Best Thread Sealant For Gas Fittings ? - 460 Ford Forum
Old 04-09-2013, 04:43 PM
colormebad colormebad is offline
colormebad First On Race Day
Default Best Thread Sealant For Gas Fittings ?
What seems to be the best sealant for gas fittings ? These holly regulators just won't seal off good with other stuff i have tryed..All other fittings use o-rings , which work great...I bought some loctite at a local tractor shops that says it seals gas fittings, and other fittings i just put on the reg's, but haven't fired up the pump yet.. Loctite PST 592 is what i just put on the threads..Will know soon....Also bought some Permatex 80632 thread sealant with PTFE if the above don't work....thanks
Old 04-09-2013, 06:09 PM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
My fuel lines were leaking on my duel feed holley and I used pink plumbing pipe thread tape. Its like thread tape but alittle thicker and more durable. They don't leak anymore. Hope this helps.
Old 04-10-2013, 05:58 AM
TommyK TommyK is offline
TommyK Driving a Ford
+1 on teflon tape
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.50 trac lock
Old 04-10-2013, 07:28 AM
aquartlow's Avatar
aquartlow aquartlow is offline
aquartlow First On Race Day
Teflon tape works well, just keep the tape off of the first two threads of the male fitting or you could have problems. I have also used Permatex form-a-gasket with great results. I did experiment with a couple different brands of Teflon based semi-liquid pipe thread sealant that were approved for gas/fuel lines and they sucked big time. Hope this helps. Todd
www.supermotors.net/22468
Yeah, it's a hybrid...It burns gas and tires.
No matter how good she looks somebody, somewhere is tired of her sh#t.
Insurance
Date of Birth
Month Day Year
Privacy
