Cheap bracket build! - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > Race Talk
Race Talk Tech and Non Tech Discussion is the premier 460 Ford Forum on the internet. Registered Users do not see the above ads.
Old 11-13-2012, 07:28 PM
SLG SLG is offline
SLG Driving a Ford
Default Cheap bracket build!
Been running fords forever starting with 289 then 460 429's now we run the 351 stroker stuff great little motors also! I am bilding a Front Motor Dragster to bracket race and honestly i want a 300 six just to be different? I have access to a 460 that i may use but it will use ALL the production parts all but the cam and intake the cam will be a comp cam 280 yea it's small maybe some roller rockers and a single plane intake! the idea is to shift around 5000 and go with about a 373 gear and a glide this is a bracket car! I will most likely go through the engine with new rod bolts and new pistons and stock oil pump and timing set! Best 460 I ever had was 60 over with cast pistons ran it for years shifting about5200 and paid for the Falcon it was in! anybody else run anything similar to this?
"If your gonna be stupid, you gotta be tough"
Old 05-19-2013, 09:48 PM
bigblockdan bigblockdan is offline
bigblockdan Driving a Ford
I had or have something like that in my 87 Mustang at 3200lbs and shifting at 5000 with a stock bottom end and heads just a cam and intake it did a best of 11.60
I slapped a set of heads on it this year and it picked up big time 1st run of the year it went 11.02 shifting at 5600, I backed it down a little for the class I run but I bet I could see 10:80's easy, and if I changed the converter I think much faster its real tight
1993 Mustang 514 all motor
1990 Mustang notch 460
1969 Mustang Mach1 351W
Date of Birth
Month Day Year
