429 install into 1968 montego wagon - Page 2 - 460 Ford Forum
  #16
Old 12-13-2012, 12:10 PM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
Let alone the great parts of got from members!! And getting rid of my unneeded parts!! Thank you forum!
Sent from my SCH-I535 using AutoGuide.Com Free App
Old 12-13-2012, 01:36 PM
71gt's Avatar
71gt 71gt is offline
71gt Driving a Ford
Send a message via AIM to 71gt
Originally Posted by CarsByCarl View Post
The 1.850 pilot fits at the outside edge of the flange. The deeper/smaller 1.250 hole is of no consequence. The later 1.375 pilot fits in the deeper hole, and the larger machined surface closer to the flange is only used for pilot bearings in manual applications.
Well when I had this problem my converter I had with the 1.375 would not fit in the crank. I had to order a converter from TCI for it with the 1.250 pilot. TCI was the only place I could find that had a part number for that converter.
79 f150 4x4,79 bronco,77 F100 xlt 2wd
  #18
Old 12-13-2012, 02:01 PM
68montego's Avatar
Yeah mine goes about 3/4 of the way in and then the converter bearing gets real wide and hits the crank edge. The engine is 1971 engine just have a late model c6
  #19
Old 12-13-2012, 03:00 PM
68montego's Avatar
Oh and thanks for the exhaust manifolds Carl. At first I was little weary as to if they would fit nicely. Turns out they fit perfectly! Hopefully it sounds good to through my cherry bombs!
  #20
Old 12-13-2012, 04:49 PM
68montego's Avatar
Well I measured the pilot hole. It's 1.25 alright.
  #21
Old 12-13-2012, 06:05 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
Now measure the next step out, closest to the flange/outside edge of the crank.
  #22
Old 12-14-2012, 06:06 AM
68montego's Avatar
That is 1 7/8.
  #23
Old 12-14-2012, 06:08 AM
68montego's Avatar
The deep hole is 1.25 then it gets wider and is about 1 7/8 inside diameter
  #24
Old 12-14-2012, 07:57 AM
CarsByCarl's Avatar
About 1-7/8? AKA 1.875. Are you sure it's not actually 1.850?
  #25
Old 12-14-2012, 08:45 AM
68montego's Avatar
Well I measured with a tape measure from under the car. So I couldnt get that fine of a reading. I'll have to lift the engine out and use a finer instrument to be certain.
  #26
68montego's Avatar
To me it looked to be 1 7/8, maybe smaller but I don't think an bigger than that.
  #27
Old 12-14-2012, 07:39 PM
68montego's Avatar
Newest photos!! She's sitting in there alright. Solid as a rock with those mounts I fabbed. Have a question of where to put my oil pressure gauge in the engine? Is it the hole in the top back behind the intake?
  #28
Old 12-14-2012, 08:09 PM
torinodave torinodave is offline
torinodave First On Race Day
i had a converter problem with my early 460 crank the converter measured 1.85 and the pilot was 1.835 chucked the converter in a lathe cut the pilot till it fit
  #29
Old 12-15-2012, 01:07 AM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
Yes sir, oil gauge goes in the port behind the intake. Cool car by the way, wagons RULE!
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
  #30
Old 12-15-2012, 01:48 PM
68montego's Avatar
I was thinking about getting it cut. Would be cheaper than buying a new converter. Thanks dude I love my wagon!! Just want it to go fast!
Insurance
Date of Birth
Month Day Year
Privacy
