Fastest stock block 460 car? - 460 Ford Forum
Old 04-03-2013, 12:09 PM
Ryan C's Avatar
Ryan C Ryan C is offline
Ryan C First On Race Day
Default Fastest stock block 460 car?
Just curious what kind of #'s anybody has put on the board running a stock cast iron block. Regardless of the bore/stroke or NA/boosted/NO2
Outta Sight Racing
545 W/SCJ's power glide, stock suspension and 275's
1.21 60' 5.45 @ 123 8.63 @ 154 3250#s
Old 04-03-2013, 08:34 PM
Darrin Gorham Darrin Gorham is offline
Darrin Gorham Driving a Ford
Look up Erica Ortiz, I think she ran 6.60s for a while.
Old 04-03-2013, 10:03 PM
Vandy Vandy is offline
Vandy Driving a Ford
C8 block
C8 heads
Offset stroke iron stock crank
stock 2 bolt mains, stock main bolts, stock head bolts
mid 7,s at 180 +
Old 04-04-2013, 09:10 PM
TorinoStyle2 TorinoStyle2 is online now
TorinoStyle2 Driving a Ford
Did'nt Erica Ortiz go high 6's at 200+ MPH??
Old 04-05-2013, 09:04 AM
Ryan C's Avatar
I've just been a little worried my stock block won't hold up but I think I'm good for a while. I just need to stop listening to the haters that's all.
Outta Sight Racing
Old 04-05-2013, 09:42 AM
promodtbird promodtbird is offline
promodtbird First On Race Day
Default erica
she ran 6.60's at around 220 with a early iron block aftermarket 4 bolt caps unknown used about 4" stroke crank old howards rods iron CJ's and twin turbos on a 10 1/2 tire in my old gateway built tbird which they had upgraded to much more current safety spec's after i sold it to them , it was rebodied to new style mustang but has to my knowledge has sat since , hope this helps
  #7
Old 04-05-2013, 10:12 AM
Paul Kane's Avatar
Cool
The engine run by Erica Ortiz was a 4-bolt SCJ block, was filled solid, used a forged crankshaft, used D0OE-R SCJ heads, and was tuned by one of the most respected names in Ford racing history.
Originally Posted by Vandy View Post
C8 block
C8 heads
managed low 7,s at 180 +
The engine run by Vandy was a 2-bolt with OEM main bolts and OEM head bolts, was unfilled, used OEM passenger car heads, and used an OEM cast crankshaft. The car ran low 7's regularly. When the engine was set up to make any additional power it would routinely destroy drive train parts behind it, usually the TH400. It is believed that if the TH400 were replaced with a Lenco that this 2-bolt block "cast everything" engine might have made it into the 6's.
Paul
High Flow Dynamics
  #8
Old 04-05-2013, 10:51 AM
gasser196's Avatar
gasser196 gasser196 is offline
gasser196 First On Race Day
C8 block
C8 heads
Was that on Fuel or Alcohol?
  #9
Old 04-05-2013, 10:58 AM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is online now
CarsByCarl Driving a Ford
6.88 with an offset ground cast crank Paul....
Originally Posted by Pro5.0Princess View Post
I was running a Stock Ford 4 bolt 460 block filled with concrete. We ran 6.88@ 207mph with a cast crank in the car. After the 6.88, we switched to a little better steel crank, and ran 6.69 @ 207mph with it, still in the stock block. Any questions regarding combination can be directed to Mr. Al Moody in Mableton, GA. He is the engine guru behind my car, John Gullett's small block and big block operation, and several others.
For what its worth, when I took out the Cast crank, the engine looked perfect. But I realize that I was playing with a grenade with the pin-pulled. So, I'm switching to an aftermarket aluminum block this year and a good rotating assembly and I'm headed out to chase down my PRO MOD dreams. Mr. Moody will be running the old motor on the dyno with all my parts next week, and I'll have some concrete engine dyno #'s for you, and how it held up. Better it go on the engine dyno than at the 1000 ft. mark at 200mph.
One thing to consider... an engine diaper and a belly pan... that way if it goes, you'll minimize the experience of skating on oil/water/whatever other fluid decides to get up under the tires.
My car went 6.69 @ 207mph with a stock block filled with block filler. Probably could've gone more, but I opted to switch to a better engine program this year and bypass the "trial by error" factor. I don't want to know what the breaking point is.
Hey there!
Well, I just ran 6.88 @ 205 with a scat cast steel crank and a stock filled block. I have aluminum rods in the motor. We figured it made approx. 1700 hp on that pass.
Hope that helps!
-Erica
  #10
Old 04-06-2013, 09:42 AM
Paul Kane's Avatar
Cool
The numbers noted above were on blown alcohol.
Very nice, more proven capability of the OEM parts.
Paul
High Flow Dynamics
  #11
Old 04-06-2013, 02:24 PM
gasser196's Avatar
Thanks Paul.
  #12
Old 04-07-2013, 09:17 PM
torinojoe1971 torinojoe1971 is offline
torinojoe1971 Driving a Ford
Default BBF
Gotta love the 460 blocks.
  #13
Old 04-17-2013, 01:49 PM
groy's Avatar
groy groy is offline
groy First On Race Day
Wonder how that compares to a stock 454 block?
  #14
Old 05-10-2013, 03:26 PM
Finmach's Avatar
Finmach Finmach is offline
Finmach Driving a Ford
With stock block they did 1731 hp with 7300 rpm, not to mention with stock crank and with boxed stock connection rods...
Now would you box the stock rods and give the engine +7000 rpm and 40 psi of boost??? Engine was made for modified minipuller, at now a days the guy is running a460 block with some serious internals instead of stock OEM. Geez, I would say.
- '72 Mach 1 460 (A429+G429)+TKO600+M9" DL
- intermediate go fast project
TOTAL PERFORMANCE
  #15
Old 05-13-2013, 09:46 AM
Paul Kane's Avatar
Cool
Originally Posted by Finmach View Post
With stock block they did 1731 hp with 7300 rpm, not to mention with stock crank and with boxed stock connection rods...Now would you box the stock rods and give the engine +7000 rpm and 40 psi of boost???
That engine used aftermarket H-beam connecting rods, not modified OEM stock rods.
The engine consisted of a D9TE standard-webbed truck block with CAT 4-bolt main cap conversion, water jackets filled solid, o-ringed deck, head studs, D2VE open chamber heads with CJ-sized valves, pedestal rocker arm valve train, 4U cast 429 crankshaft, L2366 429 pistons, modified OEM oil pan, high volume oil pump, and H-beam rods.
It's a great accomplishment which very much underscores the capabilities of the OEM parts when prepped well, tuned well, and utilized in the specific applications where this type of power handling is indeed possible.
Paul
High Flow Dynamics
Insurance
Date of Birth
Month Day Year
Privacy
