New 545 build - 460 Ford Forum
Old 03-07-2013, 07:20 PM
427 sideoiler 427 sideoiler is offline
427 sideoiler First On Race Day
Talking New 545 build
I plan on using this in a 1977 f-100, I had a 427 sideoiler in it and sold that.
I have a pre 1979 block .030 over that I picked up form a shop, ( some one dropped it off had the work done and never came back) they told me when I get the pistons to check the clearance and if it was to tight they would hone it out a little.
I plan to run E85 @ 12.5 to 13 to 1 compression 4.5" stroke naturally aspirated. ford racing SCJB heads with a small solid roller cam.
This will be a weekend warrior maybe go to the strip a few times so I don't want to run much of a stall converter if any at all in my c6 tranny. I am looking for a weiand Stealth Intake Manifold.
I live near Gainsville FL if any one would like to offer a good machine shop .
any advice would be appreciated.
Old 03-07-2013, 10:24 PM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
Default Re: New 545 build
Well theres atleast one or two guys on here trying to sell a weiand stealth if that interests you.
Old 03-08-2013, 07:53 AM
I looked in the auction section but did not see any.
Old 03-08-2013, 07:55 AM
The Cam that I am looking at is comp XR274R-10 2200 to 6200 rpm (intake 274 duration .65 lift) (exhaust 280 duration .657 lift)
Old 03-08-2013, 08:15 AM
rmcomprandy Bleeding Blue
Now I get it because that manifold is available almost anywhere ... you have no interest in buying that manifold NEW.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
Old 03-08-2013, 09:18 AM
Just trying to save the planet by recycling.
  #7
Old 03-08-2013, 10:52 AM
68montego's Avatar
Its in the auction block. His name is 7T9cobra. Guess its just far down in the thread list.
  #8
Old 03-08-2013, 12:07 PM
Thanks I pm him to see if he wanted to sell it.
  #9
Old 03-09-2013, 07:38 PM
what size carb should I shoot for? I was thinking of going with a 950 cfm quick fuel e85 double pumper.
  #10
Old 03-31-2013, 06:11 PM
I now have my heads and rotating assembly cleaned up the casting marks on the exhaust to day. I seen that cars by carl sells carbs I was wondering what size my combo would need.
  #11
Old 06-12-2013, 02:23 PM
I got started on my short block today.
  #12
Old 06-12-2013, 08:25 PM
butterbean butterbean is online now
butterbean First On Race Day
Default intake
did you find a intake? I have a performer RPM that I will sell you
  #13
Old 06-13-2013, 12:14 AM
TorinoStyle2 Driving a Ford
950 carb will work good. Possibly a Holley HP 1000 that works with the 4150 style bolt pattern.
  #14
Old 06-13-2013, 05:15 AM
bob460 bob460 is offline
bob460 First On Race Day
Good idea would be to back cut the intake valves!!..........and get a custom camshaft for those heads.
Looking good
  #15
Old 06-13-2013, 08:38 AM
ProStreetFairlane's Avatar
ProStreetFairlane ProStreetFairlane is offline
ProStreetFairlane Driving a Ford
Garage
Be careful with the E85. Don't leave it in the carb over long periods of no use, it may jell on you. It will pit the insides of the carb too. Also, change the oil more often. I hear there are less problems when used in a fuel injection system.
NIGHTSHADE: 1966 ProStreet Fairlane
Street driven 573 BBF, 4.605 bore A460 block, ported TFS Street heads, JE pistons, 6.8 Eagle rods, 4.3 SCAT crank, Bullet cam, ATI C6, 3.5" X pipe and Dynomax Ultra Flows...thanx Charlie/Lem & Jet Boat Bob!
http://www.jetboatbob.com/
http://bfevansraceparts.com/
Insurance
Date of Birth
Month Day Year
Privacy
