header design and build - 460 Ford Forum
Old 01-17-2013, 03:16 PM
frank13's Avatar
frank13 frank13 is offline
frank13 Driving a Ford
Send a message via AIM to frank13
Default header design and build
Thinking of building my own headers for my 2002mustang with a 460 in it.
Header style and design is a question i have. Along with some fab questions.
I posted three pics of completely different header design. Two look very restrictive and teh maddog headers look simple, clean and free flowing.
I plan on using a motor plate and a trans crossmember (no midplate)
I also thought about picking up a "weld your own kit" to 1. save cash 2. get the experience.
I have a mig welder with gas at the house.
Anyone have tips or tricks to not screw this up , or should i just spend the money of already build headers- if i make my own i planned to flow the design of the maddog one since they look the easiest and look less restrictive.
all of these are around the same pricing.
maddog headers
Hooker supercomp
D&D autospec
Old 01-17-2013, 03:17 PM
frank13's Avatar
yes i stole those pics! LOL
Old 01-17-2013, 03:45 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is online now
CarsByCarl Driving a Ford
If you enjoy fabricating stuff, it's a great way to save a few bucks and have some fun. It also makes you feel good to say "oh, I built them" when people ask where you got your headers.
You don't really need anything more than a mig and an angle grinder with a cut-off wheel, although a band saw is nice to have.
Old 01-17-2013, 03:49 PM
frank13's Avatar
Carl, do you have any opinions on the three header designs i posted?
I know what i atheistically like, just looking for some opinions also
Old 01-17-2013, 04:43 PM
CarsByCarl's Avatar
Generally, you want as much straight pipe as possible before the first bend, as few bends as possible, and as equal length as possible...equal length being more important than fewer bends. The chassis will more often than not dictate how close to perfect you can get.
Old 01-17-2013, 05:31 PM
White Lightning's Avatar
I you are going to fab your own, you'll also need several of the triangular shaped fabrication magnets to hold the tubes in alignment until they can be tacked. The smaller ones will fit into tighter places.
Rob
  #7
Old 01-17-2013, 07:40 PM
D Pope's Avatar
D Pope D Pope is offline
D Pope First On Race Day
There's also the tri-Y design that goes four into two then into one.
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
  #8
Old 01-18-2013, 06:35 PM
Optimum primary tube length and diameter depends on the RPM range the engine will see most of it's time in.
Rob
  #9
Old 01-19-2013, 07:21 PM
94429mustang 94429mustang is offline
94429mustang Driving a Ford
Default header
i have a 1994 mustang with 557 with p51 head ,i have put a set of hooker header.
i have upgrade with with kooks header 5502 is a horor or nightmare
the left side the tube are too long to clear shock tower and the right side it impossible to bolt the tube on cylinder 2
if i have to go back ,my first choice is hooker header
  #10
Old 01-19-2013, 11:58 PM
bigblok86ranger's Avatar
Super Moderator
I don't think anyone makes ones to work with a stick so you will more than likely need to build your own our modify a set. I have done three sets of customs now and definitely got better results on the second set and third set than the first. I am planning on buying a tig welder and starting to do more of them I enjoy the challenge and to have ones custom built is usually $1500+ I can't see charging that kinda money so gonna do them cheaper. I say go ahead and build your own, the worst part of doing them with a Mig is grinding the welds down of you want a clean look our you could just wrap them.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
  #11
Old 01-20-2013, 03:43 PM
IMO wraping them is a good idea any way.
Rob
  #12
Old 01-20-2013, 05:02 PM
frank13's Avatar
ok guys,
Decided to build my own:
http://www.460ford.com/forum/showthread.php?t=162895
  #13
Old 01-20-2013, 06:01 PM
TommyK TommyK is offline
TommyK Driving a Ford
Header fab video tutorial:
http://www.stainlessheaders.com/headerfabrication
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.50 trac lock
  #14
Old 01-20-2013, 06:12 PM
frank13's Avatar
watched all six already, its where I go the pvc idea
  #15
Old 01-20-2013, 08:46 PM
trabdady trabdady is offline
trabdady First On Race Day
Default Header design & build
You should get in touch with Eddie Henemen at Headers by Ed in Minnesota. 612-729-2802. He's got all the peices and can advise you all the way. He helped me with mine, now I'm on my third set. You just can't buy a set of headers that are as good as what you can build, you may doubt that right now but you'll be glad you did it afterwards.
