great lakes dragway test and tune 4-13-13 - 460 Ford Forum
Old 04-11-2013, 07:57 PM
twekd1 twekd1 is offline
twekd1 Driving a Ford
Default great lakes dragway test and tune 4-13-13
well im addicted now, i need this car to go fast!
this was its first run on the new setup last weekend
it is a 533 big block
2 750 double pumpers
with im guessing around 11.5:1 compression
3.70 gear 28-10.5
strange adj front struts
triangle 4 link rear with strange double adjustable shocks,
i'm using this web site as a log of what i am doing.
in the 1'st run-
carbs were all wrong i had 70 jets primary and 80 jets secondary, the other carb was 80 primary and 70 on secondary also the scoop flaps closed and choked it out. it was stupid rich but running
the shocks were all set on full loose.
the shifter took 2 hands to change to second.
then i also had my old truck battery in the car so of course after getting fuel at the track the car didnt want to start.
i changed the jets to 70 on primary and 72 on secondaries matched on both carbs also took the flaps off the scoop
http://www.flickr.com/photos/1335913...n/photostream/
new 900cold crank amp battery.
front shocks adjusted to #3 setting (out of 8 clicks)
rear shocks i am setting on the middle setting expansion and compression.
i also installed a new hurst quarter shifter
http://www.flickr.com/photos/1335913...in/photostream
I am going back to the track hopefully Saturday morning Great lakes dragway union grove Wi. Will any one else be up there or want to help tune the car up?
Old 04-12-2013, 03:19 AM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
Looks good! What did it run? My buddy was there last Saturday for the NHRA chassis cert with his Camaro. It's orange and silver. He made 4 TNT passes, said the track was so so... He was running 8.90s. Would like to make it down there at least once this year, haven't been there in a long time. We run at WIR mostly, it's 150 miles closer! But I really like the Grove. What heads are you running? Look like possibly DOVEs in the pic? Cam? I had a tunnel and two 750s on my 514 in my Torino, ran around 72-74 on the primary side with power valves, and 80-82 on secondary's. No p/v. Around 34deg timing with A429 heads. Got it to run 10.30s @ 3,700 lbs.
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
Old 04-12-2013, 07:43 PM
i will be up there tomorrow around 11am as long as there open with this crazy weather. heads a the c castings with c/j size valves cut into them.
cam: http://www.compcams.com/Company/CC/c...?csid=991&sb=0
I do hope to be in the tens on motor then spray the nitrous to become competitive.
Old 04-12-2013, 10:34 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
what rpm are you crossing the line at? 3.70 gear might not be enough?
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 04-13-2013, 09:25 PM
stupid weather track was closed today,
hopefully tomorrow it dosnt rain and i can get up there.
I only have a 5000 chip in it right now till i get suspension working.
Old 04-14-2013, 03:18 AM
That's the same cam I had in my Capri. Similar to your setup, but without the tunnel. Ran 11.20s at Da Grove. Pump gas, DOVE headed opened up to CJ gaskets... 69 Lincoln motor with a Victor intake and 950 HP carb. Had 3.73 gears and a C6 with a 8" converter and a brake. Fun street car!
  #7
Old 04-14-2013, 10:24 AM
levy87's Avatar
levy87 levy87 is offline
levy87 Driving a Ford
cool stuff.Are you from chicagoland area?Ya the grove was pounded with water hopefully maybe the'll open today.
10.5 junkie
  #8
Old 04-14-2013, 05:44 PM
bigblok86ranger's Avatar
Super Moderator
I was up there last weekend for chassis certification as well. I had work at my shop so only stayed long enough to get certified and had to come back to work. I seen the Camaro nice looking car.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
  #9
Old 04-14-2013, 10:59 PM
track was closed again, ;-( when i called this morning they said they could just see the tips of the grass sticking out of snow.
Im from the ohare area.
Now i'm hoping i can make it to the track after work this week, the weather looks bad tho.
  #10
Old 04-15-2013, 08:50 PM
it says no rain tomorrow i hope they open up!
  #11
Old 04-16-2013, 10:38 PM
track was closed again due to too much standing water. man i'm going crazy wanting to get this car tuned. Now my hopes are for a spring car filled weekend saturday test and tune with the mustang. Then sunday autocross at the sears center with my mg just to get seat time.
  #12
Old 04-21-2013, 11:01 PM
I was able to get 9 passes in on 4-20-13
With a 4 bar adjustment the car is launching much straighter. I still think i have to extend the upper right bar a turn.
The motor still is having some issues, I started with 30 degres of timing and carb jets at p70 s72 it was still rich. I dropped the primaries all the way to 64 it did seam to help secondaries the car slowed down anything under a 70. it seamed to like timeing, i brought it up to 37 degres and i think i can go higher??
Here is the issue i am having. problem starts in the burnout. I set line lock and bring it to 5000rpms shift 2nd and when i go to drive out of it the car gets its first grip and basically stalls out. (it did stall once)
I launch the car and it goes prity good 1.5 60'
then it feels like i get pulses of power. hit second at 5700rpms and all second it basically feels like it full horsepower then half power pulses, pull 3rd gear and same deal.
I have a holly blue pump, 6psi (how do i check flowing pressure?), floats adjusted.
Any clue what the power on / off can be?
  #13
Old 04-21-2013, 11:07 PM
Super Moderator
What size fuel lines and fuel pressure?
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #14
Old 04-21-2013, 11:14 PM
Super Moderator
Try 7.5 psi fuel pressure, hopefully you have a 1/2" or -8 minimum fuel lines.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #15
Old 04-21-2013, 11:26 PM
fuel cell to a big race canaster filter then blue pump 1/2 inch line to the regulator where it has 4 lines comming off it that is -6
