Lincoln rear end help/suggestions odd duck - 460 Ford Forum
Old 01-31-2013, 08:10 AM
vashtsdaytona1991 vashtsdaytona1991 is offline
vashtsdaytona1991 Driving a Ford
Default Lincoln rear end help/suggestions odd duck
Hello all, I am hoping you can help me out again (as you always do) with some odd duck lincoln questions, and general newbishness to rear ends.
What I have is a 1969 linc conti 4d, 460/C6 with a 2.80 rear open diff. factory option for that year is a 3.00, LSD also optional. but i dont have those.
this car is 5200lbs+, im sorry i dont know the factory stall speed off hand. it cruises well only pulls 2100ish at 60mph. but it doesnt accelerate off the line well at all. i have used some online calculators to see how much rpm would be affect with various ratios (tires are 235/75/15s).
what would you guys suggest is a ratio that would increase the fun factor and still be livable for driving corss country interstate? also considering switching to a LSD if i could.
now i think i have a 9 3/8 rear on this, not lincoln specifc just pre 70s ford stuff right? i have been told that entire carrier housing and assebly from a 9in, with 31spline axles will swap over. do you know anything about this? possible good donor cars?
is there no parts for my axel as is? when i look online i havent seen a 9 3/8 on the usual sites. A member of my lincoln forum bought 9in gears and they didnt fit so we know that wont work.
to sum up, what can i use to make this work, and what target ratio should I be shooting for?
I hope I have given you enough information, and thanks for any and all help!
-Adam
Old 01-31-2013, 07:50 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
3.50,its a heavy car
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 01-31-2013, 11:58 PM
68xr7cat 68xr7cat is offline
68xr7cat Driving a Ford
Regarding the 9-3/8" rear you are not going to find any new ring and pinions for it. Used or NOS is it. They did make a 3.50 ratio, but may take some looking to find a good set.
A 9" will bolt into the axle housing and provided it is a 31 spline unit you may or may not be able to reuse your axles. The side gear offset is different between a 9" and 9-3/8". Some have done the swap and re-used the original axle with no issue, some have had failure. You need to make sure you have the correct spline engagement. The pinion yoke should swap ok.
That said the 9-3/8" carrier is a HD piece - nodular iron case, 4 spider gears, big pinion support and carrier bearings, and of course a larger ring and pinion set. If you build a 9" I'd figure on a nodular iron case, daytona pinion support, 4 spider gears, etc...
Old 02-01-2013, 06:03 AM
D Pope's Avatar
D Pope D Pope is offline
D Pope First On Race Day
The 9 inch carrier assembly is interchangeable. I put a Detroit Locker in mine.
If you want a used set of gears look in a 1978 or so F150. That's what mine came out of. It was a posi to boot.
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
Old 02-01-2013, 07:36 AM
stuarta stuarta is offline
stuarta Driving a Ford
Going from a 2.8 to 3.5 your engine is going to be reving a lot higher at 60 mph.
Lots higher.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Old 02-01-2013, 10:38 AM
Lots higher.
Yes, about 600 RPM at 60mph. I like a 3.25 gear as a good compromise. What really need is a OD transmission and then can put a real gear in it, but that is $$$. Personally I'd first swap in the wide ratio gears from an E4OD. Would help 1st and 2nd, and leave the cruise RPM alone.
  #7
Old 06-05-2013, 04:44 PM
BadDadd BadDadd is offline
BadDadd First On Race Day
Same gearing scenario with my 76 Mk.4 (p.10 of photo albums) Started with engine mods. Desmog, 030, mild cam, mild head work, stock int.& carb, all new 2 1/2 pipes & mufflers, standard rebuild of C6. Much improved performance but only when manually working the auto gears. After lengthy research, seems like 3:25s' are best answer for my 5483lb car. 3:50s' strong contender but increase in rpm becomes a healthy concern and especially so if you're going to mash it. The stock springs in your heads are a bit too soft for high revs. At least, mine were and I bent a pushrod.
  #8
Old 01-25-2014, 12:43 PM
mustangman.jg mustangman.jg is offline
mustangman.jg First On Race Day
