pexi glass or lexan? - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 01-25-2013, 09:11 PM
mud rookie mud rookie is offline
mud rookie First On Race Day
Default pexi glass or lexan?
rules in my part of the country are changing and they wanna eliminate glass windsheilds for safety reasons for the some what fast guys. What do you think is a better solution pexi or lexan? I run mud races, bogs and the occasional sand drag so kinda wanting something that wont scratch so easy but still be safe if possible
Old 01-25-2013, 10:42 PM
crittersf1's Avatar
crittersf1 Driving a Ford
Lexan
Old 01-26-2013, 07:23 AM
347galaxie's Avatar
347galaxie 347galaxie is offline
347galaxie Driving a Ford
lexan, Plexiglass will shatter into large shards when flexed.You can put lexan in a brake and bend it without it shattering. Also if you didn't know polycarbonate is the generic term for lexan.
It aint braggin' if you back it up!!
Old 01-26-2013, 11:36 AM
White Lightning's Avatar
Any sanctioning body that even has a hint of having it's sh*t together wouldn't even consider letting anyone run Plex as a windscreen. And if they did....well I think that I'd want to run some where else. Changing from glass for safety reasons?? Are the windshields popping out and hurting people? That's about the only way that they can cause a 'safety' issue.
Rob
Old 01-26-2013, 12:05 PM
WFO WFO is offline
WFO Driving a Ford
And the scratch resistant[Marguard] Lexan lasts longer than standard lexan.
Old 01-26-2013, 12:31 PM
Polycarbonates have their own set of rules when it comes to cleaning them. An old friend of mine used to clean the wind screen in his airplanes with Lemon Pledge. Makes them slippery and lets the rain run off.
Rob
  #7
Old 01-27-2013, 06:53 PM
I dont know what their reason is for taking glass out I just do what they say. A couple other safety parts theyve added are u-joint cages and haramonic balancer shields anyone use these or know where to get some pics would be helpfull if its something I can build myself
  #8
Old 01-27-2013, 07:46 PM
The SFI approved type of balancers don't need a guard. The outside of them is one piece and can't come off. Only stock 2 piece balancers can have the outer ring come off, I've seen it happen quite often. I've never heard of a u-joint cage. Are they talking about a drive shaft loop?
Rob
  #9
Old 01-27-2013, 09:54 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is online now
....they don't hold a Snipe hunt before the race do they?
U-Joint cage?? Really?? I've never heard of that (but then there is a lot I haven't heard of). That sounds crazy to me.
Do the fourm a favor and ask about whey they consider the stock windshields unsafe please. This puzzles me. I thought the only reason to go to Lexan windows was simply to save weight in race cars.
Do a lot of people break windshields racing where you race? I could maybe see getting showered with the little shards hazardous but the stock windshields do a very good job of keeping large objects from coming through the windshield.
  #10
Old 01-28-2013, 05:22 AM
Ridin Dirty Ridin Dirty is offline
Ridin Dirty First On Race Day
Default U Joint Cage
I know for our rules around here most organizations require a shield around all u-joints which is most likely what they are referring to.
  #11
Old 01-28-2013, 11:57 AM
Post up a pic or a drawing of this shield please. This is new to me.
Rob
  #12
Old 01-28-2013, 01:11 PM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
Yep. the shaft loop holds the shaft in place, but the u-joint cage (or shield) keep the little pieces from flying when the shaft is spinning really fast
  #13
Old 01-28-2013, 02:41 PM
I'd like to see one......
Rob
  #14
Old 01-28-2013, 02:58 PM
kjett's Avatar
Hard to make out in the pic, but the last loop right in front of the center chunk is the u-joint shield. From there, my driveshaft loop "cage is attached and there is another loop at the top u-joint. Same setup on my front.
It mounts simlar to the way the monster truck loop cages and u-joint shields attach. From Partick Chassis catalog:
  #15
Old 01-28-2013, 05:15 PM
I see. Thank you. I don't know about anyone else but every time I've seen a u joint break there weren't any pieces that come off of it, the cross just breaks. I'm not saying that it can't, I've just never experienced it. Now drive line retainers.....that's a whole different story.
Rob
Insurance
Date of Birth
Month Day Year
Privacy
