tunnel ram guys please help - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > Race Talk
Race Talk Tech and Non Tech Discussion
Old 11-17-2012, 04:56 PM
bigblockpaul bigblockpaul is offline
bigblockpaul Driving a Ford
Default tunnel ram guys please help
I got a weiand tunnel ram on my bbf and want to turn the carbs side ways.But the kits for linkage say that there for 4150 style carbs and iam using 4160 vacuum carbs.Will the same linkage work for my carbs.Thanks for the help..
Old 11-17-2012, 07:09 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
I use 800dp carbs inline ,but 4160 linkage should be the same as 4150. Inline linkage is a lot more simple to me.
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
Old 11-18-2012, 11:48 AM
Default yes but
Several carb guys told me to turn carbs sideways to get rid of back bowls goin dry and lean.so iam goin to turn them and get new linkage..
Old 11-18-2012, 09:06 PM
460VEGA's Avatar
I never had that problem,I use side hung bowls on the front & center hung bowls on the back with jet extensions. The carbs almost touch each other, but they do clear. The car 60fts low 1.30s sometimes high 1.20s with no starving.
Old 11-21-2012, 02:00 PM
kim kim is offline
kim Driving a Ford
the linkage has a huge amount of adjustability, I cant see why it wouldnt work. You need the ford specific base plate, to mount the stuff on the manifold, its real easy to set up.
Old 11-21-2012, 06:34 PM
Default yes
thats what i figured.Thanks tho...
  #7
Old 11-22-2012, 12:49 PM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
I have carbs sideways on mine if you want a pic.... Pm me your email n I can send ya a couple if you want.
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
  #8
Old 12-23-2012, 12:07 PM
68xr7cat 68xr7cat is offline
68xr7cat Driving a Ford
As 460Vega said use the jet extensions in the back bowls. The main reason for mounting the carbs sideways is to make tuning easier as bowl access is not obstructed.
Steve
  #9
Old 12-24-2012, 03:53 PM
Default yup
I got them sideways now and just need to get the linkage and iam ready for next season.thanks Paul
  #10
Old 12-25-2012, 11:07 AM
460VEGA's Avatar
Remember when you are jetting them one # up or down x8 makes a big change!
