Choice of heads ? - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
Old 01-17-2013, 02:19 AM
Steve460's Avatar
Steve460 Steve460 is offline
Steve460 First On Race Day
Default Choice of heads ?
What I have atm,2 bolt main block,cast crank,steel rods,forged pistons 30".D3 cast heads (ported)not sure of flow numbers, GM671 blower & Enderly injection running on methanol.
Have sold blower.Unsure whether to get 871 or 1071.
Im' getting a A460 block & Scat forged crank.
My compression is about 9:1.
I was looking at getting some bare heads & fitting my stuff to them as they are still good.
Was looking at Kase P51 heads but also noticed the C-460 heads.
Wanting to keep my blower manifold,will it fit both style heads ?
Any sugestions?
Thanks Steve
Old 01-17-2013, 04:10 AM
WFO WFO is offline
WFO Driving a Ford
C-460 heads totally different!
Old 01-17-2013, 11:55 AM
c.evans c.evans is online now
c.evans Driving a Ford
The tail will wag the dog here,,,,meaning whatever style/manufacture blower manifold you have will be the determining factor in which heads you can run. So,,,,,,,what or whose blower manifold do you have?
Secondly,,,,there is a very unlikely chance that your head parts, if you are meaning valves, will "fit" the new heads you decide to buy. That would be the least of my concerns.
Hope this helps,
Charlie Evans
Old 01-17-2013, 11:05 PM
Steve460's Avatar
Manifold is locally made Newby suit my D3 heads.
I was looking at using roller rockers.
Thanks.
Do they still make Blue thunder heads ?
Old 01-19-2013, 01:48 PM
Zac Zac is offline
Zac First On Race Day
Of the two choices you referenced, you'd be better off with the P51s if you plan on using that intake. Well to be correct, your only choice would be to go with the P51s if you are determined to use that intake. The C460 is an entirely different layout.
Old 01-24-2013, 05:56 AM
2slow 2slow is offline
2slow Driving a Ford
"only choice" thats not his only choise , there is about 10 different (specs) heads he can use.
with adapter plates -even more
  #7
Old 01-24-2013, 05:40 PM
Zac Zac is offline
Understood. My reply was directed at the two specific heads he referenced - a P51 casting and a C460 casting.
