D3 head questions - 460 Ford Forum
Old 12-29-2012, 11:55 AM
72Pstroke 72Pstroke is offline
72Pstroke First On Race Day
Default D3 head questions
I am putting together a 521 for my jet boat. It had D3 heads on it originally, with the exhaust valves upgraded to 1.725 exhaust valves and not much else.
I realize these are probably the worst heads I could start with, but I will probably run them one year and go to alum.
The question is: Are there any substantial gains to be made by porting these? Does the Mad Porter's guide to head porting cover these heads?
Or should I just bolt a piece of chain to them and use them for an anchor?
The engine probably won't see 5000 rpm's, gonna be around 9:1 compression.
Input on rocker arm suggestions and cam suggestions (flat tappet) would also be appreciated.
I am leaning toward a Stealth intake and an 850 Holley for the intake side, it has log type wet exhaust on it.
She is a pretty heavy boat, not looking to build a racer out of it, but more power is always nice!
Thanks for the help!
Tim
Old 12-29-2012, 12:35 PM
Paul Kane's Avatar
Cool
Tim
I have a set of ported D3VEs on my jet boat and it goes 85 mph gps. And I know a guy who has run ported D3VEs on several 557 jet boat engines. They may not be on top of the food chain but once ported they have can certainly their place.
A 28cc dished piston will net you about 9:1 compression ratio. If you shave the heads to abut 91 ccs you might get 9.25. Definintely don't go any lower than 9:1 as it will cost significant power--keep in mind that if your boat uses an open cooling system then you can get away with more compression on pump gas since the typical jet boat engine operates with a water temp of 140*-160* F. Consider a 22cc dished piston (9.4:1) if you can find one.
The D3 heads respond very well to porting and The Mad Porter's site is very effective for D3VE heads. There are other things to consider such as valve guide height and maximum amount of cam with the OEM valve train. The Stealth and 850 are good for now, even if the engine may run better with a larger carburetor but we don't know the exact application of the engine yet. Such a build as you are describing could be a reliable and economical cruiser boat build.
Paul
High Flow Dynamics
Old 12-29-2012, 05:22 PM
rmcomprandy Bleeding Blue
Where did you ever get that wrong idea that a D3 head was not a very good head...? Those heads are just as good as any other non CJ regular port head, (other than the D2OE-AB P.I. offerings), if high compression ratio is not required.
In my opinion ... the Stealth is the wrong manifold for what you wish to do. I'd use a Torquer II.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
Old 12-29-2012, 05:59 PM
Lem Evans Lem Evans is online now
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
I agree with Randy........on a jet boat engine I'd go with the single plane manifold on a 521"
B F Evans Race Parts
270-278-2376
Old 12-29-2012, 08:23 PM
I guess I assumed that since they were smog era heads, they would be lacking in performance.
Thanks for the input on the Torquer 2. It has a Torker 460 on it now. Is there enough difference to warrant the upgrade?
Any thoughts on cam or rocker selection? I will have the rotating assy here next week, and will drop the whole mess off at the machine shop. The valvetrain is the next batch of stuff to order. I will gladly support the vendors on the forum.
Old 12-30-2012, 10:50 AM
Money-pit Money-pit is offline
Money-pit Driving a Ford
I'd get them milled, drilled, and tapped for studs and guide plates. Get the guides trimmed down for retainer clearance. Might as well get them cut for spring seat cups too.
  #7
Old 12-30-2012, 11:59 AM
If you are going to use hydraulic lifters then converting to studs is almost useless, (sometimes even a detriment), and cost more money to boot.
I would recommend the Ford Racing Performance Parts rocker arms #M'6564-C351 or Scorpion equivalents.
The "Torquer 460" is a low performance MILEAGE type manifold and is completely different than a "Torquer II".
CNC porting
  #8
Old 12-30-2012, 09:44 PM
" sometimes even a detriment " why ?
  #9
Old 12-31-2012, 10:49 AM
A lot more than a SINGLE reason.
Ridgedity and rocker arm side motion are the most common.
CNC porting
  #10
Old 12-31-2012, 12:47 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
Pay very close attention to the advice given in this thread...
Properly ported D3's even with just 2.11" intakes / 1.65" exhaust valves will support enough HP to take an A impellor to 5400 rpm with just a 460. A 557 will do even better.
For a juice cam the stock rockers are fine until you near the larger cams which require dual springs with more than 330 pounds open. I would then graduate to a bolt down roller rocker as suggested elsewhere.
In oem form they are pretty miserable. Well ported they perform amazingly well...
Oh an Lem is too right. jet boat / Torquer 2 / match made in heaven...
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
  #11
Old 12-31-2012, 04:11 PM
I appreciate the advice more than you know.
I had been looking at the Scorpion rockers, I just didn't know if that was the route to go.
I have 3 different impellers here I can try once I get the engine done. I have an A, an AA, and a 4A (long story). I also have a diverter to go on it.
So, what is the magic behind matching the engine to the impeller? With the previous engine, it would top out at 4700 with an A impeller. MPH unknown.
Thanks again!
Tim
  #12
Old 01-01-2013, 09:47 AM
Thanks again!
Tim
Matching the impeller will depend upon how much you actually already know.
When you go immediately to wide open throttle the RPM should go slightly above the peak torque of the engine ... that will get you close.
CNC porting
Insurance
Date of Birth
Month Day Year
Privacy
