Miller 302-351W Roller Rockers for Std Valve Layout and N351 Z304 Heads - 460 Ford Forum
Go Back   460 Ford Forum > Classifieds > Vendor (FOR SALE)
Vendor (FOR SALE) This section is dedicated to all vendors who wish to place ads for their new products.
Old 01-10-2013, 10:26 PM
Paul Kane's Avatar
Cool Miller 302-351W Roller Rockers for Std Valve Layout and N351 Z304 Heads
For those of you that are also building small block Ford engines.
Below: Miller Small Block Ford Rocker Arm Set, Standard Valve Layout
Below: Miller Small Block Ford Rocker Arm Set, N351 Z304 Valve Layout
  • Miller small block Ford roller rockers (same manufacturer as the exotic Miller Boss 429 Hemi rocker arms)
  • Designed exclusively for small block Windsor motors (289, 302, 351W, etc.)
  • Rocker body made of 7075-T7 aircraft aluminum
  • Can accomodate as big as a 1.625" diameter valve spring
  • 8620 billet steel trunnion axle
  • Beefy oversize pin on roller tip
  • Tiny pushrod cup oiling hole so as to help control top end oiling
  • Chromoly hammer forged polylocks (ie work hardened, not broached)
  • Establishing proper pushrod length is a snap with the top measuring face on the rocker (instructions included).
  • Available in 1.6 ratio and 1.7 ratio
  • Complete brand new set with polylocks and instructions, originally $384 Retail/$342 Racer Net
  • 302-351W standard valve layout rockers, $298/set + shipping (Int'l please inquire)
  • N351 & Z304 0.150" offset valve rockers, $328/set + shipping (Int'l please inquire)
We think the Millers are the best SBF stud rocker arm out there for the money and among the best stud rockers for the SBF at any price. None of the other rockers offered at this price come with comparable materials, composition or technology behind them, nor will you find any other roller rocker with a rocker body made of 7075-T7 aircraft aluminum, with anywhere near the fatigue / destruct / tensile strength capabilities, and the 8620 billet steel trunnion, all at our comparable pricing.
Don't put your high performance engine build at risk with el cheapo rocker arms, buy quality!
PM, call or email if interested,
Paul
highflowdynamics@earthlink.net
310-435-1900
High Flow Dynamics
Old 01-30-2013, 01:17 PM
747JETMECH 747JETMECH is offline
747JETMECH Driving a Ford
Default Hi Paul
Can I send a set is used Miller rockers in and have them inspect, replace and make them servicable?
Tom
"The more hair I lose, the more head I get"
Old 01-31-2013, 01:31 PM
Paul Kane's Avatar
Cool
Tom
Tom, we are authoized and equipped to inspect and rebuild your Miller rockers. PM me your number and I'll give you a call.
Paul
High Flow Dynamics
Old 03-11-2013, 12:56 PM
Paul Kane's Avatar
Cool
M.L.,
Your standard valve layout rocker arm set is en route.
_________________________
H.R.,
Your 0.150" offset rocker arm set is en route.
Thanks very much for your business, gentlemen.
Paul
High Flow Dynamics
Old 03-17-2013, 06:55 PM
majik455 majik455 is offline
majik455 Driving a Ford
are these direct bolt ons for dooe 302 heads? The studs are pinned are do i need larger diameter rocker studs installed?
Old 03-18-2013, 10:50 AM
Paul Kane's Avatar
Cool
We have these rockers available for 7/16" and 3/8" stud applications. However most people with heads like yours remove the press-fit studs and tap the hole for the 7/16-14 coarse thread (the stud hole in the head is the correct size for the 7/16 tap). I don't recommend using the OEM press fit studs in a high performance application. It's also possible that the OEM studs will be too short for roller rockers, but that scenario depends on the overall valve train setup and the actual rocker arms being used (parts combination).
Please call with any further questions.
Paul
High Flow Dynamics
  #7
Old 03-19-2013, 07:39 PM
turbo2256b First On Race Day
I am running DOOE heads on a 302.. 7/16 studs, springs 140/150 seat about 450/460 open. Using Crane Cobra rockers. Dont think these are realy sturdy enough. Max RPM of engine is somewere over 7200 RPM. Havet pused that envelop as a few componets in the engine hold me back. Factory hyd roller lifters and the rocker arms. Will the Millers handle it?
  #8
Old 03-20-2013, 12:54 AM
Paul Kane's Avatar
Cool
I am not sure what you mean by "Crane Cobra rockers," (do you mean the factory 1.7s?) but to generally answer your question these Miller rockers are easily capable of handling your noted spring pressures and noted 7200 rpm at least as well as (and likely better than) most brands available for the SBF. We have customers using them in big roller-springed drag racing engines, in big roller-springed road racing engines, etc, and subjecting them to higher rpms (along with a rocker stud girdle) than your noted 7200.
They are made of 7075 grade aluminum and have a destruct level of about 83,000 psi at 250*F. Compare that to SBF Crane gold which are made of 6061 and I understand to be closer to 63,000 psi (which is also very good), and Scorpion which I believe has a destruct level of almost half that of the Crane rockers (~33000 psi )
I think that these Miller rockers are among the top of the line SBF stud rocker arms available, from a materials stand point (both the aluminum and the steel), from a geometrical engineering stand point, from a performance stand point, and so on. Same source of high quality needle roller bearings as used by Jesel, T&D, etc. As noted at the top of this listing, they can accomodate a big 1.625" roller spring. Further, the rocker slot is designed to accommodate at least 0.800" lift at the valve (assuming Mid-Lift geometry setup--other methods will lessen that ability on pretty much any brand stud rocker).
Please call, email, or PM directly with any further questions.
High Flow Dynamics
  #9
Old 03-27-2013, 09:53 PM
Paul Kane's Avatar
Cool
D.T.,
Your standard valve layout SBF rockers are en route.
Paul
High Flow Dynamics
  #10
Old 05-17-2013, 12:33 PM
Paul Kane's Avatar
Cool
R.M.,
Your standard valve layout rocker arm set and your 0.150" offset rocker arm set are en route.
Thanks very much for your business.
Paul
High Flow Dynamics
  #11
Old 05-27-2013, 12:37 PM
Paul Kane's Avatar
Cool
B.O.P.,
Your rocker arm sets are en route.
Paul
High Flow Dynamics
  #12
Old 07-25-2013, 08:53 PM
Paul Kane's Avatar
Cool
J.W.,
Paul
High Flow Dynamics
  #13
Old 10-02-2013, 12:46 PM
Paul Kane's Avatar
Cool
B.H.,
Paul
High Flow Dynamics
  #14
Old 11-18-2013, 12:56 PM
Paul Kane's Avatar
Cool
D.S.,
Paul
High Flow Dynamics
  #15
Old 11-25-2013, 08:23 PM
DJW-Racing's Avatar
DJW-Racing DJW-Racing is offline
DJW-Racing First On Race Day
Send a message via MSN to DJW-Racing
How much longer do you expect to be able to put on this deal?
Derek.
1966 Mercury M-100
1976 Ford F250 4x4
