Compression Increase With heads - 460 Ford Forum
Old 12-26-2012, 10:09 AM
Madman Madman is offline
Madman First On Race Day
Default Compression Increase With heads
I been working on my first 460 build, simple one engine runs great but rear seal once again aheader leaks prompted me to repair said problems, Now with the engine running Propane and Gasoline (dual Fuel) I was considering a set of 75 cc edelbrock heads as a replacement, I wonder if these will fit right on the stock 1984 circa. block with stock pistons and what compression increase I would have. I think stock is 7.8 to 1 i=f im correct(usually im Not ha ha) Thanx Guys Mike
Old 12-26-2012, 01:03 PM
mp40's Avatar
mp40 mp40 is offline
mp40 Driving a Ford
Originally Posted by Madman View Post
I been working on my first 460 build, simple one engine runs great but rear seal once again and header leaks prompted me to repair said problems, Now with the engine running Propane and Gasoline (dual Fuel) I was considering a set of 75 cc edelbrock heads as a replacement, I wonder if these will fit right on the stock 1984 circa. block with stock pistons and what compression increase I would have. I think stock is 7.8 to 1 i=f I'm correct(usually I'm Not ha ha) Thanks Guys! Mike
Did you find the set of Edelbrocks at a good price? That i think, to me at least, would be a determining factor as the cost of the complete heads is fairly high. What are you working on? And what is (are) your performance expectation(s)?
1967 Mustang coupe, Mustang II front suspension. W/RV camed, D3VE headed, 460/C6 (soon to be 557 CID w/ported police interceptor heads) out of the box BBC headers(with homemade steel adapters)
Shocktower removal enthusiast.
The race is not over till the Fat Block Ford Sings!
FBHO
Old 12-26-2012, 01:48 PM
Paul Kane's Avatar
Cool
If the engine is bone-stock then your compression will increase from about 7.9:1 to about 9.2:1 with this particular head swap. Note that the valve train is different between the two heads and it will be necessary to spend several hundred more for the new valve train parts and associated components.
Paul
High Flow Dynamics
Old 12-26-2012, 04:01 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
Another consideration is the piston to valve radial clearance with a cam much more than stock.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
