable
Big difference
