front or rear fuel tank - 460 Ford Forum
Old 01-28-2013, 05:35 PM
robertaccucolor robertaccucolor is offline
robertaccucolor First On Race Day
Default front or rear fuel tank
I am behind the eight ball when it comes to new tech in drag racing, I have been away from it for 30 yrs. My question is were is the best location to locate fuel cell in full tube chassis car runing on racing fuel, front or rear. I was told if I ran alchhol to mount up front and racing fuel in rear. Its a 800hp motor and a 1150 dom.
Old 01-28-2013, 06:52 PM
NITROUS FORD's Avatar
NITROUS FORD NITROUS FORD is offline
NITROUS FORD Driving a Ford
Send a message via Yahoo to NITROUS FORD
Talking
Running mine up front racing gas! 1 or to 2gal tank! And another one for nos!
Old 01-31-2013, 11:24 PM
D.I.L.L.I.G.A.S.'s Avatar
D.I.L.L.I.G.A.S. D.I.L.L.I.G.A.S. is offline
D.I.L.L.I.G.A.S. First On Race Day
In my opinion any drag car that has the room for a front mounted fuel cell should put it up front regardless of the fuel type used, just makes more sense to me.....
Plumbing the system cost less because of much less total fuel feed/return line lengts needed.
Easier on the fuel pump(s) since it doesn't have to push the weight of all the fuel in the long feed line from the trunk foward against the launch forcess trying to force the fuel backward.
If you use a cell that's a little larger than what's actually needed to make a full pass you can add/remove some of the extra fuel from pass to pass in effect using the extra fuel as a small amount of adjustable ballast.
Just remember that a front mounted cell must be protected by a chassis structure/bar/guard/loop of some kind made of at least 1 1/4" OD tubing with a wall thickness of at least .058" (moly) or .118" (mild steel).
D.I.L.L.I.G.A.S. Dave::
460 street '66 Ranchero.......................finished someday.
460 race '70 Maverick..........................finished someday.
All 'glass Top Sportsman '69 Mustang......ummm, check back when I win big playing the Texas Lotto, or online poker.
My youtube page. Some ancient & newer local race video.
Join the Poker Players Alliance (theppa.org). US online poker should NOT be turned into a crime.
Old 02-01-2013, 03:31 PM
Default fuel tank location
Thank you guys, as usuall you always come thru with sound advise and your experiance with using a certain setup.
