429 install into 1968 montego wagon - Page 20 - 460 Ford Forum
  #286
Old 06-02-2013, 07:25 PM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
The fastest I've ever gone in the quarter mile is 17.50 at like 80 mph. That was with my wagon with a stock 302 c4 trans. So if I can go faster with a 127 more cubic inches I would be happy lol
Old 06-03-2013, 11:55 AM
68montego's Avatar
So I got the intake. And realized the studs are twice the size of the ones I had in my stealth. Haven't seen ones this size. So my question is do I helicoil the holes in the intake to fit my smaller diameter studs or do I make the holes in my carb base bigger to fit over the studs. Dobt really want to make the holes In my carb bigger. What would you need these huge studs for?
  #288
Old 06-03-2013, 12:23 PM
68montego's Avatar
You can see the differences in size as well as one of the holes has what seems to have a bolt broken off and has been moved.
  #289
Old 06-06-2013, 12:20 AM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
What brand of radiator are you running? Also do you find that pusher fans work good?
D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
  #290
Old 06-06-2013, 12:46 AM
68montego's Avatar
I'm running a 3 core aluminum radiator. I got it from ebay its called a champion radiator. Works great and was a steal at under $200 bucks in my opinion. I wanted them to pull but they wouldn't fit on the inside so I moved them to the outside. I have two 14" fans that flow over 1000 cfm each. And it blows plenty of air through the rad. I heard that pushers obstruct the airflow but at this point in time its fine. Just bought a little 10" fan for my transcooler just need to make a bracket to mount it.
  #291
Old 06-06-2013, 08:57 AM
Dman64's Avatar
I just bought the same radiator but I bought the 2-12" electric fans with the custom shroud they make, I'm just not sure how well the 12" fans will cool my truck, guess we will be doing an experiment.
D
  #292
Old 06-06-2013, 11:24 AM
68montego's Avatar
So tonight I burnt the living crap out of my face, neck and chest as well as some of my arm. Rad hose blew off and sprayed me with 220* water last night. Spent 8 hours with ice on my burns to soak the heat out. What an awful painful experience.
  #293
Old 06-06-2013, 11:26 AM
68montego's Avatar
I think mine might be two 12"s as well. Rad works great and doesn't leak after a year and a half so far. Like I said they seem to flow plenty of air through. I mean if the stock fans with copper rads kept these beasts cool two electric fans with an upgraded rad should have no problem lol
  #294
Old 06-06-2013, 01:57 PM
butterbean butterbean is offline
butterbean First On Race Day
Default studs
Ryan, I'm reading over your posts and see the studs, I did not know it had over sized studs in it I took the motor out of the truck and took it apart, I sold the 800 DP that was on it several weeks ago to A guy in Altuna PA. and have not herd fron him sense so I would check and see what size they are, the stock ones are 5/16 so see if they are the next size up or not, I'm guessing the owner before me must have put the next size up and drilled out the base plate on the carb, just let me know how you work it out, Butterbean
  #295
Old 06-06-2013, 02:00 PM
Default burned
PS. I hope your not burned real bad!!!
  #296
Old 06-06-2013, 03:02 PM
68montego's Avatar
Hey butterbean its alright. I pulled the studs out put helicoils in it and stuck my 5/16 studs in. Got the intake on and it runs great. Yeah who ever messed with it and drilled them out drilled through two of the runners and made the carb spacer holes bigger lol. Anyway it worked out and its on and done with. Looks good too. Thanks Dman I had some second degree burn spots and a lot of swelling esp in my neck and face. But after hours on ice it feels just like bad sunburn today. And of coarse I'm at work atleast its not hot out.
  #297
Old 06-06-2013, 03:07 PM
68montego's Avatar
Here's a picture of my burns. Got me in the face and neck pretty bad.
  #298
Old 06-08-2013, 10:39 AM
Dman64's Avatar
Dude that's harsh, ouch. Loose clamp or did the hose fail?
  #299
Old 06-08-2013, 12:55 PM
68montego's Avatar
Hose blew off and shot it all right at me lol. Guessing rad hose was not tight. Car had an overheating problem.
  #300
Old 06-08-2013, 02:42 PM
DeepRoots DeepRoots is offline
DeepRoots First On Race Day
Ouch. sorry to hear that.
I had that happen at work. Main generator fried the voltage regulator, so I was running the aux gen. Aux generator blew a 1.75inch coolant line and I installed a new one with the engine running :P It hurt a lot.... but floating offshore with a dead ship seemed less fun somehow.
