Strange oil issue... - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
Old 11-08-2012, 11:57 AM
joemkII joemkII is offline
joemkII First On Race Day
Default Strange oil issue...
I have a recently re-rebuilt Ford 460. It's not stock and it has been rebuilt by 2 different party's. I bought a '71 Century boat that had been ground up restored. The engine, I am told, was original but was modified and bored out during the rebuild. Here are some of the highlights:
KB pistons
hydraulic lifters
roller cam and rockers
Melling hv oil pump
Milodon oil pan
holley 650 dp
etc,etc.
You get the jist of it...
Anyway, I bought this boat, which is by the way, a Berkley jet. Everything is right. New or restored as new. Engine starts right up, runs fine, sounds phenomenal. This owner says to me that, as a winter project he was going to put in Smith Bros. .020 oil restricting push rods because he didn't like the oil pressure at certain engine loads, but he was not too worried about it since he and I would not be using the boat for racing or anything. Just a family fun boat.
I took the boat home and then out a week later. Put it in the water, started it right up and idled out to the lake via a long channel. Took about 15 min to get out. I brought the boat up to plane, not hard mind you just easy until I got the feel for it. I gave it the beans for a few seconds at a time, everything sounded great, nothing unusual. I was going about 30 mph (out of 60) Then was suddenly I heard the engine banging and I brought it down and shut it off. I waited then restarted and there it was, dreaded piston rod clunking. Got towed in.
Yanked the engine tore it down and the machinist told me that it was probably due to crap in the passageways that caused an oiling failure to the crank in certain areas. The engine had maybe 15 hours on it.
He rebuilt the motor replacing the oil pump, bearings, magnafluxed it, the whole nine yards. Anything he didn't like he redid.
Put the engine back in. Everything is as it was, starts right up, sounds great, BUT this is where the curve comes in...
The engine sounds and responds as if there is nothing wrong. No hesitations or anything. At exactly 3100 rpm the oil pressure drops like a rock to 20 psi or sometimes a little lower (15). The normal idle pressure is 80 cold, 70 hot. We are monitoring via electric pressure gauge in the dash AND have switched to a screw in mechanical to confirm the reading, same. The sender is at the rear of the engine. As soon as you bring the throttle to 3000 or below, the oil pressure returns to 70-80 psi instantly. We have tried overfilling the oil to see if somehow we are sucking the pan dry or sucking air, nothing changes.
Now to see if it may be angle of the boat causing dry pan we have ramped up the throttle fast, then very slow, with the bow up (coming up to plane). With the boat level and on plane. Slow or fast throttle ramp up, the result is the same every time.
Now, since the original owner had suggested the oil restricting rods may help the situation I got a set and installed them. Took it out and got some interesting results. When the engine is cold it was holding, that is, until the engine warmed up a little, then down it went! But this time it doesn't recover quickly as it did before. It takes a few seconds (3-5) and sometimes you have to bring it all the way down to idle for it to recover. Also, the replacement rods made a very predictable problem, unpredictable! Once it went up to almost 4000 rpm before it dropped. Other times it was dropping at 2800 rpm. Also the pressure recovery was now flaky as well.
I, and my mechanic, have been scouring the web trying to find a solution to this issue. While a stock 460, when having oiling issues always points to oil pump or tube, a modified engine can have all sorts of issues. Most say when you change from flat solid cam, lifters, to roller, you have too much lift and it lets oil run unrestricted briefly in some positions. Almost everyone agrees that you need some type of restriction up top to solve low oil pressure problems. At this point I am out of ideas. If we have to pull the engine again to recheck the pump/pickup situation some have suggested to dump the Milodan pan and use an Armando's pan. I have tried many things chasing this problem and I truly think what ever is the problem now was the ORIGINAL reason for the engine puke the first time!
I'll be happy to purchase one of these pans if I know it will solve the problem, but I don't wanna throw away 500 bucks to find out it didn't.
And yes the oil pump was changed from the first rebuild.
Your opinions would be appreciated.
Old 11-08-2012, 08:47 PM
Lem Evans Lem Evans is online now
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
Is this Mil. part # 31365 ? The one with the front of the pan 8-3/4" & rear 7"? If so, I would not say it is "the" issue but, it anit the way I'd do it.
How many qts. of oil do you have in it?
B F Evans Race Parts
270-278-2376
Old 11-08-2012, 09:27 PM
Default strange oil issue
I don't know the model #, it was on the motor as rebuilt by the former owner. But it sounds like the one, and it DOES have a windage tray.
10 qts.
Old 11-08-2012, 09:28 PM
Paul Kane's Avatar
Cool
The oil pressure symptoms you describe are a textbook description of the Milodon jet boat pan in some (but not all) 460 builds. If that pan works in a given jet boat engine combo, then great. But when it does not work with a given jet boat engine combo, the symptoms are just as you describe.
I use the Milodon 31365 in my 0.030" overbored 460 jet boat engine and it seems to work fine. Incidentally, HV pumps cannot "pump the pan dry" and in fact my HV pump/Milodon jet boat pan have run 90 seconds wide open throttle and held good oil pressure for the entire length of the run. Let me emphasize that my point here is to address the fallacy about "pumping the pan dry" (in an otherwise proper oiling system), not to confuse you with my correctly functioning Milodon pan.
If you want to spend the $600+ go buy yourself a Dooley pan and your unusual oil pressure behavior should be solved, even with their inconsistently fabbed and sometimes questionable pickup tubes. Or, you can buy an Armando's jet boat pan with a nice 7/8" pickup tube and its windage tray secured inside the pan (boxes in/compartmentalizes the oil in the sump) for less money than the Dooley and correct your unusual oil pressure symptoms for less money and likely more effectively. They are great recreational jet boat pans.
Paul
High Flow Dynamics
Old 11-08-2012, 09:29 PM
Paul Kane's Avatar
10 qts.
The tray design of the Milodon is a big part of the inconsistent oil pressure behavior with that pan.
High Flow Dynamics
Old 11-08-2012, 09:37 PM
10 qts.
@ 7" in the rear and 10 qts. and the oil runs to the back when you get on the "gas" .......windage from 'hell' i.m.o.
270-278-2376
  #7
Old 11-08-2012, 09:48 PM
D Pope's Avatar
D Pope D Pope is online now
D Pope First On Race Day
Why wouldn't you use a rear sump pan in a boat? Is clearance an issue?
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
  #8
Old 11-08-2012, 09:50 PM
Yea, I'm at my witts end with the thing. Anyone I've given this problem to scratches their head. But I have to press on and figure it out so I can put it away for the year. Then it the spring I won't have to mess with it. Just maybe a tune tweak here or there.
  #9
Old 11-08-2012, 09:52 PM
The pickup IS in the rear. That's what doesn't make sense!
  #10
Old 11-08-2012, 10:01 PM
I.m.o. it makes sense when the bulk of the 10 qts. of oil is in the 8-3/4" front and it gets 'jamed' into the 7" area when the boat sees w.o.t. and the oil is climbing the back of the pan and wraping around the crankshaft.
270-278-2376
  #11
Old 11-08-2012, 10:14 PM
Well, you see that's the rub. I've ramped up slowly to see if that was part of the problem and the lack of pressure comes on at the exact same time. It seems tied to the rpm. Is perhaps the blow by is just bad enough at this point to cause such a repeatable event?
  #12
Old 11-09-2012, 01:03 AM
scumdog scumdog is offline
scumdog Driving a Ford
Is the rear of the sump baffled to prevent oil from 'climbing' up the rear of it away from the pick-up? (And into the path of the crank)
A long way from anywhere
'70 429
Isky 270 cam
Roller-rockers etc
Torker & 780 Holley
Headers
Petronics and Mallory ignition.
Shift-kitted C6
2.75 4-spider 9"
All in '55 F100
Top speed: 131mph
Best e.t.: 13.93
  #13
Old 11-09-2012, 01:17 AM
White Lightning's Avatar
Wait a minute. Let me get this straight. You're running a front sump pan with a rear sump pick up???
This is the pan set up that I've run on my jet for years without a single oiling hick up:
http://www.summitracing.com/parts/mor-20614
And I've beat on this boat like a stolen red headed step child! I usually throw it up on step within its own length with a wide open throttle and don't back out of it untill I start pooping my pants! lol Seriously, it works just fine.
And it fits my Kona hull with room to spare.
Rob
  #14
Old 11-09-2012, 02:48 AM
D Pope's Avatar
This would be the pan. Nobody's asked, but is your motor flywheel front or flywheel rear?
1949 Mercury coupe
58 T-Bird interior
  #15
Old 11-09-2012, 04:00 AM
Cj Ford's Avatar
Cj Ford Cj Ford is offline
Cj Ford Driving a Ford
I had similar issue but it was at 5000rpm ... ended up being a combination of things ... bearing clearances way to loose and that pan also is very questionable
Chris
Chevy big blocks are great ....... for traction !!!
