c6 shift lever swap - 460 Ford Forum
Old 03-31-2013, 12:24 PM
501coup 501coup is offline
501coup First On Race Day
Default c6 shift lever swap
So I've got 2 c6's. One, I think, if from a 1975 truck (d5up) and is a fresh rebuild. The other is from a 72 lincoln that came free with my engine. The truck trans is column shift and the lincoln is a floor shift. I'd like to put the floor shift linkage on the newer rebuilt trans. Is it a direct swap? anything else from the 72 that's worth swapping? Thanks guys
Old 03-31-2013, 01:43 PM
DeepRoots DeepRoots is offline
DeepRoots First On Race Day
should swap right out.
7/8 or 13/16 wrench is needed if I recall, and a pair of channel locks.
If either of the transmissions are old and crusty you might want to replace the orings, otherwise should be easy.
Old 03-31-2013, 01:56 PM
stuarta stuarta is offline
stuarta Driving a Ford
Remove the valve body.
Pay special attention to the detent position in relation to the manual shift valve in the valve body as well as the k/d lever.
Remove the 1/2" nut from the k/d lever.
Remove the 7/8" nut from the shift assembly.
The shift arm can now be pulled out.
Now would be an excellent time to replace the seal and "O" ring.
Reverse the procedure.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Old 04-01-2013, 07:05 AM
Great, thanks guys
