Remanned and recurved duraspark distributors by RHP - 460 Ford Forum
Go Back   460 Ford Forum > Classifieds > Vendor (FOR SALE)
Vendor (FOR SALE) This section is dedicated to all vendors who wish to place ads for their new products.
Old 06-23-2008, 06:19 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Default Remanned and recurved duraspark distributors by RHP
Fully remanned and recurved to application.
I disassemble, double check, curve to applcation and reassemble.
Curve is set on a sun distributor machine. In addition vacuum advance dashpot is set per application.
Cost is $144.95 plus shipping.
Warranty is lifetime.
8)
Scotty J. "AKA" The "Mad Porter"
"EMC 2006" 3rd place finisher
Ported BBF iron head specialist & Aluminum heads from all sources.
Custom ground cams
See our products in the Vendor for sale section
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 06-23-2008, 07:48 PM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
Scotty,
Can you do one and ditch the vacuum advance stuff for my WOT mud bogger? Basically make it a mechanical advance setup?
Old 06-23-2008, 08:33 PM
Originally Posted by kjett
Scotty,
The vacuum advance can simply be left disconnected. Its arm positions the breaker plate. It could be tacked for additional strength. I can set up an advance curve with a very small amount of mechanical advance and a good amount of initial.
I would just need your build specifics.
I have run these distributors to 700 Hp with no issues and found no additional power changing to an MSD unit which utilises the same pick up and reluctor assembly.
8)
Custom ground cams
http://R-H-P.biz
Old 06-24-2008, 01:49 AM
grand_marquis_gt's Avatar
grand_marquis_gt grand_marquis_gt is offline
grand_marquis_gt Driving a Ford
Email sent 8)
1979 F100
1987 Crown Victoria 2Dr
2009 Grand Marquis LS
http://www.grandmarq.net
Old 06-24-2008, 11:57 AM
Originally Posted by grand_marquis_gt
Email sent 8)
Email received and a reply sent...
Thanxxx.
8)
Custom ground cams
http://R-H-P.biz
Old 06-24-2008, 02:47 PM
BigBlockMark BigBlockMark is offline
BigBlockMark Driving a Ford
Would it be possible to send you a dizzy and have it worked over or used as a core? I have a couple collecting dust and Id rather see them get redone and used that just keep sitting.
Old 06-25-2008, 12:01 PM
I can utilise the cores for core value against the purchase of a remann unit. This is provided they are in together condition.
You could send up to 3 in a flat rate usps box.
I dont rework the originals as it cost much more than just buying the remans in bulk.
Telephone me for more information. 253-988-6648.
Custom ground cams
http://R-H-P.biz
Old 08-17-2008, 04:14 PM
sheffield.mike sheffield.mike is offline
sheffield.mike Driving a Ford
pm sent
1965 mercury meteor
545
Old 08-17-2008, 08:42 PM
rvesterby's Avatar
rvesterby rvesterby is offline
rvesterby Driving a Ford
Default a
How about a locked unit for a crank trigger ??
Do you feel comfortable using your distributor to spin the oil pump in a 900 HP motor ?? (Using an aftermarkrt drive shaft) - Have never seen any info on where the stock shaft in the distributor runs out of gas
Tomorrow is the first day of the rest of your life. Lets go racing !!
Old 08-19-2008, 06:36 PM
Just Brian Just Brian is offline
Just Brian Driving a Ford
Hi Scotty,
How much to ship to New Zealand.
Cheers Brian
Old 08-27-2008, 12:02 AM
Default Re: a
This is a reman stock replacement distributor. I dont think its use is appropriate for that appication to be honest.
8)
Custom ground cams
http://R-H-P.biz
Old 08-27-2008, 12:03 AM
Originally Posted by Just Brian
Hi Scotty,
Cheers Brian
If you still need help with this PM me....
8)
Custom ground cams
http://R-H-P.biz
Old 08-31-2008, 04:57 PM
You have a pm
Old 09-11-2008, 06:02 AM
IndyPete IndyPete is offline
IndyPete Driving a Ford
Send a message via MSN to IndyPete
you got another PM!
Pete
http://www.indyracingscene.com
Old 09-18-2008, 06:19 AM
Do you still sell these? Haven't heard anything from ya.
Pete
