84 f150 build suggestions - 460 Ford Forum
Old 05-12-2013, 05:14 PM
Chris Guthro Chris Guthro is offline
Chris Guthro First On Race Day
Default 84 f150 build suggestions
Hello guys, first build and am wondering what you gus would build on a tight budget for a tire frier. Its a 2wd with a c6 and 3:50 limited slip rear end. My engine is a 76 f150 460.. The bottom end has to be completely redone. Would about 2000 get me a new bottom end?
Old 05-12-2013, 07:10 PM
snotrocket snotrocket is online now
snotrocket First On Race Day
Is it a short box or a long box I'm just starting my build for my 89 f150 long box. What's your plan for motor mounts?
Old 05-12-2013, 07:43 PM
It's a long box. I bought the frame perches from a 95 f350 with a 460, and bought the actual mounts at car quest for 35 bucks a side from a 95 as well. So I'm into it about 125 bucks for the mounts but the thing is that they are factory mounts. Not some cheesy l&l product
Old 05-12-2013, 09:07 PM
Here's the truck it's going in, although I'm doing a complete frame off on it
Old 05-13-2013, 11:11 AM
Looks like a nice starting point. Right now I'm building my 460 for my truck. And with a budget of 3000 and shopping for used parts and the best deals I can I should have my whole motor completely done carb to pan including machine work. I went to the machine shop and let them know what I wanted and what my budget was and they were more than helpful and have given me lots of advise.
Old 05-13-2013, 02:07 PM
Yea that's around my budget as well with my build! Maximum 2000 in my block hopefully
  #7
Old 05-13-2013, 02:24 PM
killer501872000's Avatar
killer501872000 killer501872000 is offline
killer501872000 First On Race Day
Garage
my self i would rebuild the bottom end, leave it stock and get a set of aluminum heads.that should give it a good wake up call. then if later on you want to stroke it out you already have good heads.aluminum heads are all over in price hit ebay.they run from $900 and up complete and a rebuild kit starts at about $400 and up.but you could stroke it for around $2000 or less dipending on how much the machine work would run you
  #8
Old 05-13-2013, 03:20 PM
Would it be better to build the stroker bottom end first than aluminum heads later? Because even on a stroker aren't d0ve heads acceptable? I inagine a 500+ cu in with fairly stock ported heads would be a torque monster!
  #9
Old 05-13-2013, 05:02 PM
Garage
thats up to you but d0ve heads can be made to breath with some work.what kind of hp you looking to make?
  #10
Old 05-13-2013, 06:34 PM
Like 375-400?
  #11
Old 05-13-2013, 06:40 PM
Garage
wow a realistic number lol.de smog it and a good set of headers would probly get you close.
  #12
Old 05-13-2013, 07:20 PM
Yea I just want something to get me in the mid 13s maybe, not trying to set land records
  #13
Old 05-13-2013, 08:47 PM
Garage
13,s should be easy to get out of it with a mild build.
  #14
Old 05-13-2013, 08:54 PM
Yea I'm not going nuts as I'm only 20 and since I'm doing a frame off I don't want to skimp on everything else just to have a 550 horse engine lol
  #15
Old 05-13-2013, 08:59 PM
I'm shooting for low 13's high 12's as well. My motor is a 1975 460 getting bored 30 over with 22cc pistons and c9ve heads that I have ported following Scott's instructions on the rhp website set up with proform roller rockers block zero decked should be right at ten to one. For a cam I'm getting a custom grind from Scott. I'm hoping to get a good used performer rpm and run a 780 cfm hp Holley double pumper. I'm also running a c6 and a nine with 355's. would like to see one hp per cube but idk machinist figures 475 at least.
Insurance
Date of Birth
Month Day Year
Privacy
