Engine Limiters? - 460 Ford Forum
Old 04-02-2013, 08:54 PM
MrScharfenberger's Avatar
MrScharfenberger MrScharfenberger is online now
Default Engine Limiters?
I'm struggling to find a good attachment point for an engine limiter on my 1993 Mustang on the drivers side. Obviously the block would be the best place to attach one but I don't see that happening. The headers pull in very close to the block so attaching a limiter to a motor mount bolt hole won't work. I thought about extending a fabricated bracket out to the front of the motor from the motor mount bolt holes but the oil filter will get in the way. Is it OK to attach a limiter to the front engine plate as close to the timing cover as possible? Or is that a bad plan?
I have a two good places on the block to attach one on the passenger side so I'm not worried about that side.
Old 04-05-2013, 05:10 PM
bbstickstang's Avatar
bbstickstang bbstickstang is offline
bbstickstang Driving a Ford
Send a message via Yahoo to bbstickstang
North to south movement or east to west? Are you on motor plates, or mounts?
6.15@112. 1.32/60' New best, 12-20-13 All Muscle and No Steroids!
69fb mustang ,509,nash 4+1,4.56 ,31x10.5 w ,3309 w/driver.
I get to feel the torque of a BBF 4 times an 1/8 and 5 times a 1/4.
www.classicgearjammers.org
Old 04-05-2013, 06:14 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
Front of the head to the frame rail is pretty standard.
Old 04-05-2013, 10:56 PM
White Lightning's Avatar
Personally I try not to attach anything to the heads, it just puts strain on the sealing ability of the head and intake. A limiter will work running fore or aft, and as straight in line with the crank centerline as you can get it in order to negate (or not cause) any flex in the plates. Of course a mirror image limiter side to side is desireable but not always possible. Think about how many G's the car will be experiencing on launch and design the limiters around that figure. Keep in mind that a limiter that isn't in direct line with the direction of force will either impart a lifting or lowering force on the engine and/or the attaching point. What about a remote filter location Chris?
Rob
Old 04-08-2013, 07:52 AM
Rob
I like the remote filter idea. If it comes to that I will do it.
I had been going back and forth with 79DragZ. He has some limiters on his motor with MADD Dog headers that mount to where the motor mount plates bolt to the block. I have the brim joints arriving today from Jegs. I'm going to try his method of attaching them. If that doesn't work I may try the remote oil filter mount.
Old 04-08-2013, 07:19 PM
FourEyed Freak's Avatar
FourEyed Freak FourEyed Freak is offline
FourEyed Freak Driving a Ford
I run limiters on both sides to the motormount location. I have a stock location filter and 2 1/4 headers. Keep trying it can be done. Ill try to find some pics.
When to much is just right
  #7
Old 04-08-2013, 07:33 PM
John Myrick's Avatar
John Myrick John Myrick is offline
John Myrick Driving a Ford
What about attaching it at the bellhousing area or the trans mount ?
Some people take themselves way too serious
  #8
Old 04-09-2013, 10:05 AM
The stock trans mount isn't a great place because of the leverage that would be applied to the tail shaft housing. Like Freak said, the stock motor mount pad locations are the ideal spot. Limiters don't have to be long, in fact shorter is stiffer and as I said before, in line with the engine and trans centerline is perfect. Attaching the limiters to either plate will just cause flexing between the capture points on the plate and the limiter attachment points and eventually work harden and break the plate material.
Rob
