High torque starter install. - 460 Ford Forum
Old 02-20-2013, 01:59 PM
twekd1 twekd1 is offline
twekd1 Driving a Ford
Default High torque starter install.
Well i just upgraded from the stock style starter to the high torque style starter and figured i would share my experience.
Here is a picture of the stock starter
http://www.flickr.com/photos/1335913...in/photostream
After pulling the starter out i seen there is a huge difference, the aftermarket starter comes with a built in solonid that has to get a jumper wire to use with the remote mount solonoid. To clear my headers i had to rotate the mount but it was just 2 alen keys and no big deal. You do have to check pinion depth to make sure you have 1/16 clearence from the flywheel (i was fine) but if too close they do supply a ship to install.
here is a copy of the instruction sheet it says the starter is good to 12:1 compression
http://www.flickr.com/photos/1335913...n/photostream/
Old 02-20-2013, 02:25 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is online now
What brand is it and how much was it?
Make sure those 2 clocking screws are in there tight but don't use any thread locker. ....ask me how I know.
Old 02-20-2013, 02:51 PM
turbo2256b First On Race Day
To clear my headers had to run the wire to the remote solenoid up and over between the intake and valve cover.
Old 02-20-2013, 03:43 PM
It is a big block for DENSO starter.
Part # BEP50018
Cost just over $110
O ya the lower screw to bolt the starter on has to be installed before the universal plate goes on and can only be tightned with a wrench. You can see it in this picture.
Old 02-20-2013, 08:13 PM
Vandy Vandy is offline
Vandy Driving a Ford
It,s best to install a stud and locktite it in then install the starter using a nut. I also use a 12 point nut
Old 02-20-2013, 10:51 PM
xoliex xoliex is offline
xoliex First On Race Day
why didn't you just go with a OEM hi tq mini starter? i followed what others are doing and getting a lifetime guarantee warranty start from a part house.
i just asked for a starter for a 96 f350 with a 7.5!
  #7
Old 02-21-2013, 09:25 PM
BigRigTech's Avatar
BigRigTech BigRigTech is offline
BigRigTech First On Race Day
I asked for the same, works great and in a pinch any motor off another stock Ford GR starter could be installed to get her started. I keep a spare motor for the starter in the tickle trunk I take to the track full of spares.
1987 Mustang GT drag car
472", A429's, 560HP/560ftlbs
rollerized C6 with a Merkl t-brake VB
5000 stall on the brake, 9" diff with 3.89's
Best ET 10.13, best MPH 135
Murphy's law in motion daily
  #8
Old 02-22-2013, 04:38 PM
The stock starter is more expensive, and I had no clue of the ratio. This Denso starter says right on the instructions good for up to 12:1 compression, And has a 3 year warranty.
It was a no brainier, cheaper and built for my application.
Insurance
Date of Birth
Month Day Year
Privacy
